[REVIEW] TV Box Alfawise A95X R1 - RK3229 1/8GB
Txemoto
Alfawise A95X R1
SvC2EX2-t63e6bypXBP1RQ2vAWaYM44d3w9VernHHOFCLiPjqyas0jXZyc4qZMrixCtcoF1vLpa-nWe3O1MKWgG0Z2nMN_EMUyiW6q0A-bESvaDSW9arf2pxLQsOmczwHnCQfb87hRcsLDp7n0--7yofuMSP69z0bdBKPE64JQBfrQ-HeUy92arE0p3kT-l4LmMZPJaKpzeOa-ZPvnTGZSY9I0nWacLzJWcP4-_nZF1bg-sGiqipOSVtSSui2JxvQFX0wIx9QVrNkAQ-EtuC4dSy6hB51TP2_pGi6ekeFH2PvSApB-R-I4vOn5Roc8xQT_UwLOJ9_DBLzH6-TclHsxbSamvpUBklEkN9b8bx7BeTRD4KZchETrWdJWpA_jdKjbLMCw0HkdOMrlOYDUh64TPgdn-ocONuNSlqFLVL0NfaxJHLCo7t7lDv6lO3M5lCNDYVaqypGAVIhpDCOleA0NBGfaobAgKIt9rAMMvEceP_Lkj5YNfMNutexN4-VKlvJVuwVvowXMOcgZ-5OJSTyjzksYiZQxmeo4C_C8pcZrUIH_bUmZSAs0dI3ZLcv47J2t2OXQ4-31Gvrq-cATbhTwu8Ud_Kdh8jL1qwz5SlgC93lohsw7Mn5toixrdxQ6vPSbpbB3XqECSZTv4l-NXD3p9oPqYTlgyZr2G99CUmPg=w429-h486-no
ESPECIFICACIONES
  • SoC – Rockchip RK3229 quad core ARM Cortex A7 processor @ 1.5 GHz with
  • GPU: ARM Mali-400MP2
  • RAM: 1GB DDR3
  • Memoria interna : 8 GB eMMC
  • WiFi: 802.11abgn
  • Ethernet: 10/100 Mbps
  • 2 x USB 2.0
  • Lector micro SD
  • Otros: Salida SPDIF y salida AV
  • Android Marsmallow 6.0.1
  • Tamaño: 9,3 x 9,3 x 1,5 cm
  • Peso: 120gr
CONTENIDO DEL PAQUETE
HjUfKmwwsKlHlsuE6gAheHqDdvqlHKWOaHX8NnnnOy8ueZAcs2HeIIyn8mXRO-4jLgkV8tjPc8JYSg46i-97lMJfP_FCt4fy0KOY2wSnauB4rVEXvx1gq9a8q34iqiYPF62yZMGojIoELa_8eKvSUFkQz7wZLP7pWaRhofv5lHCj52ZOYIzN0T_rji_uB6Fsb044cPFm7VbJiQQWBP1Vb_TElQ_-WAIGBwfPskNIN98YXKKpwp0bnJD6imXZOO6tA-0w6VJaAtpHF2z8Zov27grxRSEIFSQIBCUHQaEIZrLLQLeC9p30IPggMHGmmiWJemrLeqdgwNLJe2azUaiEIHrqHAS87-I2h5y4_bLBA-FG2zmhTaBIjbA43ShIxLtnmtQ1DL0PB-_UPNg4TMi_YvAORVc_ddT9JeJwtSLQQL6JqOp0nmbflNpA2lVBEwht3BKHx_75iSN-Xew0ghkjtKfYrsbU3jPMWAMEpZIWYKW9TpRuGUuUxKrD6ZFA9ny0BocM9HEjZj0mKh84KKvVo6lfO7CYW_8SwUhSripscDHQWIwg9xMLWQWODr8Z_OOAJfcFVc4Izz8tqvsbDJVtF20eNtYGneeLxOnaKCdc7d9Ns8rsjVcOuOhFLxQvxbbm_6KaeiE-b26W_-FbI-OoreF1mUUdwppnhqM8pAWwkQ=w1052-h613-no
CsGIblzwYGmd93mSmGjaADKaEFYZubWG0Ky-lW4z42bjoDWk8_JZBqWZaMZvjS3X7ViPZRW-4y69I_xdssKx4BHkjqWVCZ5LtZcBKne-1yVbZzlIMTuUxieJtfVxz2KjB_Ijm594hP_hFlhoCYHNguFW191LYk_fKLD92M0h08V2_FlHfTxX7kxhWFraGYM3xpfD92N7iC39UZ7tJWpbLTghTNlPf38PeFDodt_RZnCS2wIbDL7RXLCgA_PtzWn9ZcQxatAg8luMwradKNJ_QbujJdqj_zFZ2Y5RrCug4l4Q307X6FTN3n4EQ6UhPJ73cgyikPLmlTBaEBA207CpMko4fa4y9kn6IXkA2hkiXNzY2fQ_f2Y8JzUuRrc22ywINP7UilSYHR1j15UVX8Ar60EenxEwDObGI9VesW-vcJukh2DfP34Ykt5TR7cwC4pzIHXi1D8btFlZeYuDi-dgq3mEQZ85n0bbQRwM43tqF11Mwzd3ZWAvYKV_XU4zJElntXzq59HJwf0AzsxrGRw_gxV0r9Ytf4hvHDEBP2NNWiNUb913wtih3PSmCGTCODwaEbBYuIqLN8fQF8r6z7vl-mjp2UZNyhY3f6d1LtqFmQBEQjjVwbHsB8FXtHZ9C8onHgvIEdtkVlqrJjRKinL4MkEovwLfqLC2LXSkAtzoKQ=w646-h613-no
  • A95X R1
  • Mando a distancia IR
  • Cable HDMI
  • Adaptador de red
  • Manual de usuario
DISEÑO Y CONEXIONES
s5v_ZN1BErJiHl67SqCw8pwyb-4Ts5xKcsX6gtMmYHv6m1bHOtjwlhpUkk_kEmZnp1NljYSrreflPQ9MhD9GRCr0bCrAwJAgx6I4RpJtggqBFCpexR5928UQbXEuuLKQHbbUl2m5ShNU46pGZGwbKU4iYgbEAotv4E6dQW3Fylc6cFRqARJwUUpLs1beemExymtS2G3FfRcVfZC7yJbHGCrittB1CA9ZbD3mxPdHyDOYvifAEzxy3ARJFStpS6BS5wm8KbzUE3USRivagDG15chB9iF72ZJDl8WCtcYOKhxcoUduB-vI9lDRrGqY3szWwj_ZlSNp4j5ANwQmsfw_FtLlpg5DKqnqlnwDYQMFlFdh99d1ZKBCXAkBwCIzGqi6ZepHsf0yR4AYmzUrJu64i26ji9_vt-e1U9_08Qi_KFQb2H6M6PDzUK8vI91rTshGc97qGkkICmYbXKM2HkGPvxPl8iGKywi4jGHsXQ4nTCXtllGgXCOw1ra8WuX0CxXWXx00fSJdZ1Sco8TQ8Y-K0wAkCCNv8Gl4sFuNM065cXdHbwIZEJ5lfw3NcJMvoi4eeluhB1WKTk77YFzK1KtWkv6oIEx31rOluf_MSfJzTaMVmo_lSd8hBirzSw2AO2T9ZxmiXz5cvPp_7xadzKhOF8sI8XMGXqFXYiFPKudZ1Q=w1072-h834-no
Lo primero que llama la atención en el A95X R1 es su reducido tamaño y peso. La caja es totalmente de plástico negro mate, menos en la parte frontal que es brillante.
En la parte delantera tenemos el sensor de infrarrojos y el led de estado totalmente ocultos.
El Led tiene dos estados; azúl cuando el dispositivo está encendido y rojo cuando está en stand-by o apagado. No tiene una intensidad que sea demasiado molesta.
oVbhYADPG0SI2BDDa2NJ1lwGCtj_kXdHOivKaeTxm81o2QvXqsZRx_gmAQT3EG3lzYv4C8kEI0JRviqVIrIeSaV7K1OOuMh6qvRDD80p-gNJo1lldT1Po_dWMBNC4qgEcU-b4wuGrO1oOHqTiVoYNwW5nsOt59hLfWXYC_EoyUkXliG9Ynt2zZATWKDINB6QiVQZ4ryLjaBFQxP5a7OuPf5RvliawKVTDc8ZnUqir1HK2kab5W3DhiCHSsV_H1Ky-5IaU-rebeej9V94Da4fqELfXquG6UDDv3ieMuKX8urGa6MSXpiN_g6UYXn4I66i9UC-TanRxxN4znYQx6e76A2SgefLXj4knEj8G-6uUQydImKGvR5NvN9NxPk-TrdsEw3kQ2aSGfxyzJw6dCNYipanJFS_mGgqjW9TxY4Piy4qVF7PQ2w5DEYZXVr2Htk8ylKPnZzKsJqiAnSqdxQStzhWIT-LIx9bqb8BPM73SEs-0m-0fmFxMkN3rlfK7NmZsKvEoQdE1XfrMOLFP6f0w1pEerdYIcbMpVYoB8nsikrlf4X7Wi54amVt7GplMtnGtqwsoDzX-rOdRNpIrUTb3HmQSqKzE_PbuLM0k7lN3nHP8vGTZ4luqiFcWXoVh3jaIJAnhNhXI40miS7vxe9QiNiCg-w1FJOuSeX4ur9E1A=w812-h267-no
En la parte trasera tenemos el conector de alimentación, el conector HDMI 2.0, la salida AV, el conector ethernet y la salida digital SPDIF.
Y2h-i4vZwoLLhKKKKBchJuY7u4bYTnDfSFj1HsxMcgHP8LDf0VwZYvDA4UXUnP_t66SLKYK6ENK2iqy4c-M10QoI6GzYaHscmHg4BnAFXAN2pKb3bPvxMcu5ksg7HOncrL70Vda7Cl9CbZUTBOKmjm6FSG4KGz2vJz52yMlmNVA_LcmTpajHTBCQWjDWVbROGZ56ZS74Oc8XGpZW8jOB1Lq3Z-KYg04iNos8Jn_-aiPB7HHTbYl_5N5v6tDZAdZWxiZtUuQZc-MsqW54Szoc3Uojqcc3B24LxjgAvnhck178o8gsTN-_6cSRL_tkmaOnYzuPimI8z9IVCq-oQ4cMr9qwVFwYWEaG8JAEHKrhrmXjNUs6YZfnCkdYd7pdWm5qLOrxo1hPRZ-rVfs7GKt44FIEVUsI3LQji_Lh1kCp7QHiYONo6hoMYA-hvwBfamsdLW1rhZCtZ57zrMpB2A7_hv3XYgmMs9gNbO87H8GLFo1zNumugKkfKVJiwDDDEYU9b_gpaAA6_-d478XKkoYU0ahIn5mC28Utc0FNtTehgnELXI_2P1IVIVo-iN-wRjisx-wH5-UftXOJ82unOzOdbhwbmwXrImGW7XLRYBb2thZYAtvNzCGtMp4kstWOZjYRMV_8lK2L5WxSweC2EwkejIkiga_Vhoae4ZCCWVV9dg=w1366-h407-no
En la parte derecha tenemos el lector de tarjetas micro SD y dos conectores USB 2.0 de tamaño normal.
gDj_bzEMOSEOyYQnwsV0gmo7uaviGZ_IaHYbqTcL1KtuXEEmnQwgXsajQEDGg9yRAeS5JkC2675Oarl3OMQW_-wbjriI9Tbsv3k6e0e8tXyV_XA7NHrCc0-O49GEEQheMdDpuvSeoYvJsYdSqEt4fNW8pivAHrPkYOEBfhZwWl8ajWBPQWm4cDgIQmbGi56qgG8UW9soGdvE8LfXInr-m_JdAVgIpCactrFrF6P0g6quvBgmDNO70mYx4gEyJCzcLGcNl2CZtU8XWzkxJ29GYxNtuDFGFw1QD0bvF0YtzwZBlqbCqlde6TW0SvwZOF1GBciYG6Je_28CQXLYY1we3u2cbZNEDWqUqb4g0omlh74Y-SywDbQ8wTMISzjP72q5OYeOlFknAdXkK0vyua4uS2J1X98ANuz5-3esU4SYZur_uAZaUN8uhetjIkbCehNUUY_couO-qTy_Bf78AECJsZEIP2-Z2NyhvZzhODfUD3tw2DzR6isHIemB_KTCR_3asG-RjlA0sQh5VFhV2pIIf7sN55VnDv55yDjrerQp0UCqHHsa-2jmUM9Uf_5GRoT29O7FUmmvWV63IOx_T0BNZ3_Ivaq14S0zS5GNonx9zzKdQEsw19ipFRPrsRGVZD8okXdpYA7KNuZcnO4JfpxGm3Qd4pUqe3N3OJLlpuvctQ=w1366-h350-no
En la parte superior tenemos el nombre de la marca y el modelo.
r3u-I4d4AEXljxpEAx_moDiSE8TFXeA6VEfdYqJxhV9HgFqvPLBMGkiCidwmt2RUQFSGnBQbVKjwF6GtrzHdb7N1frvzjo0Z_FTMkeenPxRGw06kLeVRMF16CX4gVWMW_PL9DMihXaeElShl4JiMvJdULNzd04cmPw3WQwK4dK02ptH92h7xFobEKQKanfqx3td9Uu6a2Tnc7hgDaexbQC0jGhPFeJVN-BihuOnkvfowGQ-pdRIlnAjZhhe1Ltfuq5N6dkeJI0-HPwEHwotIHlYt07jE_ZdnMTl7QJ_yygmA4vW5Z9Xx_F6XHZtne4GYQS0IPLUXAP5XUmp5Z5CcY1aKanKlQ1ZOMJDOpETUbyWFxdAAN-NVs3idermsDwnU86roCNQ7IJSr542InXN324bs3esb7geqBPTI68r-ErfPZBBJsZ2Isne6hwgcztH7A9kASnrbbQgwKXFTB4huy3geEOYpu1biXVvtJ3LxPJn8YtTl7d7qoqDJVEUrQb0153IFMbrsdrp5xgBVCL2hd4XrdsG70NsixQwcNydo6MZE3TdqMnuSg1EkDRQ_PylpPKMw_ytYUr2Nte6_LtuTeqCoRvV3c277HudKc4v2yQ5YqTkoZAWZEdleDHoNzbQJ04cLR_xJAHNz5OHJ3EPJDG97SHKoXzf0t44DJYLLww=w662-h613-no
La parte inferior tiene unas rendijas de ventilación a los lados y cuatro salientes de plástico para elevar algo el aparato.
1-omKiJ-fh73AhX9yvZTiDq9N1WxceuFb47WBBP4RZPOCCNMzwsUy3Rm-2DfHUmYJEuVSetofgwxJO2cti1hHjGWtfp17QEupm4ypk7l9o556zhxFAMJHRPnyfu9cdGwWrYaT858McvsyLEIbW-bQiZ5fApjYaAmYe5NbV7W0RiwiwZvc4_Bhtns7fs62cE7eBr1dtGv0krvnW23QcuFfDv7eIo98jYER8E_YS5FNTJVn0Hc6lbBHahcbujlvUPZB9oNGZbRCt_1SyQLNu5GBjbLjcqvGVUu95smmnVTvluEyP3c46HiNsYVU30Gjv6zcBgjziZKMrAjSRrcoRCG1sBw4d5OxLQiQ1JE5daZ35l5Qvwkmj4lXhlTkq0cTcTpp1hg-ZhgD0ueUJBCjU5FCUTyDst-FC-j0tBBV_G7Ox-dE0gl0NRxC797873M2BTWAcON6ULOpx1HlThFrsG_oBWLzGQmm_WlGRijkBuI4g9bNTdeGrJt370tF09S6Gs8cFgq7UWjnd6G6AesJViQQAN_8VBkZrqEHAVoDzXPi8xM7LT7ZS_WmMl2sKIH0-QreRLLF-CYNoXULzc9BxTs5r_qd5U-KtVt3HtUfXXAAsDQN_3Y5uhi5CjYU1OjA7adfqHyEkMK3xAnkgQTSg_c6RsgHE6FxRDkQW16Af1vmQ=w606-h613-no
MANDO A DISTANCIA
vXRmGMuehD_jmD1mOFroqDq_yHZCO8Izy_su-ZlrQBQGQw1HcLQzaK3t9HQimlOxEHoYFDQkoPB9axra8bZK9ES4wGykUM-fweT2-fI-VxpCTPSI0yFYgCN5orIDHlzT-XqipnfIXReevZXq2cBvaVbmkBU48dMOY_r-F43OJTnTcbtApGMLMROOzEx7A4DquHYh9yzYbJZ4dlNerQooLZqwrVE96nmGWn1e-OcSt2WTo6fUwwsyahl1iewImC-raa6a_K3PJBDk5tH5clz38zwm0nin2mp9mVK2hzDawXe3JldHG6aA3o_TErwMQ8jqzs6l7U13PiKubFo8dX8lS6ASNrLw8VC46tdZIslwbbrqmKOWWO6jRIM0h2UHOd9sjByDaL1hWG5KFmne25c6JeiLYo0BThZl6iw-hWdvQD3Qd_zPPkqak9X14976ZFH0DQp8btA8keYTAc42XOKLdMiEzeRcD_1Z1xSlirSu1KNr_0J8aW8JNlvGvcVniNOeV5yrSWZ6maF56080EuLbyPTNTTyzWX99mxXWyNfK2wcvlVAMZ1sbGAcbMSmkgVgUUec721xB6H6yuFuLasb3Ywe4HLUAg_kWlCDqbPWI9TsQxr0s7ShVsYjpnuw0w7IggHoDJklmA6fRbV5VKsUwaRqKM4tLWGeMSsaUUS1PzQ=w230-h613-no
Tenemos el mismo mando a distancia que se suele mandar con los equipos de bajo coste. Es el aparato con un rango de acción más corto. No podemos alejarnos más allá de un metro para que el sensor de infrarrojos detecte la señal. Nos veremos obligados a comprar otro dispositivo de manejo, como un ratón inalámbrico.
REDES
El dispositivo dispone de fast ethernet (10/100Mps). Dicha conexión funciona correctamente. El Wifi solo es compatible con la banda de 2,4GHz, y funciona sin cortes, pero la calidad del mismo no es nada buena, quedándose lejos del máximo teórico. Estas son la pruebas de velocidad de la conexión cableada e inalámbrica.
moVVFvD2FJmeksFHrldhPymPqsDo87dfKACpTL0yhWnE749Y5XDE8af2-FtoDEEUX1l50c5A-SbT6unJ5Jpxzfr3YcvSswOBHqy71tcu6NEc5TP2EfGzrHYefHdS8aHaKqrPAwpKHUtPULOF3DGTf_rJ6c3tF7YQWtKzS0DcB-9PW7wvmHRzsSCQ5Ilu9hB7xm7XtTfTs_gm-VRfXSui1E02pYrNLkOoGxQmYnL4_UZjI2pWYVvwz4P0sUv9LdWEwLsLvmXCYuvOJfgIUr4W8E-xPVox6mBbUnfaUtitz54DMyFz_BBn5jGUqEJOAR4tjlS99kWxfSRmmplTci2lOVysvOfkOgWNzW2IDm-NU4ioTSuSsD48C9y2Q1O_2Nf5djYjWJKQBOn5RWlQ24L20Zs9Z95jjdb46lgYW90rTuN46aMDagott29zw4qlaaooJ6GCUzWEqfuNK88nuL19foF8vX2Lvf9oGksa-qVo42XJwVJCpPPCb_eR6CtW9MJRJzabK21kX2ady8N2vgHpvsr2hPh_duf0u-lE5vQXcNfw7uGsLpk5mqyiRG5gfcHQtkO630Jg1HqH7oE1omkYxViTLjLC_UHOR6LnPjgNy56MFIuqfUojK6G_Mch5lQpZGxfTLA04qk-bXduyJ5rUkDzOV0UguDww0SDddhnZow=w1275-h287-no
El equipo no tiene bluetooth.
ENCENDIDO Y APAGADO
El A95X R1 no tiene botón de encendido por lo que, se enciende automáticamente cuando recibe corriente.
Pulsando brevemente el botón de encendido del mando, el equipo entra en modo reposo. Si mantenemos pulsado el botón nos aparece un menú para elegir si queremos apagarlo o reiniciarlo.
QCy4iZV55jOhEgnIa0vWgbbcTCMsye9SvpDK7lm_BXN7UeB4GSBmHaaCFyaW53AsMojLh8rqo47PN4Ysfkzo0d_7c4Xavooq3lJV-mRZR9cv6gzQA_gn1j8Hq1uc70_ziefIM5_plKJrbHWka9MUrjhM99W3fnEM7moFeo4HwvUwtX6IW0ThefSCNQdtLJj8lyfpuq1Dshm-v21rLbsWnPg-kDFbabxKj3nFTMOsiGPnlw6gApzv0eLO5xAuE4wEl8QJ1Ci_IDPatE1bZcWBO_QmsfrBVazmJKSpy6kMDCCxsPdt6hPs-llW4VfLFzwzXk5acZGgbHwqSzRVXpq3hSlN32nz2yoN3Gb4zW7yNAS1LJFBB7JI1tbO_SmNV5CI1_0sbhTrV-_HMBuTMjbqUI3NNZUw7UV7H3d8NBE7K2LpMMc3_Qd-U0ww6JaMlkm8CE4y5vRppLlyObhVJ5Qak9vHsBXgOUNJ5gQlXknJfNMu2ax0Alweoxw1iDzPEGtqNIn4XaJRtStYAmkfHKNxa8ve5JhplyFHq6ccnSFEZjW7jsQY32mo02Efmc0dBESKsyNJJd9GWW7I7rZVhhvD4FFGt2rOrQ8ts8bT7ZjQoPRM39GC7OEwr8vbIQKbtGDMSRpJFvCTATegGWmQSlQje0LAuF9tqwoe2CFc3dDnCQ=w816-h170-no
Una vez que está en modo reposo o apagado podemos volverlo a iniciar desde el mando a distancia.
SISTEMA ANDROID
El sistema, con un dongle USB de teclado y ratón inalámbricos, arranca en alrededor de 40 segundos. Nos aparece el típico launcher que suele venir en estos aparatos, con una fila de accesos directos en la parte inferior.
okNxbM_7sJ90K20H1har93cGEYcZPD-_bVnqD_qd1DaSnDiytYenfUtzLjmP2Sdz3jf7GOxDHnBazawG8RMIKg6-Uu0FvV4mJXUFt1nSsTBci7fx-UfGRxbJ4gtu3DweMfpWZvp0NQX20PWllDMqtRP722PIknjFWkaa2Hx01K-G_cvTkVhpRVO3GUR7Lqlh188LcNgkFs5kHS-EicIW60ATZ8VE4gNispI_CaSSvFVfiBiSrMcyWF-jXv9xQM4T5m5vQxHsYDmIIA7DTij3xV_Ab3ukwuqxk9KNM2VecFLltyfe1fwUKGrAMEzEOtWymo8W4Qeez5jqG57zEU2Lx88AnKxTpcA-edfRrWynpxlE6tw0yyVoswNf8SAGtoE8FXge5b75fWzGigLtMCSfgK3HiSGRxGJuVeArgd2aqi3i_XgyokgIGi4jc4_qkUSBCYMFS7egKfwhydWFLKN8fqb-_XmsqlDUk3L5wsHYyOASweSSScGbavuBhMdfCMECDqyPBoSOp65ngTRv3kVRo0NBqWhuGXsaI_CnQYI1DSC6t7zFDwg9HX0ZCoGxgm5hUW5fCBpvSSHV2MgHglFNSxt9gnARrPZSm4v5x8XovY5hGtJUpi2duC7rnk-zcphdttWcmmeKjVY2OT0tNy2kW9sn1aCjLYPhzXaZwiPUlw=w1090-h613-no
Afortunadamente, tenemos la posibilidad de acceder tanto a la barra superior de notificaciones como a la inferior de navegación.
E19RDfazgBhx3Z6OsGKXlsdwnbbXaF-Mm2SDSPkUtNiEaBpmdMp7e0Vm0d0XpTiRsaZTSguAf-BEMV40Bp-fDVB1xUEtRgEBgmWIbfQIl-pDcmwb9HibbPCwLJk9VKAeGQ3f9D0BcmJzq6bs1ybNihvueYfTX1d8Wbl6OsRUx7hiqqDfbpGEUn0cKucv5qys7tZHjbVUs8C10DJ0uoOeC6JGZD29gsuWPsixVFQAI2GiJ-EERP-nwmPeqghTjr9rOKR9gqk1P8rgHnPqGUY2Hz473OcRthcfw94BGTHvY726pleg5_JnF1mhByTxuZ363katvreOSVEHfbp26U8c28JeAFj7BIziNlL3uesplxAzFDkVwK_sgGBgzR9_1sgypvDLRp14jUg2aLfdIMKoxhmugWAREkTUvXAuTEH7lWiV71-wxkMsyHPIf18q5TYPeIcPt0Zs9Hoip7y-09rcfg9dw1ZEn4M4UKN3c5b9f-V7C1t3MzZIQx5B7eEySbp2bfAFyb4qqKnv_9FqaYzJ4ajyeejmCIGIUxcgUU0q1RA5H01zJTzVNSmDKa4e1EneqJY1Dcs87uzMafLZdpVf__ihWAMiMxC1rpyMQwIeSU7J5ovtNU99e3_sz8mOOWsCmeTvvybrRGFXf0j07tvzwks1Jf12yGlWLzTvrQ2bjA=w1090-h613-no
Tenemos un menú de configuración muy colorido.
HBu0OhsWRmpmvWdujqNvMuvMTAYiB5SmevybiQA3t79nUSvSQNp7d3I3o1FedK1L-E9BOqJsVz-DcmIuks58TOnDUl5ET4CpS-0RunR_GTHFZDF6VT7e480miryeJ2-5c5t6yy0QnOvu50H7Zjx8lNjwsmzmM894srvuF7Qeya39kE2bJj9wEUiq_R_8OIyR0rBT3deKNn6Ln9VDz82jr9jgtzjm1DUZtO2xj8oYrmhhntU_Pn4Gxo3Ub-B77s5s1MxGyfhFkxOGWuptjwOz09XR5MaGebvg9_iH19YkEjfiL-IDcsqmZ0WcUm62eCb2CwUqa80fdpQz9VHTPyLzSOkb376icfl6fUOn7FQ4vLpk8qsSZV-12azkrXIkfKKAGmYhuhpVKKYiKn7uVQAdYURGcSpFkhv7LF2qwb1Etm1KKT5xIrGP-In2p6iZYUtPElLgsncK-4TGnY2M05lTUuq9APqD3iTxlTvoSelExaHwRdYwmEeB25CALsv1k6fjpM7lPsYqzh28TSx9U0WlQQX3tACij6Z3mncD7XByfOLQVz7obLfj1YxabN6sgo1ND8La5b9JvwXWYeQ9mUcFVHLgniJc6CvnO9Wowae5n3jN3aFtaEfGaJhnw9BwhtHYZf5NsMx06EbHcsUaUyJOYA-K9Eww68tCzjP2ko6hKQ=w1090-h613-no
Firmware y OTA
El equipo viene con la versión 6.0.1 Marsmallow de Android. La versión del firmware tiene fecha del 10 de abril de 2017.
UFDIfIMJajSfNw6nssCt8GYymy85hH956bspF37zp53cHK1mREQ6gCwoVLy9giii9HiKb2u_9KsAdPdj65Hk2ph2gZaBjewNGEaQdjLuZGiKgagNRQNgD8WSuvSrmofxoyDeOKNeRhCpHVlCOS8EOIvXwj_Sgl9YcMmD6TsjgamgxmEEiQIPD70qjjHejePXqRZWkbzMHDoypGsfWnlNX2wqpr-KjaAEI0x-nDkir7Ghz8dCFREsFjfQT1dESx562SqU510Bl7uz3ryb1oUKSBdeqS0mX44ZrcD9RebqTQPbq7npbHhsvTXA-dS7oBY98ZTITfa0-7EwU52vn3xRiC1SWIuGSLjrs5xQl2jbEH6AYke83UZVQm-_ETHASIlNHR3mW0n31vJ3RP-ntvxzJ-Febe3oFew0jPY5o2gOkQ8eDT9s_mAWVkvlQBCBaxB5Ls4aBe2ObH8-swtO4hMbq2mgPYs5HXwhiJXNRN-qRZCLC12vVJI7JSp65qhgQwkL5SYvnvwjKpdrUCPZpphi1sDCZjD91XRohhRP4VmsLaRP-dxUvcMh5bBRcEH28Z8WCXOJEYUUNCEIyfDIYejo21ExpThzHeTd3nD0vVC78LWI0OSGRgIt0D9gn9x6SOImb1ptOgHr2mbCPqSwLtU2FkONPAdYuy4QBA3rSo7Fbg=w1280-h720-no
Hay una aplicación destinada a las actualizaciones por OTA. Nos dice que no hay actualizaciones disponibles.
YDMW5YEYku-cLASsOaVEJNwFOpMkDWUUXmBMeD7J5hJdAQYlwDDzwWTtC_Z7iZCtuBCuj29qb7BmBQ55Z4VCL7nnImUFjI9w0hCmHLoeisG2itk-dt2gM0ASReMmrJYgyHe5pahm1Qcv5F20PEShP10IsxeSTrX6STlEsE4BS9_yU9g6dDxpGYXNGRIMxJuD6QzKPpu6SIMWgoRq7JBkGJl36rjyPBNh-9IIF6VnkAPs3LoW4Sey2rd9L_EIgeiuq_EnwPZTJPAxirhsV1xkdkKgVHahfMu1lo7fDvlBBQR8yIV8bzdatZnPmDmT_xzYKKXCNSW-7opWODQ-lxFqtrUvT7EDr9nPk28bs7My7cJyAILB8S2iej0-jIlkr3MAx_DtcbDlnAdAGAqF6BUIwlbi20OW-uhaCLxvLQ6I2DeFJf6ZDWo0qr5wWedS-lK4e4hP7P4jNBV67lfQrmmw9fNArejgPWQsA6fphcFg6wuNHTzi9Ch-LhCvSN4bU2W1wLtwzIDPMUSt0PLi-b3X4oa0jC4yRnCbL_lbVgWIIkVf41gpjf6AB2iRW1hiKzEclt0-yL4-c03ly7O72D8oU4M-6_B9g_g8SAs7aCe4tvhWiG8y86oITIk1pmWAnlsG8eCri33Loer9E6SPYMTw6DQbPpYISNKQU_Lid6asUg=w1090-h613-no
Almacenamiento
xHzZHDK9p4DqZ_BG7pI4bxL9qG9VmF9K_7V-dvoy8nPnUH8MrjizdtQck77Qwi5hfKIc2-A_4s7UUzTmg5Hw0gdvckulPYZeFSJ8lR1_R5Z_q_uH1TWwxZ259nVhMryxXxySWVHacM_Le-cLQIG60EYKMRGWYyUqJKfJzHmKnoVyWwdznAMOrqGA-x_C5O747hzXp2hRWAOgTg_2109A2RmMd7m379NoftiO0-r-nCxubZHCShEBu2u1VOFRmwZC5GVKAxEECmWVxm9SdY_D47wrKKsVobd4Dc6WrEA4JkukfGVF0-pfLsz3jb2t4qzgZGZ9CYoGMjaqdP8iS0QWaOBF4P6Eliu6gW9_EEA8Pj3ty3C_Q6_0D7z5j3JHzAJfQoVN4_Y10sRgUxaI-EEYOWgaWzKllEU5cSmQVYS6SDZNsQAgIyPeY7aq-TYHG-LHaJLwWFOafUOSsowDCeEPqM7R9YYfPuBT2tCWbdEpEyZNX88gFwIc9QfO4p3kyA05HN8t_XU4WuwOpq0gnT2A7LAzAzkCnxaJV8NzU3A4toPYZl3sYX5vjWXy3EVowi4CSsjsNj7g1nYVJQRfp9jQJ5vjxsxEmndsrPuEU1ii5a2YzekLuasj_q4VRbxSFCuxrCc47c6gBqNspzQI4dPL51U3FaDJtPuV0nL8f22Keg=w1090-h613-no
Aquí tenemos, junto a la memoria, uno de los puntos flojos del TV Box, puesto que solo dispone de 8GB. En los firmware de los equipos Rockchip suele ser habitual que el espacio esté dividido en dos particiones. En el A95X no existe ese problema porque tenemos todo el espacio en una única partición. Tenemos 5GB de espacio disponible. No es demasiado y no podremos instalar programas pesados. Sin embargo, para usar Kodi con los addons más habituales o para ver contenido por streaming es suficiente.
Salida de vídeo
Este soc de Rockchip, como el s905 de Amlogic, es compatible con HDMI 2.0 y soporta salida de vídeo 4K con un máximo de 3840x2160@60Hz. Detecta correctamente dicha resolución.
vSphShIFR1JPpwG16gNbLm_j6voXSL0f5_cdbXM3gR2E9ME4mcnU-4cxWZ227RueuyEiL13-yNuKt4Qvm1j8QPe1A8I3mBzy2gAO5RvO0E52dfW0AIfMD1IPoTHDboyvPtAcZDstUYryykN8nzr0MaYTMdPrHhyW-yBi04xNCbhSaoW4lKQarfwr22DqmIGTSIeWX77Stf9_ambq8YuGRIdds2xtTsFsuza6eXWVN7zLdWLcNSyBBVf8JMaWgvTWB-Pu-er_zQyD5Bke4b77wso3DBIz09cvjiAXwIef4z1Pwx-4jGBACoYlj6qFBKLMuxTr__WhsvezWLul1-XwZUcGOd-c6JdmH_m8kzhTvWV3ej_hZ_tWP1jFr_6edwsFy1y-Et_aqT6goJPuw-yzRAdsTLCUSA9ODrVIStdpGbCNsv4u7InR5EbHy3Yn8QsBaI3UvLOma6VdKIv08BAHpyD2fE9XeNMsooP6Jqeofd2728HIJtsPZ0GLClJSKzh_ck2lUnOMNCQRVm8xDw5bTfcxotd5s5DMMC4OCQb75b6JGfuP0dqOl9h2IJsQcJEoA6-MlPlbmCaZBzjvA3hzl3dqUugEos6-2ZZyRqeuzNeo9bXw4a_9-yD90dn0_mRgL-4skKp9UdY-YfK05gc7Fi_EGUQNRv_t06zHGiRwmw=w1090-h613-no
No hay posibilidad de habilitar el HDMI CEC, lo que agrava aún más el que no funcione el mando correctamente.
Software de control remoto
Aún no hay aplicación de control remoto disponible. Por experiencia con anteriores equipos de Rockchip, es posible que en futuras actualizaciones del firmware acabe existiendo esa posibilidad.
Miracast y DLNA
No hay aplicación para hacer Miracast. Sin embargo, sí que tenemos una aplicación para enviar contenidos por DLNA. La he probado desde un móvil Android y funciona bien.
q8H_O4Gq8Y-TxGleFU7eB0Jl2gi3dkMc7sxiJidwA5xLk-MoAWGeqDoeYy4RpP72KprfH25M2-T0luxVwpOoc8tLhMmmM98fFhrAwZ52X0j8tfU7hJFBaOIwEI2V9FuUOp25r1EuwnPg-QLWVXWpJueAVFksuino938XlCC1vPrDequdie7761LiZU1y-Gk_cpS1LbTx59-sidcbUknuUfeLxghk9V4HgoHwFRduri22EmPEigxi2DA83SpsensxZWdYoTFkwMVCDndl_l_Pjmdo6eDcKvcSkbo28e_TFTR5r7vpuZkomybSSs_PARees9WmYt_PogJIRZFHVoLFAB0IBUgvhNSZlHsw5MDAVd7UqJvOlwbXOjKz1tuQGRMfjx9ItdGUoZVvTlc70z1HM32LekULtwbmt34ksNmQFLB4ocp70pHa6bEy4_0bGUwReraMdBfC6aAtH1Nn2GGt5azwGIx4Lter3KcwdQ8u0KE0d5p0baBR38OvAGhaZPXxAYdwVpwG9-kY80oKrQ7UtDUpRITWXFTD40f7nXXK9wT1T0_gCZvIvOCGx-hfP95NkZ4E5Pk9qmh_ISAMwmxGDbAQKux1ePuc5dKd-ml04xhpLK7tjgRktITYUnAqx0g7n98e-HcS_5SMxfCKuQ5LTDSNhPQtrCXHFmwbRouNMQ=w1090-h613-no
Root
_z9ocLLH78oROwOgfKt2BfV_fi5qvJqpwfhbU193yHfDFB6nOb60dN0kMHIoe-vlhu2PUQ-ury4FjGe-WsXyft9OXEe5RRFVnZ2HKBgPFpFPMIXDKKWEqChQOsgz92CDCjYeXz0ZiICkMEID025WhJaZTeEN1U1_4nD0n2Ery0CbopAZ-avhvJUJzZxf3HNVktchInalWRvJHJ0nG4LxUgTOjb2kxhFW_Tb89eCA57ilJIRyo49ltNF7JOBSnv2nRSiCchaCqUO8ZrIZil9M2L3Blwpv_G2p7pFqx8ifcQrnMrg4FtwvOjShfm5bWFMLTWifXyy994l6U9d_sIHvkfI4R-e1RHKui1tWrUVjmEjPlNULBBxtZXryuO_8DM2aHIC1pmlRI_qbvCEB5bNBdGtt8RXP25h8qJ0AL5hQZrKtxbWGxEtss4PhILbXVwHd17646G5jylTzOFrlfRC2CRjTw-PBAPcHK8C54OUm5fsd5tsQ9f8nqD0zruW6Iu5xVXIPI8kw898ZVWJAOhADXlmoh2eanmfiAWW_G2DczLFF5wendnf8K8snTaaGJ-dPNZrPQ7ClJ5xs4Goim9Bz_IuKiqtYWbOzUx23O7tNDE32OJCYTAenYUfOXTuelapJuC2EDtG9bJ-OhkuF3yWL3MMP7LBX7xYnervrqyqcWA=w646-h201-no
El equipo viene rooteado.
SOFTWARE INCLUIDO
Estas son las aplicaciones que vienen con el aparato.
lRTNhguPbGEaMyFPISmKvDsaz1tLvPhhRLyRhkZHnxLw1ruoOb7XA6UJhSzmHxFvacVdVFP1qksS40qpe2JQKrlfoLQ5sIW8bkzcU3k-DTP7jlUoHlP3jVdsDFniBDgmWou2WuklYp4HCQUk8LIlpOFtp6pEzirtW1QRafFP-__-lIl2AROQ9j7iOrt3Jesw3BbJQVqEBlGzp84OZPcuFDEu4yxbQlFZQKxG60z6E6HPHaTU4hTb-s9T0GE2L_MOT9oX2IBl7yyuKuEBK7gv-LlukvGNr1jAMD3RxmzsCfbw7LUlndMN0nXkMxosqWsk1Uo4WHpAZz8ConO-qqPPYyLlxh_yZFBFS-Vh-Ct7uZkbk-O2fBj3-gPBaMBMyrRbi7WKzRob6XanCq59C01ks1YdeSC0d5TdM1mx4MMCqfRCwoWP4L96NJc0Q_bwvco6H71bUxvRjIYEPWjHoTBwiO7r5o_HJ3rE2yJq3zt0B4Kzqd3K8aFxjzdBmLD5Gw_Ve_nhlezkONIpALy5DOY1ULAQ0lKB_wbSu8mr_6C4A-aiLwY_AQuL3_AqKjzy9QI_aj87i-6ma0RNhir9nKPCzm2QLSLR9ipOXLfS40mkEAxfXmglCfc6zBUQf2fexmz1bectRjJ5dlKnWnnaO92UKC1CdBYI40lfcux29kZxxA=w888-h613-no
En cuanto a Kodi, viene instalado un fork llamado TVMC que realmente es la versión Jarvis 16.1.
-L21e87CGHV38hxy0fnzXRAkfL4C4sa_cs_H2viFitb9daukdXncS97_5_ElN6Z-GiX1qesAS_P-Ykjz0lQ6MsdVANXThl0vt0Jl1AHDDzLaGHPxuBRVzYmjp0qSis8_C51vfcT8EXHQoFkkGZiWmoAAbSuT07BkeaEZMxyDk8MGE25NnIAV-ckaVL_j4F0I4mcWK0-KaxRAak0iMPvI1imngQzKbpKqqpDEvuEbE3CRDM9hK8f8R2D4jBZ5iQ7YhZ9oKF010qqHfH42XEmsFtg2EZVaucEasepnY0zWcfBCNBHrxs-NvplUZrZrIovi0nL5c02TFNpBGohQfgdoT95S-xtxijOcLCKlEEEgtmywgevZdtf_ZPyMS47KsaUGrNncgfx0SfqxNJWMZL2NhX78vbWnh9V-R5nDm2vICh60GTgrjSDJ0jHXkxRARHHyMphpQHM4wFsq9l1mxB5J7ahbmX1mY-_X4DC4ZIrHVxeWGpRAy2rma5Uiqz_NcnZ7vN8oW7TCdhWYCm9X18iHbi3WInFj-eErrCEc8b-F1eSl_ZOISVmHuSoYUISTiQzrKYZqwSlYf2J7mkmT4oqgzGEfmfm-CZANWFMqiOlY8w4Sb_IyDHJJ8047gFCXERaNYJ5TIhMnv2YszeRObn2IUk7QaFLkCrgZkSaZgcZUxQ=w1280-h720-no
He probado pelisalacarta y tvalacarta, sin problemas. Con Quasar tengo la sensación de que el aparato no llega en cuanto a potencia. La reproducción no es fluida hasta que termina de descargarse el torrent. Es posible que este problema mejore con alguna otra versión de Kodi.
Al estar el equipo rooteado, no podemos descargar la aplicación del Google Play. He instalado el apk a mano y funciona en SD,como en la mayoría de los Android porque no cumple con el Widewine Level L1 necesario para la reproducción de contenido en HD en esta plataforma. Lamentablemente, no funciona del todo fluida que debería y tiene algún microcorte lo que merma y mucho la experiencia.
7Ib-dWLlidCwYfylXXdanudKVNjTTKA3U0mV6PtfHm3LKVWs9_AA-6wXopTnSSrCDgpPvukCi8fVPo7U5eKlGneLPLl7eZD-V3b8qm-pQsBPHJZyAhPB1jiIvAgk0CWeYDKk0nXgPKcY656UDH1FtZSYq8rSY4ri2UsfV4UVUndZ613CGOS1KWjutoCGwkxTx0KIVbHZ9WSCJgGMMR5e_-EQ5Sg0y7Uj8GabLA6mw4-Flkb6_uEzprm48HtWG0MGa6_fjNxOpmlWG5INjCQsU8CwL7Lv_WmDyLQuNRAOQ7ZyvfhSFFmRLhZF9YZwm2n0km9O0ePmlg7hH9bvIPDK7JdmQqyWDGoRIEvXpc2Nqhy8gxcBf4gRGpFhpvDZmt5OPhNgv4hyq0l0fuqq7swDBn8EylUij5XH2ZPf2pt2j_g16kkdEEYbt4Zda5Ym3OB2lvTN1Yzh82uC4zWzNSHENdzD8WMLul0ibfGyT-35ARJWCZOz6jDYftlmXNGl5gzJOSVIr2U0DCcT_fKb5x7LAQbZsnZcN57JUAHfmcDjW7BbLWBQpn1fzejGepUDX8iwjpdrTR3-CeaIjgROzCGq-WMZz2KJGr_-N3TkzRqwa0EqnCVvytM-VeqZ0s6BqTJOlopsQECLlUvpZs5IZcGas56mTsMjgi7lgYE9LobFpA=w1280-h720-no
He probado la aplicación de Movistar+ sin mucha esperanza de que funcionase y me ha sorprendido gratamente porque funciona de manera correcta, en SD, eso si.
PC3O54MHTqb09Ff484NFqZIIA9oFBnlpFtJgrgGher1Ll6JAr9cJHRqqePzYKJSzwNwp-1dhXNqgnl_dE3qMS1LE__sNQ7TnZI6-j5OoULbB-yndYLo3PDV7MBKUR2JgH4EATLDd43dz3TpwVCNlveffK3OwVIJnhDG_ZUt2kEz8KAHpxoWg4yCi_R8CPIp_Oej62TVFHKesDyWgSvzfKQ-0gDyxYTiT4E_2_bQWFU2aMx718sKwgtDS_Q-VaWezvr2S2zb9sg-eUOKlaG17x1BOPgGp5Cv6xjW3mXxu9aMlgTQrRt6BfD3kYX6KlpdWZrSkLIl03Au6XYTWY1TRPeJK_Yy9IsedShhLAljDby0iQFjPwaG1eg56BvHzciMPAUrueMQGWDvj4CdsaapKcbVZ6y8SthXRp4CftIjAG1HcgNZwef1XO3MGAg7uP2lFYdMfhFR0daqVN5dGOXtmOAVF_6kY33EYYYSviYmsi53PKY2Ix3WIqYmeZpDd92qL0B9_S6Y0gi0QJqJ99GGtgf4jbDHDXdD7Gs_VLa4r7WyOC5rzaNEdiyYrsk3s6KMBl_UGs4Rg8npHadZljk_cXyhznRew6SznreA5U1VSAD8TpPsvlpCqiqFHxJOoNah9J03-9Y2UqD7RoPf4xKsqYXtiIiLzEUMsE2VUrX5LRA=w1280-h720-no
La aplicación de Amazon Prime Video también funciona bien en SD.
wCI-da1ArRchIxblT07SBRXbE6PFNBq7KULqP-0swTnS3nYmHWJOXs80FZLfjv9IJ_ogvHhtx92BsadDPv7lK49DWlbESPfURzzJUaDZhzH1Vuu_ZSGFSmz7boIr0MqyNJgbFtNB7zL0KKymxat_zTuyI2yZpOWmc__LD1gMa5N-O8GrRV-F9mD5bfYEwzjHkntTIIqAl_COmfaxPtQTqE6lJzOXoLDDeyznu7LdCt4NCcRpK1XaszDEY9e5yR3DQSzxBlKmZpMXM0vaymqswJZ_Irt7MlZv7fm32sxpaGeJmIjfwFgiVDuNOPmc4JKiCRpDzobBOV5qiBvrvjVJfjTgGvUx-Py2iKrZm88dd6vSYTCLNcSRcBf7LIb1vkeRn4rD8LkpbiZCsAP7sevnuEYGTuBW0nwRUUyUnrPkt13K9OOpQivrR6cFxRUKRNQ3IxQk5Wfoz1_K1SMmp5Gfoa1ocR-wWCn9LGgkZ5cAf_Z13SGm13aYUY1Nm5adUKXWc0AVOTG1Ik03D9ajRpqa_V2b_8bw5IRpTmJqAaxQl8iDu8gzWM5bQfNjcmnP0tjV2CSdOXbtmLQssedqyYPoiDn-qWhDSPzKUmbaa7Sda3ferVSoO4M5w1Cu8jkW7YMjHi6TCmNWkUsqt19buj3WWjdj-Mi_pUm1v60zPhvoNg=w1280-h720-no
PRUEBAS EN ANDROID
No he tenido problemas en descargar las aplicaciones de Google Play, pero si que se nota sobre todo la falta de memoria y procesador porque a las aplicaciones les cuesta más instalarse, abrirse y pasar de una a otra. Creo que es debido al acogotamiento que tiene cuando tienes abiertas muchas aplicaciones. La verdad es que acostumbrado a otros aparatos más potentes, la lentitud de este equipo de Alfawise es insufrible.
El A95X R1, como hemos dicho, viene con un soc Rockchip RK3229 (Cortex A7, Quad Core, 1.5GHz) y una GPU Mali-400MP2. Este es el SoC lowcost de Rockchip que viene a hacer competencia al s905 de Amlogic. Estos son los resultados de las pruebas sintéticas que he podido realizar al dispositivo.
CPU-z
X7j6dYCJcCJQHvSM34dHazN5jcmFmVV61h8PHrmldYJokQP00IruTXQWrrRcWbCaH05DoLIRQ46cljUH2CtOep738h--IQmDHwwok4DQ0dvJcHSv8mi-BQioC4AUogwHGou98mcNaRy39dVo8nJKh4lCki67WsPJYObZoEdFmPZZ7ClHum4KtLELVKQ6goYwYjyK3JsRr6GYCVVzAPb0XxvJ-F1mcS4FPz9PVXU03rudaNjrBx-xlHJGgrSG5ylVQQhLIwaUamRqU7-1AyDpCMjqlIRDzkVZhZrRnpaAtX5k_vRJIQ8-7ALKvLtMqVonaxwk-dqSNy6JxuzdmC0WTE_1c0qBeOaGT7jP724l0JYQ2DOFTrjyV3gVumf2GmUomNgDgEMI49EIGzgiZK7cFyY6--7m7CHwUdkDrjyrQkdPzO7wkn9wEBBYPHkzm4iCMFyvjJjh3eTqM5S1OaQY05K8v769iR-mxWtwNcOAyhO1s1SS1Gd_0JZcDGoH2w0F3gx28RC_0gdqSNPZbEY__PyqfkOSMoEQYavgysa0YU6Wcob5zuydJu-fYcdk_s3BEvZimSJik3uBfQZDnSonH4KJ8RqXA0MGw7ksTLfrJiv2O1H_TWie4Bz89FVn_OGL27lQCWD3cd1WNtHArwq9weC16on3NHSvHhxOShlU-Q=w1280-h720-no
No se detecta correctamente el SoC por parte de este programa.
Antutu
KrdZCHcDhNu5qQ1Iz65sAEGATQocPXqNyf7ZYJTmZY4PBcjseN__88Fcuun_02slLaQVgWMOoo9EsXwrwwvk4zYQI5sk3g3JC7i1rLceOjRpll9xXA9r68nLbJwTRb9Lhf2wR-HQCzWL9dlxsVjoDQMFEFkLsthJJo7pccetl8as9HUtVt-O5xO8C_0akFX9og3g-NBPHl1My1NweZI8nBvq3KMtkeSSXCjQOF-IYTFmGv8tzayBesZ5gVu_S64KTkz4KtPv23q3Xl4IcJhuFWXHXdHAZp-hcRojEnATuZi5smoQNdHsuJ17eeHzC7JyXMg4L_Oy88j8k8RBInsCRQyCvbkoiJlfGyu26NF1ojnmOmjI5aYJ7iOI6p3t-u3BDhKgrP_8F89nlMoitUc_nsKFrk_zoitb2301xIq7pCimEx1opUkF4mC_yxHh-NRPyup5mmJmBJ8pAYmNvCrAnnhPkXdc-YkkiXyDqTFRQfzkOULpFQSAjcLEiWQxYWiBADeJwk35fVWYKHoIkdJIm_4AJYDrIxaliPzvXXrZc2ugrpkqopKe1CPybj2wevjd4FUZqDKawIrOAept7kRxbsOLzY-9-kyEtRAAxE3gIr7RiXY-ROBTtEtEGCfN62mLAGkPmKIa-0Wie5AXffVjT16vNlCrED7LHzWFMRIgSA=w1280-h720-no
A1 SD Bench
cWLWZaUTT5yGxOPpcqbNW5GqrZ7_wJSpzaEwijk9D_BEyMJZFAylng5LPcT5XWXYu_x_7Wi2_ZtHVOAx1qfTRx4RGmcJ4SMiTcZHp_pL7m3IYLuUhedMHJloKib8Q7rKC2PUcR3mc0BKvsjmOf7Ygd88wBftFMTDLfpVbRFfC2_W59kRq1SkNxTGx-SYgabJk9Jl5DQ7ORe2tLr8c7lLVIBM587aavOSqqvcoQXEfiY-e1QcEv_1CLl0B_FFtokOUEsG_LrS3MqhPxkcry58WOo_J2vhmBJL2IWB0kSG8GsGO7IyKisPqEn6amLQ0jy-kUzOp_jfws_qjHvZqNcyudZilTOIS3Dg3LozGVrbw-SD2_iSPUaCZe3GhdVS4pejRIfz-NVGOOMALKsuDyzONnWzcPVpDc7IzEXPwnzTQMJMUo5d6XSK8TsQ5mN2yyDd_8gTGwfPcp5RvsYWDMxc-CM1f8FKvkuEr9dhGjGu-c1VCbrCCxRdWTbp9rcDAC5_q9QGMSAyfaWEuVMjqlPh_rsCdnfDgj5VK2cvtQExkLncAVnBvMz6KZw1KkCb-mdm8ocP7DaA5sq3RW3_f_yV7aGUn2CnBi4GKvTodFyRy0z0so-fZrAvqlz2-3wQ79fhGPK6FpY4VpE-0HYfeCVpsxvILKKbk9zR5yqJjcpxLA=w1280-h720-no
Como se puede ver, los resultados de las pruebas están muy lejos de equipos con los SoC de Amlogic. Además, las velocidades de la memoria RAM y la NAND están por debajo de lo habitual en otros equipos de bajo coste.
CONCLUSIONES
Leyendo las especificaciones técnicas de este A95X R1 de Alfawise nos podíamos hacer una idea de lo que nos podíamos encontrar. Aún así, todavía había posibilidad de hacerlo peor. Empezando por un mando totalmente inútil, que no es capaz de funcionar a más de un metro del aparato. Seguimos con un Wifi de baja calidad, para continuar con un firmware que, sin tener errores muy graves, tiene carencias como el HDMI CEC y la app de control remoto. Sin embargo, lo peor de este aparato, con diferencia, es la falta de fluidez del sistema. Si a un procesador justito le sumamos el único giga de RAM y la memoria NAND que seguramente sea de baja calidad, el conjunto se convierte en un TV Box Android con una falta de fluidez terrible. El único punto positivo que se le puede dar es porque la aplicación Movistar+, que en muchos modelos con SoC de Amlogic da problemas, en el R95X R1 funciona de manera correcta. Por lo demás, por muy barato que sea el aparato, es mejor invertir algo más de dinero (tampoco mucho más) y dar el salto a algún modelo que funcione mejor. No será difícil, la verdad.
PROS
Movistar+ funciona
CONTRAS
Lag continuo
Wifi de mala calidad
Sin bluetooth
Sin Miracast
Mando a distancia con poco alcance
