Ayuda para pc gamer
Que os parece esta configuracion? Muchas gracias, es para gaming
[TABLE="align: center"]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif]66693[/FONT][/TD]
[TD="width: 299"][FONT=Verdana, Arial, Helvetica, sans-serif]Intel Core i5-4460 3.2Ghz Box[/FONT][/TD]
[TD="width: 81, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]134.71[/FONT][/TD]
[TD="width: 76, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]1[/FONT][/TD]
[TD="width: 84, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]134.71[/FONT][/TD]
[/TR]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif]89258[/FONT][/TD]
[TD="width: 299"][FONT=Verdana, Arial, Helvetica, sans-serif]Asrock B85M-HDS R2.0[/FONT][/TD]
[TD="width: 81, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]47.93[/FONT][/TD]
[TD="width: 84, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]47.93[/FONT][/TD]
[/TR]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif]56811[/FONT][/TD]
[TD="width: 299"][FONT=Verdana, Arial, Helvetica, sans-serif]Corsair Value Select DDR3 1600 PC-12800 8GB CL11[/FONT][/TD]
[TD="width: 81, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]34.30[/FONT][/TD]
[TD="width: 84, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]34.30[/FONT][/TD]
[/TR]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif]52021[/FONT][/TD]
[TD="width: 299"][FONT=Verdana, Arial, Helvetica, sans-serif]WD Blue 1TB SATA3[/FONT][/TD]
[TD="width: 81, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]39.67[/FONT][/TD]
[TD="width: 84, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]39.67[/FONT][/TD]
[/TR]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif]57426[/FONT][/TD]
[TD="width: 299"][FONT=Verdana, Arial, Helvetica, sans-serif]NOX NX 200 USB 3.0 Negra[/FONT][/TD]
[TD="width: 81, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]24.75[/FONT][/TD]
[TD="width: 84, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]24.75[/FONT][/TD]
[/TR]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif]71475[/FONT][/TD]
[TD="width: 299"][FONT=Verdana, Arial, Helvetica, sans-serif]Corsair VS550 550W[/FONT][/TD]
[TD="width: 81, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]41.32[/FONT][/TD]
[TD="width: 84, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]41.32[/FONT][/TD]
[/TR]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif]77779[/FONT][/TD]
[TD="width: 299"][FONT=Verdana, Arial, Helvetica, sans-serif]Gigabyte GeForce GTX 960 OC 2GB GDDR5[/FONT][/TD]
[TD="width: 81, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]163.64[/FONT][/TD]
[TD="width: 84, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]163.64[/FONT][/TD]
[/TR]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif]59129[/FONT][/TD]
[TD="width: 299"][FONT=Verdana, Arial, Helvetica, sans-serif]Asus PCE-N10 150Mbps 11n Wireless PCI Express[/FONT][/TD]
[TD="width: 81, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]14.01[/FONT][/TD]
[TD="width: 84, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]14.01[/FONT][/TD]
[/TR]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif]31046[/FONT][/TD]
[TD="width: 299"][FONT=Verdana, Arial, Helvetica, sans-serif]Montaje y testeo de componentes internos del PC[/FONT][/TD]
[TD="width: 81, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]37.19[/FONT][/TD]
[TD="width: 84, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]37.19[/FONT][/TD]
[/TR]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif] [/FONT][/TD]
[/TR]
[/TABLE]
Usuario Inactivo 8
Saludos honeybadger,
Personalmente te recomiendo montarlo por ti mismo, es sencillo y una experiencia que te ayudará en el futuro a poder hacer el mantenimiento al pc (limpieza, cambio de pasta térmica, algún cambio de componente en el futuro, etc) ademas de la satisfacción que da el montarlo uno mismo, y con el ahorro que ganas, puedes invertir en mejores piezas.
En el foro tenemos guías de como montarlo paso a paso, y usuarios que no tenían ni idea lo han conseguido montar sin muchos problemas, es tener un poco de paciencia y ganas de aprender, sobretodo no tener miedo, es muy difícil romper algo, ya que no puedes encajar algo donde no es.
Personalmente dejaría el ordenador así:
Se te queda en unos 630€ sin los extras opcionales de mas abajo.
Extras Opcionales:
Ahora te explico un poco el porque de todos estos cambios:
  • Hemos añadido un disipador, el que viene de serie es bastante básico, y con este disipador que te he puesto el procesador irá a mejores temperaturas y el ordenador será mas silencioso, este disipador puedes dejarlo para ponerlo antes de que llegue el verano, en caso de que vayas ajustado en el dinero, pero es muy recomendable ponerlo.
  • En placa he cambiado a una con mejores ranuras, así si en el futuro quieres añadir otras 2 rams podrás hacerlo sin problema, la diferencia de precio es pequeña y te ira bien para futuras mejoras en el ordenador.
  • En ram, te he puesto dos módulos de 4gb, así aprovechas el dual channel que te dará un poco mas de rendimiento, ademas hemos puesto una ram de CL9 por lo tanto de latencia mucho mas baja e irá mejor que la que habías escogido.
  • En gráfica hemos escogido el modelo de 2 ventiladores, mas silenciosa y mas fresca, ademas rinde un poquito mas que la de un ventilador.
  • En fuente hemos escogido la LcPower, muy muy buena marca, es poco conocida, pero es una marca Alemana muy prestigiosa, de muy buena calidad y a un precio excelente, ademas la fuente es 80 plus bronce.
  • En el Wifi pci te he puesto uno algo mas potente, nunca esta de mas y sale casi al mismo precio.
  • En caja es personal y he dejado la que habías puesto, pero hay muchos tipos de cajas a precios similares te dejo unas cuantas (todas compatibles con tus piezas) por si hay alguna que te guste mas ;)
