[REVIEW] TV Box X96 Mini - Amlogic S905W 2/16GB - Android N
Txemoto
X96 Mini
ucQcRQcH5spvvHE4GLB28A7-naxbS2XLWA7sEWFDT_jqYmIv1coAWWSLWsHl_mPf2P1j2APkl2YLGz-nEC9PXvDNaf3YH7-IwyiunK2HtcsUxyVOcpT4AnguY8MIx9Kc3Ki8gAnq22-_XSrmcDBJ8tqNnpZbDSU89uQTRxurcVMl_kSV8YV7WNTVGx4-n2YtXUs07OaOf6iWlqChznuEYhwR_pkbX9x2a0CH5tNpGv6sNtnY88gj1SHfH9r-n5wL0AWad44xJ2x7e8GNCLFDTHI1A6S-UNnqYkJ5rMc4bkfOaHSdnuirx0pauqSyDTkO_haiNRFWiWhvN_Al5GEKXBfyc-A_Xv2FikeZ9PLZJVt3_EHjo6FYpMkvdDIRiGyRGXGichC-Z4SwqqL-6oERLROpikI1F3GADsnE1GWJxD_VLPQZZ-SMh5fV0pocFITnLM8pSvLgqOZ7rBSZjM5WIkN6vpqZlI7_-TZXdup7tLpgmaLAeG9TGxle1ewsvOwcwL2I73FPSNjy-bplAoh12PQ_PWWTrkdrSsbnOmxbhcpVtGdFfzTjFVC7szqqFgTEXPCfd2GNzDPouc0xBHfsoEOqdimJ1ccoyZslUtFSXmaXrAN_2QGWuBVRZUq9bLzdTeO6aTAZqqC-pIRaOiNiD4IEyMZYoIl0Gya7=w640-h423-no
ESPECIFICACIONES
  • CPU: Amlogic S905w - Cortex A53 64-bit Quad Core, 1,5GHz
  • GPU: Penta-core Mali-450
  • RAM: 2GB DDR3
  • Memoria interna : 16 GB eMMC
  • WiFi: 802.11 b/g/n (RTL8189)
  • Ethernet: 10/100 Mbps
  • 2 x USB 2.0
  • Salida HDMI 2.0 hasta 4k@30fps
  • Salida óptica
  • Lector de tarjetas microSD
  • Android Lollipop 7.1.2
  • Alimentador: 5V-2A.
  • Tamaño: 8,2 x 8,2 x 1,7 cm
  • Peso: 120gr
CONTENIDO DEL PAQUETE
9BfsCTqH0dtLB-uQaSfil6f036XtQtfLSCltIJ3Ik2OLE-IcwvgUyFTdwGbkhD1QPWebl0beO43cO00OiycHn_oQaG_ONQXetOXN9f2PSHX8nmvODiTb7S5LwAq5CdjD9txbrIHhUYw7cirGRUwHwk7GcbdRpnp0VCyWsWlN1YL8jcTaHeCwtE5U0pZIU71ZscvhOXJHhLgcLvXLnjz_7MQ8qW0k2ZFnE-y4BuGRnBE_pZmrtiMmnJRFcMZkcIERMgjr2LP8muLewrt02n_76IPBQcIB8svJCMgzzL7ToEsPpPj_TUqtLS_xbpTdf72Eps9LyAkGhizrgWGPF2XCk11lMM6UPLRkyXKkqyeS3iHKG0VYi-LoFP2F69sdm395PityZaP956cCATkHshEb84oKlK0rkFFqJ9bGAfIPl8ES6rOByTA0-DDsjk2EXHhgKYMsGyFpN3ttF0-IkyLO44XZQnhbNFjiN0ILWiVx30o9FK_dojnza8japl03SezaYZyHu_Y6nPdiBCs1bxxjvL9aW_42__iM3G2a0AZ22vALp_SijtTvAWVzaT-ZKVgKdX3U05bUAxucNqJEjDHKQO_6Aq4cjeU89gbXgldCbjoysl6jJfOvn8OJHd8ucmrEsi4N511uLoZ7gTTntppOhTonh3jAATuU-EIa=w1093-h613-no
gVq1mQxAljesYCKJYbLAc-XiSzAfdSbaphVw8wRRcAvRV6CRfsl8YxvDjZhDXAXWNLMNgYV8ySLcTBD9s8_a_6a319WsNrdNmV-gg5Q4uBrK0zIz6NARSouui-I8YqTDpGANZd2Yjm_0qA2i7KQtjtEcoFHTX9ydr8560j_Bn_xn-3pDWvsvK1jbajt3xMdaF228BINJftNmo0aAZFrrstwGKnlfZh7EMz5pGuOwIIyZTpzQwsofq-mRqodYKOih1pYKKItpgEBjzWTmATNZ46bRirbTSjcNYbYRtgsPK9Dc7pJ2ZUKurOo-ewOkfueqIKtiSytB_tx8PiOawzeHkeG_yzzZE6zyB0rSyaZS0FBaPS_Sv5M1jeg3j3uBFzaa21wWv5UU8UjUWhFoqxHpCXiUPgfzfej6kOGGoIHVQRJwhUAFUBuY22WPCFfRFRWQuoBgZtb4O-7wUyMW-oRwlu2e7Uv5T-606wz2udsHyL6DgTodnaShmSa4ER3smCA-YAo_4Qn8JOxf8sjBM0MwUDUaWcY_wWMdJ0QOJexcYrCL0WJgcT5IZi7wX4bQ17O3-CNDD1Wa9r28I3Mc2Klr7V-hxeM2HBQxS6GiCGb4GRof_GDTfi_3V9M7Cb2UsUxAparKgILb-pmxrpwLsCO2QS2FoDol_2Xod1yS=w1315-h613-no
  • X96 Mini
  • Mando a distancia IR
  • Cable HDMI
  • Extensor de cable de infrarrojos
  • Soporte con adhesivo
  • Adaptador de red
  • Manual de usuario en inglés
Llama la atención la inclusión de un alargador de señal de infrarrojos y un soporte que nos permite, por ejemplo, dejar pegado el TV box en la parte trasera de una televisión.
DISEÑO Y CONEXIONES
6q3BcIYvLYsk1Xy0U2p3pIFn393ujkIkhkA1rzKR1Jxt4gDpC8-H3h-lsoDQ_2s4T0x8614WZKful-4TvnrOiwNeXOdsiFtNhcbnSUnVm1LOPjWhvVf5_d0j0v-TGQ4tA6sdnKvrdzH-3yB3RKtMWB9-6WY2n2o1k3My_7K-32q8l8mWaJRqiYyoh0PXbfV8_FTTZkmmhwV4AkxVtN3GmSitDRxzG_r7mgXqusf9QpBklTm-PkvGzt0boAgHfeyIRAVU3go6J3tjmacQUuXMPNP_DUABvz2o4oAXnKFE_DZB0hmuOuurL9xSpLotqkG_xtIWHuWB6GTyIERe2G3iHhT1aS_zH9U1dzRqVBaZogtxZgTj6JCz9tOvSzOBp7QipaFOSeVs7ZPf5ksBBg_kIP0Emf4EZ9UhLyEjFa8owHJftHgyDO3U47IsUnT2iHcoHa09sgycak22ehzxzNNTGBZ_d0yuJBO5D-yw7NZjc8xH037WjU7hT7v-HPxSz9ZwrYf2CjwccJSgXIWlN9ehvsXV74umx4XtqN0yWlGcpKIplh8MW2gdoQntGlkmCJe_UFuhx0j8ntE-IKvuL7gIF_ovt11fwz4tvOQqpw5g1PpFGK7Efnn_WskvJdNhUIuEx3nB3pdCPyKJoSQy7-VUv45hzz7hOevxIMpa=w866-h613-no
Este equipo destaca principalmente por su reducido tamaño.
En la parte delantera tenemos ocultos el sensor de infrarrojos y el led de estado.
PzrzZYo9uarNl0GGk-AlKlHjycnmS4zz-d5cmol12Ys7s2wcb-3dGwhGN92x0Bi9q7VvDUPa4tioDHvwlxQnRyXoeFp_OpwxYMzxMI3kq9rZmb0m3AfNIGiCdXlaA6zcCUH2VRcgB2jmD1LsD8V-ig0InJkFkaAPybzBgdig9EosH3qXQQyZbobgJQPT8mAb117U6RnLH1tKn6ry1A1PgA7IFpbhpzlRQHtQMMJse1dWLS29r6hExgvgU46a819y2G1ceMPxEe962Bog2t6B9_MQqc9FqlKJjtlGDSAENk9g0CR5vyRdyrGo-2pGNAuswxGhgT76JMflh1SSKkfiPsG9g0eXo9GrWMFiZwNRo5pkbrDcyOaQzqZfFspKtinrexaTt_TZbIS1yF-qUXRTYHWL_IPLXxOgql4grSud5Ub2rpyz2p4zelLuijHaYfK-u0eobyOuWTBtu2r1rTkFyY5Y_BK1mc9US4vUnGSxghayPGZMpP1svxpVkvyBKts0AcGpxZIul65L9GXkIAKHnLyex8-v1Q1fseA7EwtpK9PjX12eMViUF0zLl_X7yPyA-PrRG5rYQ2q9IK9Dxda0u2grNOMJOv6P_lcc7vmX-XC_DNYRRI-RtzPLBo2IuTW0Wch9PkL_2xXjrDtF_gwsR-7scl0kpeYQR3AW=w1366-h391-no
Tiene dos estados; en azul cuando el aparato está funcionando y rojo cuando está apagado o en reposo.
En la parte trasera tenemos el conector de alimentación, el conector ethernet, el conector HDMI 2.0, el conector de salida de audio y vídeo analógico y el conector del alargador de infrarrojos.
daNCl-Wg-Fj9ymSPW3qMLZN7XiPueZVK3C66r13hCztEh7reMXhLNXjmBDPNV2i4R57wn3IKofilnoRtjVLFXqcg_a1S-yNPZ4GvegGtQkjnNS4p13JD9OuY-thvyV-7bPHQCzrKJH1mx_vmrC-6cibfQ6BwCGMvTdrqgaheauwehQv9Ckzly9bhTSrQ2ltps5TI-nGtyUBssd_0lxnYCHuy7Fxh6QQi6co8lHxVLdvvb6TjzJ0GqWWDwb7OIigg4FBnHGsK6NwG-F5G-aVZ5Ci3HPU7JPF_L1jGKtcjr2zEUp5338_EVidAkd4ZMcVAWjdqXzQiPyn7BXUuOnRu1WA96aQE1VcIINuY_rPVD_dNBlIcHADHLPE_hSmbeux0vZB3G9NlQH4PTBbAlvUs-eqNCk6lAO_mGcNcBddh6HPRCpgKKxueNkRKYVmJ9eav2agcRCi75i3DMosmJm6-kP3oSWc1nBKrmUzEIXlXQ5YdQYqsDXAHMqCcLMT7C3xFi00BszuI-JsT6x-NVKI7Ev0-4pPshU90Yn0ZhwxIAWRlehzR8v7ei8kCn0Cw5nzUnDxc89G6R00fNMNfhb9DCqFqf9kogDpa6PRJqLlxb81Vp2JUTU8wchoMjQ4_vJoCuZGhfLncfeK8ih_JksiZEFs7OA5r2iLHLciD=w1366-h420-no
En la parte izquierda tenemos dos puertos USB 2.0 y el lector de tarjetas SD.
Mw4G26x4iwD2fGxk3K8nwgb-CN74UY1v9gqgeSooRQHrJ654jeu7yRM84pgiJeJ_Rbl8kVEls7ricCwLxOaswa1-YCxdpm3sGU4h6Ew6igD9dnCQ8y7zPSzbAt2Db4nAHHxZ7GaFMLWogORhmhSEnpo4kLaOHFa6UAlYMNMWuqJqqW4jC1dRtNtNMmD_egUPxp6iX47zf8MaKToQtfoY6ft5K_5Lo5ChvYdiKjkHhioQpFQG6EFaX4YMoj0FFaT1jW6sj7W5jjFR7aVAqjQ9dlnNzMhIR29cj0-AF0VX6EiJ5wq-0UMrUnfvTIQapIuZ8kRJ1PiyT5OLqrlIHiz2jbTnUwd7KVLrgU4NbBW_7OQiPZkEkdJnM0xn4vk2SO4o9psvR4z64XXTxiVTGCrhFd1y6bQY_AWc8OHaYcFqUJ2qB5LM-XD78JXJZ_XU-AzAHIFmUZexYqxFEhM-bP3Tch3kEsepdLdk3HhPrNlYCEgp1g2Jop5nXltitAA-SHLpKmDFeWduV613eAj8qf39Usw4gPga296Uw2XIPin2xjhMqG_tq5uddKuEZmnSwdA-AhFa136ldvpN3g0qD7rdgSj4W9heU4lw6XkznWhXXpooElhz4ZEqrYd5mQ9gAns3z4hiKH2tY6tO5yJV4jhsRb_nn_QkKRsAeYyb=w1366-h412-no
En la parte inferior hay cuatro soportes de goma en las esquinas y dos orificios para el soporte incluido.
C2YpszgMgF5H6deSnY-ekbP96erHFiwrVOzhBPsjSHsgtj4j32rfLdtBU4z_15d8_bzC2Gg10vOS3a-XhQwp-jUkn_hMsY3e9t-2NS5-6WvUUZkWNpld_QJrqAntouPdtPTASsIeqnWVFgtUWT2HYaJdackD-YSp6T89svN3B_myyYS3q53bcIRD9LqQYEhczJsgHrF9kVcjKTphEp5pmxjdEilgH1InIptQpddcewUgbQt5ugfuRmn-sFmwSUTUZHyWGjXL_MmZEmikIDkUUp8e0jbdVvyQsLYRr9D4PxbZdOxnLReKcVaUnnUxscQfzibQk5soqh6Td1UgH1xg0S1t5yosaB_WVTu9_YBmrXUx7oLJSlLNthrwOqMuh2gehH5GlfaaORG44FsVAyzV3c7I3X17VEQwnLi8xEm8Zb4pJZS54H6z0f743vVn89FAp0j87ty4yfYjftYOSd22oG6_xVDhNagJ2XC-ru2pk6838axAC8A7Mtw7VsnxsiM9Z_tWOOW4fydP1IUk20qh6FJEHjcx7LhsgTApmJGg2Bc42VAYa8acxdT3frLTwlxJt8MnWipmXjhBuMXUMuT3dGqCKWWa1Vwi_AHLAV8glzRxK9vMCObEO73ExbFrJDAgyhTNc-Upq2MVYDOOwhrBHlwcV1FTLTVz0T2A=w807-h613-no
MANDO A DISTANCIA
TESMW_oTpUSzdLFUHnO3cpiLkpQRQy42o_Na193NZslRgg3T7ERGv-wqwIkmcm4qUfI1wrh0KNnlrzFY8pq_jSnsxwUOae9k0oNnJk9BOjaJuebUR9oI5QMhAoDqo4HylG_3URfeYAHcut9ywC28zHOUKr5tzosJNjmbkKccT4-AAQc-ztiJbU_kdOUU6atuKm2rxM8qCPfRsexqesv1m2f-FB1YEzORWSsaYZdXzOOLupcpoi_Ce5wfQlQk_IicgipErZt3Nv4rPRxJnwB_7ZxPzs8FGrHdALPG7-JCdtk-RuzNNAd6qcUdVP85qhGhihoSNytsVKBFpqTtQN852EgWRUq3IXAMuKvu_05UEndRbmUuQwnNTQ3g6XHjLTlKwf8VG9HfLfIefFMb_3PtXgu6_xsThE8Fblc5hlZ6J8G9Apw89g4umE---kU0em1Dx3bMhH8JtkB1KwHArS_cDnhKn9y7ekadKWUhBesfH_KvSWsDzeo9gu8i6y0It7tdGu9vdCmeN-TgQjGgGHTGIkA3P99Lb_Rq420nYvwkoxh7DOhzQAP_BSIuMpeIuqwhXHzTEnUDnG2EHpVwGzk0LobF5FnwBECIOI4vH3RVOsEG8q8Tf7-RB3H9bt8N3tnoXiE-FbWzo9SbFImouYsZ0RGwgZmdPWGye1wG=w210-h613-no
El mando a distancia incluido es básico, como no podría ser de otra manera por el coste del aparato. Incorpora las teclas básicas más los números y, pese a tener el alargador, tiene un buen rango de acción.
REDES
El dispositivo tiene fast ethernet (10/100Mps) y Wifi N. Ambas conexiones funcionan sin problemas. El WiFi, aunque tiene buena estabilidad, no dispone de demasiada cobertura y, además, tampoco cuenta con bluetooth. Estas son las pruebas de velocidad de las dos conexiones.
t5nz4FtX6Pyy6qIdztNcEjmj82jeet2EP1DXNPq7U7oeMsAz0MDYf-Jme5Aanx6QoZg-rvxyki4670ETwbiBkaF3RalUQtxbhDEtC1yQrSfW9GALXylXKc8oBzXmrcfcXmuowFwCaYpF7QnV7y7ikRt8ssJnxEHH-CTllkQQF38NfyPnRQTJm0KaqWmen5MsrRvrYOwmZkMbqVrXY-r8p069_RGjGbJPCtZAWj4-usCAp4NTLuG2M5w0lfMTJgHIinkC8fnT3oEHKq5r2hBnQCKgWagbxT2149DgkImbNZRcO8N5lEWTCIAg89V9Wn59QrG0MMOAEH5IjLw5VeBDZ4d8tThYXP9FpbL5fjO2x5QcJi5PQuV0BSQYzZttrUIUjYiETqlUVSeJVDjd55X2uxL161w3HE2ffXUZqC5_Drr1B6g_7mZ2iX97gosMnSh3itkQ9mYhTzXt3r2KeNPXwi6lpRt1xGJ-Z93TVeZMXeFK6stU1JUdExXk1PUBsVcEWrQ9XBFhXWMiYqdykn0c1rYEvzxLJy_HrIUJb1T7kaauuBkHqczlTKH3cThMNyrM5dnKJj7sUawXQ3c1nyAC0P8cB0JFS4NoAMkn0qxklfuLKkr9ySLFek08_kKgS4Y9mIIWIlF_DzCfyNF6gZ9xIQWG3aBxEd82mREa=w697-h347-no
ENCENDIDO Y APAGADO
El equipo no dispone de botón de encendido. Se enciende en cuanto recibe corriente eléctrica.
Desde el mando a distancia podemos poner el dispositivo en reposo, apagarlo o reiniciarlo pulsando el botón de apagado. El que actúe de una manera u otra se puede configurar en las opciones de Android.
klnyp2Xg10g7xryPLxvucLAi7YYZJ_RffYBQJWc4LOdUxQS86_ItO2cM1ne_75y7mrYMBP7MozCm7DY5uctupc0Ij97hbatarKXK8h38i-aMsl8kzo3hcSku0nNlEHCwpAlvMgFI4NEP0Vj_ohYs7Fc0K8oxEYERqtEMFuQ5cdPo980myoLmmvL7KX68R0HoVtN98ROovfsOYvvC-2cyjWDj3yWHUNRG08FetTveUxvEHxe7MP5N5OAfMlurLPrrMtltLWhKIyHa3IVSfyUejBkH3CewbGefNmftkotdM4pugaW-Z1W82ZOxM2H3lR7NoCnyGn_gbN-rogi4QPwtt4Lpg1gH6odYLBv4A0uf0c3CSEZDa14oVUvOAQ5qf3ZYtf8j9XxD1NLS8YElZrHMFDZtC4OKy-73Rw9ZtS_F2ScvbHwhwjm6m1z7aE6rRrAIeg8gGuONdeafFwZw4zlQI3xL76jEmXE6kua6RJa6xI74sezkoI_HSmHNksHkF10oQ5X4JNpY7Br2jBWpAob1DlUEFBNAC4pR9ADwyNU3Y7fr7mv9O-LZacAajdfrgFhI8YkQstGlr0-ajGtxfRyxNFZ7RNIELT1WJ9pBGRumyg-7SwcEj0q1kREXiCmae3ZYRuf2A_8WfEAiELqn5bQylIsBiylj_jFNtzuz=w311-h613-no
Manteniendo el botón de encendido pulsado, nos aparece la opción de apagar o reiniciar el equipo.
oyTC9qT1QleyvxuLQn09Me3UHER6nirazGTScx0LYWWUuWWZewxAT1DTT3ig5AbuPaPgYgzTAFJORUvuR_yNlXxTf7aL9CC8imC0UxYA_4ZltkKFLZkdAzqqekhr1-HvawtGLek1EsWJOV4HLgaaqlm8B-NI1x843J5bzBs0ZGUvjGrDuBIgiiQK9XXh8Zbap6KLUgE4M9toXGa6clBXeMW92sYiBTvHELRPSkzdOb2KfZ13_4MC6zZarsMBArA9yY1FGJ5KhZkBuLSbQ9GAbMAWwrU3PIUmbFiR2GHPb3owezJFjwXLjgvvSSjB89GqVtQ7m_sTIcYd45ku3Z-k9JoRNy2mZ7eJ7JKz_WHzpl1lA9Kv-g3kw2f4mv0bCIVbs4MYRJbtYTwlkGtkTAf3ZepACwC-ATZMb0mcVze3xJeHohmgpfdHH3S2Zn6P2-rZ7RxUcbkSzOwjmcbjs26VP6KEgLpJnUfvNiIycYl9bLaUsTTVYfuUksTCrmrlUSBEoinp2wqq8KNlmtZi0MX8JvFBnthmflyo7Vs7hHuqk_6Ji-fbRkYxKx23Kax0GISr7axGx2pcamwNtbAwkR9iof7ZJL5jOnEFz6FemNKZN0tX5colzeT5CNTKLr_wTtfjmeGaGVqye9TwfUcQ_neuj99PaAQ6LN1G6ZWC=w570-h174-no
Podemos despertarlo o encenderlo desde el mando a distancia.
SISTEMA ANDROID
El sistema, con un dongle USB de teclado y ratón inalámbricos, arranca en unos 30 segundos. Nos aparece un launcher típico.
ZBHTuAryuB3uhKDfae-BM1cuZUZ2YqN3dZl-ISaPbZd26VxJhwViWyTCeWqJ4yPcFLV4tfqmjx_qXaUAsPwcaokS2jNI4n2lCL_m1eJyih5cm5U1R-m9KqlF68LrbYZOqZoRXVrocu-c_2XoN_OKycvrlYvO27RrUqOKU_8Q8cACYVrQXK9R-nm35R9lOZGGkzvRwENESoo6sELMY3HFNSYEcssIi23Ie8gF4Tdg0XtvzNknuPkDZsES2gJ2omiyuotqgjdW6GvFH51UowwE6N2X4nDRGnTQrMKZgaLXxiNxxNAPvMBLKdlv7YmsGLjBf5HzvMCAs403ABj7XMmHkLT61yvBFGIi3oLTwiSUl7EHKHWDv7dIEx_xSdKVW9cY5jGJjQntYPAv6gtoPt-HLXeWnjv6QcWhmOGQFvsfRpnPyIMpbuqGQkrloG6Fx2DU4Zo69UUTfVqluo2C__Ub-YLgiEGjEjfoBS9fGC9H4SQ24R0QJvAYeM9ZgvtGf1Xomq_tez8hSqdMm9MPpfJH6oYR8nkhSY-71h089xoUobJP5hRPXS4MY7hcJZp6cpuwsrvf1027Kxr8C0tjQNxRg1hkKBL7Q56x0H86DcpHj4-R0GCgPkd8fnEqRsVqYxjfrDPVHHDVW6GGW-R98Np0LM7urCVBjN22zxo3=w1090-h613-no
Tenemos una fila de iconos con accesos directos en la parte inferior que podemos personalizar.
No tenemos disponibles ni la barra superior de notificaciones y accesos directos como la la inferior de navegación.
Tenemos las opciones de configuración más comunes en el menú típico de Android N.
NTYyqYygeeY3vDXc1oHnieP7KBblc7FJB8UdWbuqA8lcRF4SFv5hhHEks3Bzk43QOpfpqHlTCuqcONasXNwGgZ_KVw01IjC92hJRgURxFNAb6ReKu0ZPesPOweyj6rnn756NLskhPEBWeJ1h5E_fR2lAE0Y1yDFRT1z9rWGBXaYP-g9ZnokW9igVCCQdDDUvTDyDqGSHlyPzCvaRiEQgs-D3-Thnd41eNj4zoipZJMBXHe9jbXZA3q-lzGpaLTyLFcrW3PrOP_8GWheAVryqvfVveXW5FmmSyPFZm7Wph6_mshFHq23M-5_ypSud-HRPGIYqnJsn-JEvTNUoI82Q-wMa026HkjgdQOq3g2AyIba2Ktm8jyY4t_3Qmq32hFUo7Ju_ViSPxa4Fj0Oin5SdcCPGYwqyy3CkBjzCNzm0dg4urPtgoka8dkeGUPWipIwPArwF6ny_0DFkZbsIPpphQNc4NwbtwLFltxv3RQwvE61htLg3xVHo6HT7GEoksfDvPw9PASBGBn9D8-qAzeJxE93eqw0a6PlXxE6eM2KhA-Bp27IYC9IiX1pn3H8T1BLyjXQ9DuKlrryXS9FQb2t9vWk3AE5s_R2_djqX47_GkwHe-ytsmPvARr0EdhPqTAvhLxi6K1W3mOpJ27bybfzUizsdYPhiI6v6hRGu=w1090-h613-no
Firmware y FOTA
El equipo viene con una aplicación para actualización vía OTA que ha detectado una nueva actualización. Esta se ha instalado sin problemas.
ZmfpgYKtMQYobzrwc5MfzuywPWux6FE73IjOZkyiTCmOtE_CymyhTyB2qBw2VnFOOjnyif-YIUBSpJcbIuVfr4v9rcjtSsWEtXAUV6Ms-wrX28OIY6Ah01iHNWUQycxHeDGSVJhDrFQh7aJi3YPlHz9GMfKZivRTKa_tFyIi9YwvIT0MH3XfZFymvVwr0icxKi0nOwwjK0p7BT7zDtG50jUCUjkmLKI_EJUfa3NAEYKWav7cmjF3ZIr02XZJXyk_Y2W4RQ7BIp1MNUFYOvkx3COl9EcrHC8gAyxaAvr8DNR4mxOqMGRDNkH1siAw8UtJsoncxuYHC90JoYsYkT7s_rT92i5qIwMkAOIqHqPRyRxDwDxJfjXj46pftpHah78PJe_eO_Zq5A3ggfwHnYiiT8vH6I4iXkoc_HYtaxKQobU3tp8BsgFtcVHPZwwOfpze-scwusyB9upESms-OxUM5ti_ZlgQp2Y87hZkBaGoMHnYipLf-d1OzcAtKEw8vQiMpBpiOaUbQXsjv_C5dPbHMR3z5pdGXPtDOkwCmHf94MwIW4UEAkuP2A_4ghZLk--H1Vnhpyq1-SkzQcQqgFIMNZ0E1L4Vr0ZmgD0n1JHd_BLwyM9U2-oMFQHKyZyrr1tqnKjPbSJo0T_1QQGnRIYCNl2hv8nNn128FvUL=w1090-h613-no
De este modo, el equipo se ha quedado con un firmware con fecha del 9 de octubre de 2017.
_uG3fL1TAabM6mOmRpzRrm96iTXkfLQ0W0lY0mswWOlpGzI9yHYYarba4Caf-CWPxgVAsB3ivM6zkga7mRhqwJqo6HTkjSZ1ZcUDbSH4zDGNpF1slkCKF95beYkA3N_AGt4L11ySU-z9FP3qsyEqNXvKlX_mUHMId-AMkS_j4OMmhXbKvfVcMW7PUMhtfs0knXQCNC_fb4DlLGTsLRb2oqPNmlVdELzpoG9vDbW02WUSpOv224xms_pyZJZNUXgfZXZLubQ3xChONfy5t2gjpyJzTGE-uWegox_cZE3uyDM9CqvMyKi7EgZRswwlrkCOQPzGz4kTmSa5aOEKs-gqY-R-1L23qe1_1Gumbh70IMqdNFv1QI3k3BrX8PuwOMhxQywtOT9mKV5LTaS8HzqxyNy994P-Tu5Ekuiq7F1Mltn8sq7uZmjIMYDv8zsSEJsQZ8n5lCuQEj0VFo6zqHzbVYa-KgILOztYsYzwtR5aGaCHx3gFJw3cnhyixT1GUEj6Q0x8hCiHmaRYGWoOpvE2cSvJeIAPinAlTRidasGVXbIhriF6Bx3xJT179UX74OCfoflnudZUZcefrergMw802c9g3Cdj9yuqbRY-78p35O4irtB8WP-e4zcsj4vnYBnAxatgxWWpXoEcsLv6tAsimsNc6hedlotkyH9h=w611-h613-no
Almacenamiento
svfyEGQjHjeZqw6oXoxLwcsryDN-ixLKdOUqVg3IRChZNhT8_VZGCcG4VtSeL0CU6upIEmhqaA8e8aYmLpM9-zQAhziSN4iw7shUR47tsyuWGWt2bRpKwvjKIrQEtwCl4JU8bhfMniW6-8Rdc4vrQN8RommASaeGFElaQJTfSxy9Z6vPmeDA4Isv8cZWtC5veF0PC08eQXA8lBpO63FT_li-C3fQ92HWTt2wDk4Faxl7ABV6zhYfjfmQGMl2WZrPOWnJEnWBlzBbS2haAL2dpNne9fgCA3gqnkrR7pADLRGQL31LCDgD9_5P2yiMQjuURGBoDaDm-97vGif0_-AFYpdr17B8EYZ85tCAia9s_s3egTchtY90714JJSbM5Tabge0cF2w0iNHJH_R1Ml3DhcYe0fIC_WBxSQb_KTG8x35_88LbFKazHFdoorY5hq-UBYKuqWREbNUOAszwUsuCDNFOjc5yojvQLa_CTeVliOYRh_gQU6mPlGRZ5V0gQ6yVM3d7bJMRrTjo2rYSeNXgY0OkC65Fbmbkp25kqZfZuz1a8KQInPNk9N9ip-J9Yb-fjzjIbZ8lkLz9_XhXoCLS0rkR-DA-TDzPxuSKbrcuafTjK2NhpFMy8fGt9QEDYRa0HkJSXP5ftPB5r1vww4S7sTdH1Ria4_PlImoM=w308-h613-no
El espacio de almacenamiento, que se encuentra en una única partición, es de 16GB, de los cuales tenemos disponibles unos 11GB. Tenemos espacio suficiente para instalar unas cuantas aplicación, pero prefiero los equipos que tienen 32GB de almacenamiento. Espero que esta característica sea cada vez más común.
Otras configuraciones
Hay una opción de habilitar el HDMI CEC para controlar el TV Box desde el mando a distancia de la televisión. Lo he probado y funciona bien.
R2OqGXV4n1uEaQvnE8FhC8h6t30MPhvuxsq4dQYO_zf6VvxFL7_Vh6SfNfR_5KlYdtR8yzmjx3W2kfWHy48LgKKVPrl_xN32mDfwmEfRtYAhlIAVqjBL2dXZAZDvlnuctey8XZlYDGVfbeQkNyANQcbN6f5UUDELfidvFDKtuTi9FbzkHGC39zNCayM20wHu_Ur7KFpkiul1jaSUlQ1-J4M0WkECWYnwc1NTQllZfj0DTFkoiXwlQDxITNkHfKNyRvOlTMnj1fKz6mhLhQ6HvUC5A6MumKwxq83DrT3C0DkYpv1Z6shi3wWsvDg2_WIFUL-6tB1GdOfADseY7h3W2akWAIMBTzDTsHPal7BuC2pCb017J_xrXRoTxyHRMpAw9U6AnYcGAghNF1uq7u4c35dOB9SDhMvwc6EF2nuDLcwYU3zrUFeiP_eZHF_1iXbvs4aTo6cfCkw2VhKSOXHCSvdPDNg8d_htwiuMO-Pa0dUyrQAsyNYjEVUeLJINTthfKkEc6EB2GEWDt6VR0Gw3jIW5LXuxTcikNx0zL7fQjaUbgH7czqZx5luD6wkR7kZtcWJOw3yqPvHiPRHVR9H1sq7ta9Jh9dm9tEWOr73bRs9jHzp_bs6J_nmUWD5pD-hPoiljYKcFswVQl1tj43T3fQb7RBF1cFRYUG_O=w308-h613-no
Reconoce correctamente la resolución de 4k@30Hz (máxima admitida por este SoC s905W). Sin embargo, las capturas de pantalla las hace a 720, por lo que pienso que, aunque así lo indica, la resolución real no es la de 4K.
No tenemos la opción de habilitar un servidor de control remoto para manejarlo desde la aplicación de Android Remote IME.
Miracast y DLNA/AirPlay
Tenemos la típica aplicación de Amlogic para recibir contenidos por Miracast, llamado también Screen Mirroring o WiDI. He probado con un móvil Android y ha funcionado sin problemas.
ogGArV029UQnleYlD-XGHhEk7MU3x6plPPIstYm158o5rwU-XtlNIljEi482VgbnULFyHe-qPjYebNZASdol3gALRgkZbnOdb_r7NbYlfcMcu5_50-sBhYea2iK25fh6kjEYJlG3UFzSVnrZdQz40UlzWUehRQbxo_sT4aTQ5Xdd2Zg_LO0WnMtS_Y4qQ4ldz3eNog6idnJWrAt6YYgxepKKRLA3ecMFwaZnWPZkoo13J_6jz-LTTe8K-p0jxdzUwCEu1h54GrL2EMpekFuta9xchBW2n5xcUnclH1fWX9h2z7KiyM8LeWQJfGe4rWXPiYahlwYeeCYC0HuP3-Wrx-IidGpclz1PFCYddOr3W9o1LHa9ChvxQ87-kjnfyezbiXF2kZ2n-VylCuATzhzf9eYU67m8eGdxCSc05C_28gPZ0nwUDcZcuN3tzY2_SiOKX4wb_mcJqSWc_LnAgnyeksZ5icmEk6rPqPn18eNz_2LHOB4te7Crhjbro2GsYABL0WTqmkJMAiycvWsyvIVAFMNfqcJcp387lN0h-Paidn6hBedkgo8mzoMUqp6zSoK8hZiIkkqgAECKBqcboJNW9j1n8s5u2hpd8OG_D80iErwgkLiBWLGGHoMxJq75lQxSlgf7pwMs4BMyxVVR51rB9Ny9KLRd1YbBUPx_=w1090-h613-no
También tenemos la típica aplicación para enviar contenidos por DLNA o por AirPlay, que me ha funcionado bien en Android.
wuEbIJoHVklsuZcrQnGTsqatGqltUUmOVeBYE4SO9hJAR3_UfbGUlYxw0XrclF2WNTRZZkji1AJSuYr8glCY2TeqvTtYcAu1m_I68tLLGEkph4d4pkUf7ITwa0l-rUloHsRsZ1xL63On2-8DllgED70BsObR5vDinXfQQjGWsuFFxlwxuoDK1LnLy11MLUmePa6cOkyS0l9qlflduBJRa2xxLAkbp-O_JufTOrBRWTO03FjUP9fkxL1zTb6r4HxNwZ2-oxI9rDwViHaL0UoQ4OH4xCdxRdVloq7qHfCdSoWmiay8_HtmzFcb13_cecW4ExgcNJtAKZFgFVvUhacW1ZMduCzkfR_Yjejks9tiMry78KhYnadfHQzit5lGmMRWckF3Yt9UdUQ3B-bfikJ08b185wRSERTMd-usWku-XutyimAgx9mpAwFZ52k229t1Mrv1uzbl2JjidPX2p9OIYGgK-S8PZMtXA0R4-4wcgMK0MBU7oyq_6sVvx_HgAgeq_wcZatUE12BevWQdy-7ysVyOi8dgCCeCNeN5InLzo8b_fBcxUbyknsq-ElrA3FhQt3MaTnwuQRVuH0feYLwFQDbX6dlU7uXv7s7CY1pxf7GgPnE4SrZ1aEyWeqRB9qva5S8DQjE0RdIf3ZPduaA1Bsqi3EsOa5qh24NT=w1279-h322-no
Root
El TV Box viene con el acceso root activado
2z88xGQkWK5sByVPp_znBoeI3emPlFndnnWOEB3rl_hSYzJPoXbaJ29LjlCuSmpqr-8nqZvMDCGa4tvV3GGsr96srabHiTAGlKRU5BnAjK-42EoNkuTSq9YIkexQXTCAA4oStlxIH4enEml9xY0p6oRGrxhM_L75WHt8oJnGjNHRF_K1hiWYcyeYvDx5WzerDypxlkrgopTnx58vMy39e7jLp6CZh5i4adIUmCLFjyOa0Tcr-mlhZFsXz0aDUR_b_H33b99e1A4EumR3k-wv6LGpwk9ys_Zbq_J9PLuJhlY4XCElZ3ZKcWFMWJs23YT5hyznrPeFgDCEptx1a7FSoPmVjP5T80qTmQ_A8HWMgkrKqd05kqqRu530Cu9m5CC6eJFGy8JdPaSBe_-bpfxkX7rwz5s1GWcwdu1OKaXiMbcOg6Ty-8PL5D64Vs2YQA1SZaHR_LjxrTPa9oHoLbhEAW2kggCqERGrmL_huU5HXce3asc_2c-Z9M09mTC3OA377Q2BDTi-0An_MMcO_gbigXUSwJX3CWts_tQICWaBuD6VSK6-G2TKgqn8IZmfB4TPgHzCpNDBFikX21AMfnPkh2PeQ9HOh1knCdgdu1sRYtyWseEmfHaY8YUdtaaEirbynVe5C1JVtFMJdhOt2_Nz2Hc_Fm0O3pHLf_Dh=w859-h274-no
SOFTWARE INCLUIDO
Estas son las aplicaciones que vienen instaladas en el aparato.
2nKJ2CEacHTFPImA_e07T17mNznL9eoH5TBPGNtZ7YnJJl6pA3sikmSubhRL_WpAHR0bLA3_Zio0nHMVlYqci6mcj2RSh52KtDVhQEYl89be8cqOM71Nt_DtAePm_RA83h-Ne5QZZSm4xnEHCHYY4z4-giRsuosMm3AhUZRDoXaNA5Y8rUKuCj41ySMT-n_82V35wMrLjZTj7DoahXk7BtFfXADh8k28yp4ECJXvdDjcGomTaAQYrAMBn5RmyhaPDqgRpxpbWeTbsphv6Mp52G1K8F-n7FZd-UI1ZX8hCLpzkKrtNp5l5_ge3h1k5yi5HNdMtZxpGLPVsgW1G-2DscxnBg2lwcdvHBHbjt5Av_vB9zEOcq4zuOBmNj6_nvdWdcJhBlMWVzq6-LrTnC-SaHB_XHBuvPf81EjOkgiSGki0qUPFfWqy7Ki0XfjXTdN3xCVqMmO12FZYN-wuMbDATQHI_lKRXLDTjXwCX-b4uka1B1hULLNDZcUDPtsoc_kQdvhGUOSnt-DXOhkGpsh7ZU00v3EEKw_p77Gozmu6DEKwZqxpEkLodEwAnTTaD9qwM95v_dGIYYBk_JpTwRU7lUuHBcgd3f2AUJbs5xwJpPHRVMaTOCINXYiMN0dPSaZ-e_c9i83ZaO2jqZYX0_5hthiZsbU-1z8HuTCN=w882-h613-no
En cuanto a Kodi, viene instalado un fork llamado KD Player que esa la versión 17.4 cargada de addons y repositorios.
WOPuXBr0gT0NpZE3aK4EQhz0DKlqxofB0hiCdJ3jwuGwlMJww5y-HhPqQgV-x7Yh5_csYTYwZW0R6hBLEY4qmrqbhOCa6UHQm1lCgK4KOVpKx6PRTFRUe0_cU4aN2a6E5ST9-JuZxF7SpP2rpz8w2ctLLozJcJZEK9CGO8Keewb5RDghhM4V55CLFfWI-iTU7R3jZnoY2X4BSr9sXS3sOyk0lpVpe2OOT1JKjhu3rR4vBMTkBQ1h7vEcDlhzaD3tnL2nlROpBbIIElXpzbIoiZVvFuFlkkyUzEnEgW7mUqT8f6GHqhQ3cbNYtQP3fVfdNbjz7WOKeM_IqcJX9TLyKPwGqGk6Iav7GwyXMJhvKSw31Hm5YHpywKlrjQYcxq5zJTiFJ_4O-XluvImCLrWTDKH7zLMIFJeQ8CQnJNj8KDkfTXMW_OxElNuBz6AWWBQSXB8vIC2ZGn37jcRWQZ9eo8gch7ihrJIDZgZznq6Vz9H2ZedRS4QgDD2RktScmcvacMdcC1kvxaKfKfOFfTUgh08F7_desW4p3QF4O_LfYOTP6ljMoXbiVMYRdnhXGL3GzUhaulDj9Eo-_BcV476ncVV-ff9JYmQd5rafXlm5qaDIYEVtjRs4NDdLchx7IxCEBw9XntQZZNYLJXOSxmKmR-XQ_uLA93roQyZv=w548-h613-no
Se ha incluido la aplicación de Youtube para Android TV. Está bien integrada con el mando a distancia y es capaz de reproducir contenidos solamente hasta 720p.
hRqMNmsOsMFlNJYu5Flv45Oa2QNJQ5fxtJgTcRYXo_J6F650MyDo-fnrVeMRmBNQetA3bMlUL_peLhJb7HTVnh5pZ2FNvJvChVcbSyng7gi0t5eqcj5nSyd6AZ9ozvC7kvNLwcxDhPkZH9p46t-o5olw-4PDX-ODZQzGG1QRfK4SggP2jKNYTvNkXtOPJH4ayDwkmlC0UZ_Tlfr1nEwQ1Jjl9D9SkRvzIOXY2wkVr8e6Wy6Bnwh9yhLABCmjYgBDlrAxix51BHexaxpwXDQo3_-Gmb7WvigIcUAkA31s8Jy8ZNzfflDhgIwea5LgTqeDe7k0xry5U3SZtSMP_4vcz0ysZ9kRF01XdFJ5JHvOSNImIBHddOgoi44vdGqbhqtCu_6-kiL32naW2kJbJ74lRr_enPidz9i_DSn6YdG_DD-jd7OSM5v7yPyjZkh-IysVirPrrrXbyAwDqSx0hQhh6fYHPgWEU5fJfFqcpCcXklYGzKlUxRtwvzAHEjQ346LFGfN9LwEFxBP_Mfg5IcrEkLiMSRwQeD5cFFSCSqvkOA2hLnpITZXeiv8HEAECVoMN0W8YbMHVg8wMMN3gQHBc8ahmqLMZwElt-k8PbHrm-j32v4ZtZYAgPRCX8-7vHJeuMcy42YY75GYQdfJlVZWYAa6IAIGEH2oihRsZ=w686-h613-no
Como me pasa últimamente, no me dejaba descargar la aplicación de Amazon Video.
JjSsRSEG0FFU-Y4dguwBEfVrU3gUul4pLX1cRCNcAHg-lEXT8zAfK3s-fP_qWmj_MT0vh2LAh1PeofUuWSZBE1H2QHl2R_xL4bFCXu5cOYpae9U52b7FU0GTf0ZYEi2OOgRiWrDGFnPLSuW8ZteJ9S2UgKk1-3_yB-C1IJ9b9_zxuLw4DPOum1MPYy0qLIvLW56fZ8_4LrPudEBiJhGPZwo6mbwT9g0hGCSphIT293RRzgZypmQ9Qsk6wo4s0Ao6WmWtDptjaG2qJH366yctF-6p2enmwVaT6MeChuFmkNujngsUl9Rb3_mwv3hIekLTwGsqjX4-5hMreSzoaKYh5olm27lh0RDgkNtL5HHUFxYuV1tkGl5bOel2VYwNDCTojDpSm2g5_XQKa7Wjai7egnY1srEtmAgTDLnwvcdwKmzQDT0A7QFINjU1WdnR3wFHX5ADOs8W0kszC-7AqAbptjJ1LLLF_adTYMxYqc6FTJzFYdQxCcebjzgew9a7BNbxx8Rqd0MrzZJv79hdbI_UrgcSwrjhIXREo56aDOVvOImL5tLZYYMDA1f2UDi_WR8LT-qlM-UkZB74hfSXTn0B-RmKk1zOxQTDzgLodoyNHm3gi7mCnP6Vajgh6gkP609lVgf0qCn_4XGbow3hBoN-E5gCFupKRO1Avjgv=w1090-h613-no
Me he bajado la aplicación de apkpure y se ha instalado y ha funcionado sin problemas en SD.
W3xMlQEc_RYBpSwLXKQEzUYu6uCWXz1YiR0sS2n4_f7W_jDR-LL-PGgqdQRBFykSeiNmNkD4Ny5Czg7I7lsrxAdCCUG7bnMIVC_it_ZIdaxTRV5Ae4wlSuJIr1LXReAPh7uhCREW6RrnCJRQJJ393owlzlSCuhJ5NwwupJLI_kiKp6rs02Ubqot0sy4yRZY1wjfqP4adTGLIOmNDFOaVuWfFGviaJ7EQoD8ycqPqJUFnxcGDTEW_NYsk1Xrkm_hzj-46C8O9W3S3Km6is9kZAK9XuEo-Qgpg922LYAl3VBexURzfLqWxi4hyke4t2km_t5G__POCHoIz18M207KiSrnmNycyZ1hNmOKWZQ7G_JYSUgZuCZVU1g2KQTXDkl2ZqaQlb9SwZkhvaWTMse4_gn5zC2kSjWNJsmCdDoz3ru4P5qS1jfL4rPyCpMXgGC665FplvnN1Q1CyIhZ2kDdm5nNVdgTSMbOiXRvMeYVII2GQ_8ZJh3orD63OzaLW_tZEXABWOi3L3sJipg9uk91RCKzBwBZu2qp_b4uDEtJcpviAxUve5oRsgf2c8pqA6d0GP_LRZ9iK4IasbKsoxjDk9ot4Xcf7_dPYFcRZbPuHj7JKkR8Q_zon1S0WCp34mQDZIjGJmN8PBB_dM3RNqnLvZm8Q9yWErMV94lEu=w1090-h613-no
La aplicación de Netflix funciona sin problemas pero también en SD, como en la mayoría de los Android porque no cumple con el Widewine Level L1 necesario para la reproducción de contenido en HD en esta plataforma. A parte, tampoco cuenta con el permiso de Netflix para reproducir su contenido en esta calidad.
stWTUM1BWg41jB7ev3bnmoJyNX8CQzZgbwYvheVza8B-A1-AlSO3Gfi0W0Oh_6oVPoLIAiK5dE8KtaoT00jbzycXtmsiWWyWL2wndCbbeTplHK6pk0Olv-4niDxbjYiIUd4gSkWy5oYHmEE236mVy_0fxmyMaGGdXmE4x7gaqlCSCNTAJXqbhS5HXQnEgQnAU_P3iUIJu1T5QfrI1tFWvdFpznoCPmyXSxSyS9MgED20JqSBCnTUgY_Nqyg3oqDRazVBHVbzNvg3AsLf0-ByxweF8jz3byvBn5kxvut20iDVwc5KhOyzzZXbhXKTlJkbmqfVVSBIFrXNGILrmNjzDFSevzJ0NrIJUbzvDGSTw0UMUWq6vYkR2eqi6_rA6PVOrDxFD52cCH7-42XxTU-5yDQrCKHWm-N-yXFJYO2Pb_UhuMBt4IywpjMpSzu70lJ1z6QKT37NLzlbYlJKa2Ef2qpSqRljvWQ3XbRwdZ3ImGpX3pkTiHc2mJT0uLdWAM7NB0rKlgKSuqDj1nB9gErNQvIfY2JsvJyGiH3qVAj0LabP4IDGp0SJCYkb9Ch0Sd-t6cgpsr00uvA0c1WV76W9SGVLqBR28jMdpOd985RSg3Vwi-_pWdCs9QUmz_mK8bqDtVOUmiujoxCsVCxawi0QZ92__GKw6I1pkaez=w1090-h613-no
b8f8iQ4VROCooPosBaytvhxox6BWJW_QHtrZFIevsx1fYztmf2RwXucCOqhI85nlQfm1Zc8XQLZfSdkUt9zP7Fo9Z2XIAHxNTrE0cIYIXygboyQvNc5YaVoOuFthoBRRJLgU_k7Fplp1bBvtxu23RZtNgXkcFQN6oMKCQVtXsnw3sxoFpbEwrw5WupAprYqYXqNR-rEUXUTrnUoahF5SrLTPD9cDivxofm0IQn6PKuf_jQ-nNglL3JGWuyQXTXxNVYIV1hUKwBcWyCc6SBmzm8e4ewz0mDBn-V3vw7ajX74fOzwJYw2CoCwHMqu4AOWHBfAlHm_Oa2QOp79lEA2-UVyDw7CdSysUuN0Jrqy8uKKkfhO6m0aKTbweLWXz7u0KUEs0nWFY6J2Ref_UOQkdHjfD9Tn88-4aFFMwTnRN_Z922aJNUVT-69QuGQdP2u_ud4983VwMs91tXfklj8n2yboB49b7xkKIEHIdAh0i0uQleeadgAPL49Diqoah741OeY_soC4ozq4HDr9x_MGiabQQxQAi1aUgFtOrWf-QkToWFVMeJPpL-CQ8G7QExNHZsRJL6bzrjSj_7dRJz3E0QoGQCD2mfvt_xLMzSEt6AcD56rIM8oDjb0xBx9MFZoJx3eWODy4DjRNEb0RwAiqw9toy1c0BcRe5Xdl0=w1090-h613-no
Movistar+ funciona de manera correcta, es decir, sin cerrarse cuando reanudas una reproducción o avanzas o retrocedes en la línea de tiempo.
6c-jHflnCMIRF3rpStjOfLxRU05lSX1MpY_xhaiuUKhrWdIgD05J5tANlJn_NKRCFHv4l5qV61VAhN5jHzn34k-tWQxMZyvakuzKzqrgJPwXiVI64EiKgH-LgTUtEIUURSEmxSH38WBifTi6mndDfoepMZeDMi9OUXHr1v30IaK0WF1M6KneC_3vjbm5J9wSeP_1TzaWqHQEBrfWI3dCSvPbG8-_T2UbAAhLcyXdeIuouovLvWJ8RfgdV6qZlAdIJ4jaosVYN0xuFUIl7F106gS68EblENH5d6zYVcvmvo9xr3Ru6Ray_lqnnFEcpFIeBROj38YEZe1tqDSL_Ror-2kxuXPbGsSYbsZR6giQMv9X43xLHQdYIvZ1edp7dq7PeJjxv_VYDB9udc95_DEr7wZ8cWzGExZxLLPDlTCMbZraXtKc_g1JUO8skkjrhD2ZJKGm_u02KMMFbRVuL9P6X8h0JEIJpa_rnrAb8r0qKruwa96extHBF2KOhgS0uV0zDtkgbX25nQPX6Bz0ntmApfR1SK4sWbmtPkgsTc5R5eR2x1PVafukTLzAkW6GbZoq0vAep03ZYjueVe8L8D4WTbgp3IQVZY6963TfTVdGoL3MAzJ9B4MRLyTrHhNKvGe_JDT4fy3-1tZ841UisveaYN9A-ITEhJPcTTXE=w1090-h613-no
PRUEBAS EN ANDROID
A parte del problema comentado con Amazon Prime Video, no he tenido problemas en descargar las aplicaciones de Google Play. La velocidad del aparato es muy buena para el precio que tiene. No he notado ralentizaciones al moverme por los menús y el paso entre aplicaciones es también rápido.
El equipo viene con un soc Amlogic S905w quad-core (Cortex A53, Quad Core, 2,0GHz) y una GPU Mali-450. Sorpresivamente, la frecuencia del micro viene capada a 1,2GHz. Esto mejorará las temperaturas, pero bajará el rendimiento global.
CPU-Z
vzNXhAb4F0wNPsM7PCWVSL2EzCCw2c0f34YbusBUdsFNIjXckyyTiHOJ1DGs7M0FuHO9ESti8f2YhLQl1nGhhBC4jbarmdmTUuDisasaDiNYJ5Fz7O6E711kn_xr6YChVB5Oj-6-LoBaFDFenpCX6B2uIhrBUbiP-CYxbAijy4UvujWMMZrt6L1mcnOV5_jMRfDmnVSvRAIZq-zMGigus-x1sFv5gbYXEtW_bn2L9bcps38zNcJhjiR872nAOAM55bXgaU1RJTu0J1uAH4o_Y2g6xJQfDdkdTW1vNi3LCziqLaQxogeJs8_Y1D6AMB-lLWZl2tANK26Zz6p2o4W7fswU_Lc7WTkaCaQGrvezpISlcKy-IsN479kBdeKoAnSOajULwPpYVrQgXZ74p5dhvoGVybP3TSQD8UlkqzoAn9N8ZfN53HNGV493cMtINArXuO8X_bqJAJz02NP4tiFs6xWNVidx1g-RVWIVn4jLvEVTZNtUlDZ3SNF54jj90Rr7_ZMvK0haRGijQzwkB0Cw8ajP8dN5k56eDydtouaCKzH2o_6wrOKlL7HgOVVXs4ZoDfus28cibZSoY1_oDrkPPpPBil5atOq9j5kfciDFo-_yduL-tWjNFPu1MW-nB3HTZVsSBN30MkjozfncKQU63MOMDlJnx521ohOi=w1090-h613-no
Antutu
hEMmQxi1ef_SvG4NuvxNTHiBUV2N1BQFEOMWAyLu4jYG-YmJjCsEdd3uhdjGclBHrxz_uFh-koF45RzDkLmTJ5DTEAYu2QgTfu1DpUUJljXIvRGhU3Olm11SYqM6TP4vyaBPPBdiKXfRA3_8TLvJxwAtGtxZr4ICRpoaDRrrTB2M7xDioHPDagFYDWKnYOeO00Cg1iFSyJLdCjsMcp4qmF47NcXnZ1o8xOiEAmLmszLA1b91GpjHzP5eqj8XfD4BtW-B-ggb-MOU6pMtW0bulYMKBAlMEijRywMz4Op1jr8jLNWupsRsylcg09HCe-TOgB-YPPejE9OOMHFxOLOdm6Xa9u3d9-Tlm5uhhctbwW0F16lp1UONs6c-KIam4HKW7XnY30kHDmqv3uHlEheJQ9kMMeAjMADVmLiRjfwJ9fXKaxRCFIcToSdSbkNzZ2m59-WHDZ5hrkGKzyTP-FlXxEFstvPCKXP_ZbUWYNf7SYxlNKKEgUTh7vTL9jVbEfIqi8kB3XIJfXcNiIJDbcukFGMyhEyeib72OepMCvGINsnORgJ9rEpKFKuKi7zGXZfwBkuitVnN1axogjbdUEoMGXJ-W-KvViHXgKPOFj2uymQRQgM99nTPsRvkcCyikqylrdy2Vx3WiOj2K9N9nlZc4EoTNDa7ldkV-dCc=w1090-h613-no
GeekBench
SdKfieosEL3zY0vHCnRTI_L2vNDv7_m0L-26Y-dDmU5UfXNxlQxq-CDWWhA_chksknVAH7LwPuZYcrZ8kjLOlsWaI78uNC61KDDarLWpWDxnm5n9PVyFA1_DgymbuTjWO_-TtATiR9NGct4DQDut-iBLYhfS8WfcrCYH_2TIv5o1rDONrZDQip_-hPkFbzvT4IzX9ncssOrpb0oc0m0erczO0XZbt9RM-SONeqxxka7UcGFb1OE9pNl91PWuzi2PUOiJKHcmogjmUIg8IPkcZ9EHBxhSOfpRb-IwbT2-iN68slXsqqndEYqrZpeJmrlAVG1ob_qsqjWyh-xKE0y4BxWjR0h05w7vSjCKi6e6koZ7BXbafauzLuvnyESqAzxUXOwgmzplwlnxfyjdzqVrMPZmjAFqh3MjKvPxvRrShX0AKrcl-BRxfkw7iwAbgmcjO8qofuC6p9TFOhQMnbNl5cjCXc0Z2Fwy7Sxu5K3KvpW5MI6XFdjQc2Z5ROkN_dwzdfHWJGYjXe763IdGoK5_NBBTbrGWJ9tzo7uKE_TEKU851LT4rIpZx9hzN6rgtj3JsttJ4fR9DOKfcgo6vlzlQok-IKQCg_9KS8qcSFi5bHX2TThXLg-sQzX_p8V8ON81XbTf_gwTrS7LVmg06kvdLGt69eCfHz3Y6MCX=w1090-h613-no
A1 SD Bench
ezlXt7QTLpu7ZfDLUEjpZ1GsFOxDHC78se6igPl18skP79iYHiaM45qQmGtCsYvL6LD-7YGBs6rS-QXpEKadTCHtuCRV8GuI2RT1f65hda71iQJefBEQWgPWIqqrVY3ksEqBJ42LVCKFaotWn9AaNB4xXXzHwk_8oHFgzg-ZrRlAzDkCRceMXbeU6uqDeEK83P7D9_XOA7ZiRb2EpSKOQ6AlAb0-p41I-KYkQB4H5aGrTToHFnywLxIU5k1atB9cKHFuc5DmTm1Rw7cpGtkXcx6R0ozlTY1Spr3nogDiMq-1niQvDMZ9l5hEmLrI3Ljg6ud8U0MF4iRS7pyzm8IcsPw_ZFO0-D8YbWtHvgIgyfWCROxsH9gP8l95mnsahFG1qdLq478xigxJl0cgTtUnzlJhnn9DLuF7uOsogS8HaHSXsjPInW4HqS_7y_Iez0iYso-Vilb1glEQySaDwZ8y6Ks04Kt-ib6UBHNAQ-Ss8BPWg80I9cQ-1vSpSamTENW0yJd68vGDiT0Hv0dxm-Shl8F5FEVOw_XjGJDEohg15G0MPEYQthVj0shWJuOJf_Xde43NBAVo2SIKJZCSqv8UDtK5ziOna21Xo2e9-5zyLvxiqKkqTL0Jg9SFNubFEG7G8-jqBJwYnYOIZw3ijm3G9E1NErYoA1h14jvg=w600-h356-no
Tiene unas velocidades de la memoria interna bastante lentas.
CONCLUSIONES
El X96 Mini no pasará a la historia por ser un TV Box sobresaliente. Cumple su cometido siendo barato. Con el SoC s905W se puede hacer prácticamente cualquier cosa. Con los 2GB de RAM y los 16GB de almacenamiento tenemos lo suficiente para hacer funcionar con garantías la mayoría de aplicaciones disponibles actualmente. Pese a no tener red gigabit ni WiFi de doble banda, ambas conexiones funcionan bien. Sí que echo en falta el bluetooth. Por lo demás, hay que destacar también el funcionamiento de las actualizaciones por OTA. Esperemos que haya alguna más para añadir las barras superior e inferior. Por lo demás, este firmware con Android N funciona bien y no he encontrado errores destacables. Quien quiera un aparato barato pero sin renunciar a unas funcionalidades básicas, ya tiene otro aparato para elegir.
PROS
Precio
Android N
Buen rendimiento
Actualizaciones OTA
Soporte de pegamento.
Alargador de cable infrarrojo
CONTRAS
Sin Wifi AC
Sin ethernet Gigabit
Sin barras superior e inferior
Sin app de control remoto
Memoria eMMC lenta
