[REVIEW] TV Box Alfawise S92 - Amlogic S912 2/16GB Gibabit Lan- Wifi AC
Txemoto
Alfawise S92
VqFF58OVAAT8Thv9dGJQhwXrfRF4E8uOgKk_h0JpsSUUys8LImg_H5ckvNkYDpSlsWbBVWKoO3WI-IzTdFZpmQBu2FqIEswBkaLVXAMa63saunzFJso0TycdaKLQ4_m-uTmHgzrwpbBjrX3Jgnhm6KwZHFhhbd7X_UyEH6zfL7tFipSoxKtp2fymFVJ1lXkbM7MR1-nacEAXLwvQdDY3x_hvSgrKm3gsbMN83ydhUcaZ0Lh20bMvTCHS6eWgZU-q2aUcZQys_JL2gn8MzyFYTKTKaRRT3iEQb0PXxNl8yoRWsE1b3Ob0plziJBadM0mpFm_4yzKQ-GAoDla7QDLWQ6poVUHw2K6sPk7RaFzolZCmT-MAHNk9S06VP8fDeCTTE_TLjPJTYquKDjgzoztEok4bO4JHcpGF4W5XIYdQF9smxhr3UbFnYj_wOVTEM5xklXyIABxNoVZgHFL1wzrmxEC0_un2BMm45nOtXW-V0DSjBKIFGnCQ53EOIms-S8xdG3mh-6jjsxjoblz6BQZpPInQZhvtMjW7kuQqnL5IiTncjS8ZyAL0Q4OMFz8jS5SQtO1lwLIGSCRyDaztQZNPwnYEnfILE2uSMMujwfgdCeU3BzjQ=w520-h450-no
ESPECIFICACIONES
  • [*]SoC: Amlogic S912 - Cortex A53 octa-core Core hasta 2.0GHz
    [*]RAM:2GB DDR3
    [*]Memoria interna :16 GB eMMC
    [*]WiFi: 802.11a/b/g/n/AC Aigale - AW-CM2735-M
    [*]Ethernet: 10/100/1000 Mbps
    [*]2 x USB 2.0
    [*]Salida HDMI 2.0a hasta 4K @ 60Hz.
    [*]Lector de tarjetas micro SD
    [*]Android Lollipop 6.0.1
    [*]Alimentador: 5V/2A.
    [*]Tamaño: 11 x 11 x 1,7 cm
    [*]Peso: 179gr
CONTENIDO DEL PAQUETE
PS_7OAFzyOFyXR9qqd8-0DWeyVUlwo9JY2o37A3UJH8kwJBf3huaC_qkeofSYUVAC16mLouDGpgJXEo0lwQ8v8LHxEoRA8WGnesoll7B-sC03z3VXXV7codwZOFFF6aOxf5bstWy2NCAA9l12aCMIKRDF7mHZ514sQfiFIi8I5AbB06OdeU0pidu6BODg7LvJcAw0mQxiG45e8WtwpI5g-1gOVj56pefehjeDtuk34JcYshlgMXBq-T0QXXBIsTJs9QVlRBNabz2ckEVx6GnZBidOperWWQGnaEbu1BtClAN3gaqKgcTLon5atRjMflgRQokuYMgH0uNJXFuQKD4W55PeB_77xm1DvHweXfqHAxwKXdQc2rjl-91NdN0WPV444V0b56o71Sr-QiunEX1RGOQBjhOu0HjNESRimn6oTgVs7VY6fFtUS7oanWgwqEjPdmujoNlrkT8BMAJngp4WZCJa8eq2ZNE0ag-JzyZgilUtjDECFSTof0iqPugN3QkQV4dOVnHbqnjN0XgqFJ5bcLtz_BP9V6F__eFcHroX2L1nKkClS4sU_dDEFeSwax-J_qDn01D6MK7V8iWM17fDp4j_FCJiE4e-fd-9_5LiZApOK7E=w1124-h662-no
tNMNhSYgzJ2nz20sjnsIUmkqMXgNZUGW_4tqw_I0L-USpx2XlX1qix863THZIC0yFsIqMS4betM6KUXMw-7TArzc15hhHB25QBFABNTehP3CXCq54EiK63kyqzdrIwbNyXh3l-aZuvbnQY3b5Ey_lrT66dDix8GHhm7p9FQyeZYiieMhDyytUvbmZtdUblC5SVCf6b6i3QsbZ0sqY-7EH1w3x-TE3ldRoRyw_7cfO_w_hSvRH1nDSbrAPEgWfkPZkEN5grnaO3zRvzoTroeipinhY5D9HI23BE9tCAOQCdwtCWbsC5vEpTtPko-vJ5BwWnJ6w2krwyifOtdXgloI7utJQW_tg7gT3KKUjGSaHC3tf2TgcoRPc8Zuogmb56yslrvXewOcJTAxeOBUboHGjBG0f2r3AKT4sJ2EAn7NAosJ9NCgmMht_BibR9flDgcrm5KgBxb7OFT1q86vsLtmdoeUt7uCfA1vCWToYa80ZGDIKj9oyZKx93iMVqkUGjVXCqZPPtsHXOmOHysSO_ELZ5EwyNLerKX_oURLhS1tRhTBECYSTrddMzet21ZNjl7BHe2NCaFM3WltcRLEFS_0LHFvm3qAPkV5N9wm6rLnrbuwAAHd=w866-h662-no
  • [*]S92
    [*]Mando a distancia IR
    [*]Cable HDMI
    [*]Transformador de red
DISEÑO Y CONEXIONES
LKKzWiTy7DzOIyEaktupppm6M-QQ2qac6N8iFUN44LKoYJeP_BSoI8H22EVVMqV1UWvjGEB0c9BOdoTCYnlC4lSMv8dQesT2rPuOc4soriBiOWlRVhFM1YcyQTssyE5-v_n-lWrHH4OBAtqd24Lstg1xHwyBAuUhtFKIlo5W41MiZ6l2eJ0CuJGZ2ogHuTwu25x9f6b7i5mzqZTFwAUk6FqJuCD_2ExX1-BO9_vgywJu5VwQYD6RGyfIcxWLni1Maxdh4P3u_8SOv9Cj9Xfo2aMwYBzHIMLJYbaFz0scJZ1ySqTMwrrgXDnpSu_jvwSDWGz4auYGl8KOcHlSliSCjmnbA9OhHjhV8carvy9cjjF3LvvJIK57bg7d3UW5J_1bDqYbRexv6QzIoGUDZpvgAyjsaZ0zuXxizrRJKd8--zfaRL9PLfLDdYlFam4vo8xDrtDGCA1zOR2xa6lp5ND4GbTH56_eI7uufOl5d2pbUv5j2yyvsSEYYVj_RL8G8ewH8odAGYx2WTJM7cr21LcQ7DvXjXgpgW6K1DW1C9wVRCkpveZrZBpNNR5qQR36NiVmfmQLfEwl__fhDAhDqijAiYE6XpKkDPhMzbIqayv5GDZ-5iS6=w377-h245-no
El S92 tiene la caja de plástico más común en los TV Box. La parte superior e inferior son mate y los bordes brillantes.
En la parte superior tenemos el nombre de la marca.
dsCjr_pPM5oSsOR5Koc8K5TK9fLTqQHEbPsY-YkUF5ATqqnLGDihh-GWIa9wYok3ls46ncDRG-8-4iKrc87N1LGsFmSyAn8UY13f9ws0lNmQO9m8SA3YL5_8rQUblJP2XDL71Rt2h4VcHz74UJsWqUmvSXd94Ckamc-6SqF4-sQ9CtX3qt4OC_k8XxNIt_wStGTVFvrN61JE5dkeso3BgYrPsmG7TBzHf4NgSILyeVlEGsaOW5rhorvVjS_sye5VMjRNcKvUqfnrCvSweuWkv0bzjqK3l76cUjc0n-82MKozxDlpAQybmzefoBQMSdDyvKa3dE3Wnmb7yf4OozKY4RFSgoPjrQBzg8-UG1i0n9ZGOm8MmCKRhTeJxvcNRD7AkNrRwz6O9_jEX7mZPCb8BseXgzzCD-PBUU_qEe4hQ_7N7e1tHtd6r0sLkg0u_lRTJ08RmklfPrsh2FJXRl-d4WclRzyqIizNSBv_W10wVgt4cbPmb2lEoa-EwDnO_eoiHp9F2pYrS9W9xt_5wnt51yd2Aa36pk3Qj5jD1Dxgzen5aa9zNT2NnuAI4IWe9Ob7d5uJT8TkwErGgOopNeHFCl2ylYXkWlabgol-HV99C5CxU02n=w746-h662-no
En la parte delantera tenemos el sensor de infrarrojos y el led de estado totalmente ocultos.
a7uoiCGLJsRH-KGQBRDMRv28dhrVV8Npa9WnCHk2EJLKEUke15kJV9vNgjoDudQY-25u090smxFVAu6bs3azPoBDvXC5F7c4RzFcQo6-IU7VIj9dzHE5Fnp3ArH3N2sAl87g3bwEoSX8RfTFMaWjkvxDywb7x28m15gPsdp84nlgYLPFcJDWlOYPcG84hEU6WCIDhLaG50HH1hFIL0PpOhiNmjx84ZNwHwnO_9qvIjeoRXDqcwIr7EIaT4fBGOITwvkjEulaGBCFiANMVLlvzXMfAkB1GqZeorFd9AJYHlSoukzy5J3deTWlFyJkGapNaj1NkHgleuP2DV04fgwj26piX_bFNzpTX0uoqlHja2kgPTcse_UorR76uPIZz_wWMGh_Qm5IvoZVqktKRtq9brH_ZswAvtPSPIA0egfAydquiL6bXFG81mzu9medEnrF7CZkEAuQC2JMDfjX1OZNRRiwttXK8b1okmHnBGVMBrLkEAKOfWCMopMbbib7qvVxE22gBzwW90ZM4rXA7e30XHgSt0-Gd5D67tfkEYvIxopzvq61cTQjK_bLFR5AfCuzdesLCBePRaNxx6n34glPzGhciMYqhXdFHz2PPFDOHsrm0F5f=w1156-h287-no
Al encender el equipo se enciende el led de la parte frontal en color azul. Cuando el aparato está apagado o en modo reposo el led está apagado. Es un luz muy tenue que cuesta ver incluso en la oscuridad.
9otJntFK4wT_QWWGE7R4eDYLcxYsPL5z6Kyo_G_b_NaSN-0Qi03QZA65wUvMGQrBuB7D9k-KfkzRV8FLf-eAPi39xAi8ta-H3JiZmsrq1j07-PXhKZ1lVVgHOEtrYnsg1N4DqNTSWTQ6AkuUj9YKU0medszglc4KdsS1Gmke2OfgkixNVaGgGRU-j3_THtlH41R95miOIxvXKOjQM5cJjjYpgsgtf-NVKyrb6A2rQ2n8BrgJ_o3Wc6rclLGtlR_eFtPowZYsSw4Zjqg8qkwhA9yB1W2IrCdtEtJV9Dryc1_pSfbfsoBjWozF0P-phVLm4vl_cgrG7_GiG-ZV6n3MUyT2i8JxkmBF_YBWgKf5NjbQrPiXtVmZyu6oB5AyVUiL9_ZP0GyESfa1NvsG1oB3sHmNCUkwz-U6UhtrLzt4oXiLMlP6hKR3FNau3XJjd1uYn_cluCSfVgY2Pxi52D5_MPm_lmgUJ_j0mf4qCopula1sZHasWSQa9y99KF0cGb1UyKcGHizyduXfXw5UwjDfSDbcKnFcs1apXlfUq4-UlwIiWnrtZeh-Is4wN18IdHMjkToMWxu0yHjH8aLeQZN98IC4aqkn1Zn9YJoIeJkv-VkaFhX0=w1003-h309-no
En la parte trasera tenemos la salida óptica de audio, el conector ethernet, el conector HDMI, un puerto USB 2.0 y el conector de alimentación.
_gdCLUtZMpGJ4LvqB8EblnI9Kk7Gqgs09-goOD-s179IJAmuCM7jqRPnc1ci9VnNjPcseTCrJ-y4HCwQDQ-pfxUddgNasAi0KsY-3zTfyJmrzUIm7Jn4R0-ru6BTXJ-_nBH27vgNe0yV9DRuF_vT9J0CFB0DdtY5Nr7YfYOSrNXSy1RoVjop71qek6vj1KlGS4d5rTbSGdngYt62JUkWq_uvt1DUcE_Zn-7FsrNaTK0eLV-51JUe4vPQAvP9ibHaq67KIJ6Jt4_1Pnd8zKpvWmPZGLmkWfrZgP8nQvBB3RxGotCxGN_B87ARuJDdo0b5DOgG_StaLTJiGBp5c8DFCr63-ZCA8naEXHmkChFwWAQOK6PtIiNwoe48idjSkEs8xUFVglPoB4HQHtdiIGkLcmkwsxxdY7sjDodYlfiYf_AhSPQBJvYKhK5t4YaJTHC5foSuzf0oqQmXtWbSeiTzWshwUXzlj31T1YbweORZmrQk-Zz8Eo4AjezLwiKR2vpxnjPHRpxhVaiqFt6TdLnj5oz7yM-GyUou_mLkeVLcXs8TUrwh4VTIkfCZGBE1IB9ChA2VrTvwrmcpcM5gN2NzL56LmQOKUEHLEm7Y95mWBNamf8sG=w1121-h272-no
En la parte derecha tenemos el lector de tarjetas micro SD y otro puerto USB 2.0. Este puerto es el utilizado para las actualizaciones con la aplicación USB Burning Tool.
B8LPRkcNgH5_NU6x_RpCclVU34FtogJFvIHrRYK6UI1ApiGubufLWJE2dSJr04rxyS85PVAis7TygVmGBnQBkjZrM3z0YIOuavCSRTiqLkZ7Dk68KwftjKKR35tfAzBoVi3uZeGNif7LKMEMs3YVWQOR45hCKDHYllsEquSbrAvct_Vzkr7Ek5Uc1H8JN00fliqWHelQFETVoaljdF7TAoT3zI0PDikSjK85VsIh6ocDVhowck-JfdlGP1X5T3bETmqGee12eIUOo8lR5uwMEklD3IQdeRFgZBBCf4R6u7_m5w46wPaA9ehRzWA0FHIxx_H8aJi-GxiV0Aci8Pz0yBmeHp-sv2zaBfup2VXAJgLMqI_GLqQcIrY6cR1er3Irv7U0k99yfYEw7KH7bnXm3PBeLGej_STjR5SHLkb0mg6X5PPrHXnlzUJ399R47aZdf7fP0yLD1b6LE3-2gjKdJfAkefKu0ABN94Se7gGeUwKrSIVN92XqwMSbL6gKBOVljv2IgnMG8BxRp3k63ZGZH4EczSlToH0Bz-ALMFsB5dbTaE0uyatdVK8SkTd1kIm-3tjKdwmECBORW-6lFcuNktpPyz_16gw3twJ1Yyo4ULzuj5K9=w1210-h270-no
La parte inferior es también de plástico, y unicamente tiene un orificio para el botón del recovery.
0CmdtRdg-XC46lHB6YvrDYVYvr20b5dsphHoSxrv3q-TPPuMxzwNXJPKWKZy4IXSi9VxxZGA38e9Dq4bLIhTBRVRoGupV_SSyKABEQOsBbCLQO8Yqw1i0DwlnXWegGaiFmi6PaXQBxG9O2rx3zk3HmI-FVUajObzP8v5RnCoDhiU6sWsWfnXjomIMqLSCQ-jIDIz3UL92QE0wm9t8tM0x0h8O909fdnKeGkiwcCExem5DpoPgJldxuc_WcC-lHxBN36V6lgxzB9pKRj09GCM4iL9FuunAgy1ek03uYjoNalmziucpafzN2R-S5ynn8p6Dfb0dWor13rCPNboj44Uq-Flw5JJYNqKDDBc66_zofgEy3jRl4LuUsNKx_S2G5L2uppOqwTqoLolzfK8BOHJFs_RiwagQ3Mfq6co0ZopiGRgAQQlTqxQ1KLnyx19u6eiUQ07cFrLM5cLykk-6-IVkHX43Hu8ula1aRa5xRwg7IVCSEzk0RLi75SnMqVYIJwMnAEIsQgAjCdegVIZ12jKnqgPbMIoTBCe-hqnFJ_aEx4vAf2xTRpQ4VjyIM6NiTSb1KP7VsWA934VCnt_u3TP8senGR9NII6ka3wn1lD8JOBbIRMV=w711-h662-no
COMPONENTES INTERNOS
6xflG6DXyty19sEO0rsIxueKfUtfOoxVdNvVyNaxMv_GS-b_bDRAETii4_IvwwFJcxTvSDfO6uepjJMpgUk5Y64zTFJQBFLNDPqoZUapABLCYQs1arCPSvSXOH3OYklvuELFMTplhcxlWdcW-Mz6EiOqXpVlHe77wBBcDFlKPq-Sjk_8j1kfPuit3EGOsRnuGojYODItYSXiIMSRIF4LW6NKOcMYGx0KoP9tAFpbyNGEhLtahnGq1XhJyxRb_m5M2mcu1SCG4wTAonFzBF0ye5PYA82v7VqdifXEsN2Ff3m8Sl8yv4aEs0IATn3agC5xBpsggM-W5VHybq2VTi59agQNrrlf9mgexT1tdBiHQk2hhCqhQ2RBQkcvNnVbNXcQJXN9wLPQvw1dV8b82YGIPaXCW0hjvmoItYLZKa67EZlCwH9Usm-YAwtWtL6VsQVDXo03QjD6kFRrFGvfIJdxrGT0w0fq-5ky7ggfL28b4oMKNpEaEmhWcnQcd_WN3sTlKH_pfbksyF7sxEZCJ2AQJd-ekXDz07EZ9ygbNYwAWjXOGgLa_j8b5KtjUfab2-g1ZybVH-UGLR-vgHgWacbRxnFQN7rkwA7DAIPK-MpKVEjx_ZaS=w1269-h645-no
8RURKkjeyPsz-OQSkzamnLtlu5Og_t3rVTWuVx5xTUmIUnyv4LwZgvM22BAm5PVelK9Hk6NkhC9V0JkAHSUcP9BCrr5v1PNOmG8kVjyrw85ttJkZBbiPVidLCTNtA3XSO6kYEvJ-7zASBUSOv2WBC4zeIkRYG1mVQX5nrBTePpBV7_l-AR6-ysMHtVYwfn1FtnY-v8BxAch-qUznQzuhM6LBq5dCCzA72GP4tenHXt4kR2RJuoZoP0yYGd154tLsXnMgnWBVD5d6G5uYmE-p5zl-taFwSJ9uv0vfwUeXvJO8c8qBq5j2UDhGqCUmhlo3iO6jsMSe3evW56lGJTNnz9WRCB1Z-jSueu0CJhiTGknchPw91IZRC5IADrYdeuG8WO7Tx9Tr2NHBAiFolhKejtGAySJx6i1qslLt7RkjCth5a2-cakANC2V0TR2Gvr20Cpi-lPOkMVQrxLbllIeseletQAiHGLGcFdzUwjZw8R4O14QA4fVbGX45CrpJKinHozuKWfNl31NF6-utavoK5WqkCACPNBMHHYcvKIbYW53eIf6qZnVHrnMRr1jyMzlsS5AAaYlhiexRCaM-uMxqoBim7ZjWB1OnnL8QR9LwC97sLV5Z=w1161-h633-no
Fa0WeqnPu369Jln4y3kRUkqhuEH13SkhPu1nk5Ero5NjRxNm2gTkOktNgowGRwpvhklFlQncTGl0ysoMyzVBLhV5tRkOWilh2vX5slxy4M1cQRKl3WgBZw6DKfxR42Dh6D4NSWXK0h_7BUzsPmHuUWeecoRvHwkPiAL6r6YeD-r9MvyKT_k_sERmbuiG-P_YCI__5HY7kV8J-mdSy6RB7fxxMXzXAIf4Dqp7Q-YM8baPcG0oUGBaC-qmvzFfW0yX5NS6jW-QsiPSDg5PHia1um05rLGexCJANiHtU1pibZfYYPYEY3TATaY3DQAgS8il_sPawEbw096SGr4jrtEwNdZClQQ-YvP1OsCT40yJaZ0DlIiP2gGuZEdDExqGy8EYiQy5dRnum7N0JS14xpleSBdYwAMR-ahtRIbtTX-w3RHXdZ6LQnDacCpg576VHtsG1b_b83InZS6qoXGwyzqnvV7lLqsTmrHYwiyfxOuSnFn7VLOGaNDtxLkCvVW8pwzct94blDV3b5zZNLX5s0V12a4LwTxGqaNVZnUelpRA7yprApQR5mf0WDLVKcAfEEyWe2TSCpCGbx8yGX5pughyyE5Gdv3VZoNkLcly0EzJ-jbCsS6i=w1153-h582-no
EU1sdS75YiDYVAU1xw6r7tzwiBPZpOpNMHPrSsm-5SvhJG4ptzJbrsMhjk1bnZy5Ooav_m2HzJYnc38Rf5cFPz8oMODMaa2UbTI_7TUsYL7vgt9R8dRXl3T0lmNQKa0tuVH7ZeEQK5E2n9NNvVHH7u85Or-865f6rXlS4mWMTOInoY41730f9domIaY_3gxy6egcWczbnlgh0Y9kzb0PKwNtuoIay_SM8IJQjqzAQ3hgQok5QlFq8y8FBtaB4ffsFIGOA3w1hxgUa2ATftpM7PUsQwr2Izm5nWPAttoq_bXVDqf3rwLPUsJnBRxaWjMxGkasIKCs0f59_FezaTUmdJR3gY7WUaGsf28F44QKEOxgb817qVKget1Z5WVPmfSWmROwytw7hm3JyB-e8ltAekY5H75LcXOBNCWvXSQFDHaryhqaSWsB2YZ3kR0xuklrTYHX_WbQBJJUi4yXOn07b71MtDRJUdtPj2J0WGTBDvLg186066yRT6Yro-CXT4RM5JXoVKTsGqBvyHzDOT0DzWu2rDCryc80Vv7YvNRcvS6-NNb-zDhgW0UoBiKK-52mHPDOAi6ANLkay6V-ExxtWR27WjkVzaJCssSVAm9VPWjdPLPc=w1177-h662-no
942Bk4biTTvbi4-cA_-NF56cOXO-DEbOGP9Z-7vn6zrrboXnINLCN3R-4MZIm-Y2_FPIZEtxZ_AqCA9hsa-8mK5RIdT-HtwkNzIRJm9W5F2XikGO5gAiIWHKOEBwIG8wOeGVOEF6EUUOqJq_xHP73dmcrMXQsKJgytz4MxaEzToWWxdL1wZupWlw7wOy77ida8mIUnko5pzK-2jqK90O_WyVlRNjVTl1QaeWp0JBZulUpqOgxfvbOSQi_SrLzswFxAiC7rgHFCmFmxYTM_ajNfCeqv7_EcVBXOPc8i5tHzV1ufA4uHRCkIQUOb3pRcK-EGydylH178IffeJfKRkFpu0WXHza2w3mT-WnBOnypDg5NqDVNzg2OMAtHQjH4nrIxXERfADQ-hbYHEZmAR9RreZpC7mvxxCQXXE0J8fMaMUX755W08gvInQjrUf2bIjn5l5rmQIZmapQU1XGMKQJpAX83cyjDWLTSiK6eM4ttAAhiYwCe6wmggyPlcWBWjxdlLQ_V907C1McWxr-YnusNDvJvHeQsi97uSICIeiDhGiIewJK28WdPJY2ruEmCqun1hVff4-uBY4hxbAkQ1OeQKbUizr9EaxuZDFY8JbuUx5WmQd-=w1256-h556-no
VA0h2fZcg86XcEjZb0ZlS8oKWD1YRTopBPMflr_6yCgcwCyxPXTVwkLMB7SWkkrn1pCAKVj3kTFCoJyFG2MkpVM7UQMo61dO_d0z3YZ5uJGQVx9ZljNTjSmNORm9dLbzR_WjikM4Frv3fpkd7w9CvrGaOpxebd1GvNGSD_wOH_XXzYfk3NxIrJN_5Ugj0pIEFFovMifEM8QwqZ4TqP1vde8-qawaPfd7Bd8hPmDafl6FNd78nGArURWsc7mqVD_ARyH2fGC4ixEw1ijqYon54lgofOJYl5qHS7rh2G1pNPxuHO3hwhHJ5gnrbe03s2EJ-zYAsGIslFYMPRaXexUBp_027GwAgsmsHnQR3KmgiJEsOx3Enuu1OAov3M97QWp2LSLFrZYTS6NQZBs8uK1lnF-YVoFt2mqQcF6s-3w616NcEqlY2T1KNoGqnvzlMmlkI4iaoJ5gQA2DULnRnRAhEw2ey6x2ZavQqg1AT8n6tiMD_pMl2dALQWKr1MitCbG7kno10L5ie6_5W1ei-twuEcfuc1csfnIvxjdlhmo_NO9dQ0J7-nVnPIGpkFOS4048GVVVimK3tW1DQN4g5Ldlg01IBQtcAKJwRUsnSjrWBo7mLp3V=w1271-h556-no
i-qA9s3gf-4687h7xAR51gm2PTQDIE8X8AVmd2E3wKz__Gg_IgRMhS0_NPhsSaEoST03vz-7ja0B0apb6SIR0OQ3qiyWQkXLfCvqoECiMUS6AiBnwJXbkWlraJhEbbj-QlBIpDIjzBcGVMQmMwJuwChbqH5U9WMqp3XO0Mz8iw2EXj_AIsGAAToC_0hcpWx6PcLhKUQBnvJGBYyL5T4rsSNwSQFQ6uyN7lHVaOkgvKfOMarMSBLmpEmKwVJ0UTsay7NIwZnl7TxCTow8lQiFrjkhqLYqMqsabP8c8cwCJfgKgKcRUEskxDsr0eKLDsgZSeSqO2MrYL79Cbnm0rOrBIy-3oMtIoY5wDizXvpHkcaoSNm0kGoGbpKz6H_3gPGuvEn8lZTLvvwDq2vW4BpsxvHswd0GJKZSmgdj505NgAvrO_jUuqjNAyfGNvZ2x0-_lSrulr9ukTJJU9wZ9aOY95stEdTZq1_cdf9nMJafH9zfqq_yeVJQGFdHIpdm0rxRQGxIl8Lp5_rZab1EWwzWgWgFIiTQPLHy-RNbaqbH0CyluFa8KF8R-Gpo31xGBRaYN47KgrxQKirQhIx07eoShTtZ5gs9s4lyWXeDdouV_NwQsAMH=w1083-h662-no
Para la refrigeración, han utilizado una chapa metálica puesta en la parte superior que hace contacto con el micro mediante una almohadilla térmica.
La memoria la forman 4 módulos de 512Mb MIRA P3P4GF4BLF y la memoria eMMC de 16GB es una FORESEE modelo NCEMBSF9-16G. La conectividad Wifi y el Bluetooth 4.0 las proporciona chipset AW-CM273SM del fabricante Aigale. Al parecer es equivalente y compatible con el AP6335 de Ampak. La conexión de red Gigabit se consigue con el chipset RLT8211F de Realtek.
La placa está nombrada como QII_V2.0_20160905
MANDO A DISTANCIA
87CrPPn-ejmaGf8iLnU3iyaz-ls8OlaygTFfFdusNK80LDbhFUSfHYkz8mNQSxBVL597bMf1vSPRHvH55IHsjWbBOVnGA7IEGiIfiwjbioolBZbQ3FCuYLhhgYeWkGOriVaf_zjI0G4nyIUxyxr432-9z_L5fVZrwi1L61qH1AyeANjSGFzCrx8AyGEzO7EhQWTyFvrthfJF5kW8c4sjnU_zLWiKUwCznzeAMRGLTVaZXmaONBqNQSufUCX3FxM64tsGAxfXl1Jx_RgcLkqYIfrKsVfh2n4um9gZGsV3zPN-TeX76m70t48_Yytrb2IRG_8Ahrv-mhwHaiZ6ReysjepE5B9K5c6lxj-TgU2MmgDGzESve5dArikvRPNbA7HvZZx26-_I2Z1XSdqhY5FnMLsTRQQfUPyA7TdezCQIeK-K2JJKFrfV2v_tvb3xiubNmLTVu0Q0d3DIAm_Fps7RoAIQ8r_cr5ESIyEJNOvf_sFfR-a4MsIkLqc2F2KpnKy1GGOhy7QK2OkYvRBvOUiMBLgfkW81rGhSA5vXcThijXn0Y_Mb60EQvJ_RdzJvrrrqQABDwcgDHXeXQm9PdVXjF4FphwKGI_22wEqvq7BeQwLJEdi0=w264-h662-no
El mando a distancia incluido es, como siempre, básico. Al menos tiene una buena cobertura y no debemos apuntar directamente al aparato para que nos haga caso.
REDES
El dispositivo tiene red Gigabit y Wifi de doble banda con compatibilidad con redes de 5GHz. Ambas conexiones funcionan correctamente. Pese a no tener antena externa, y a la poca calidad de la interna, me ha sorprendido la buena cobertura y estabilidad de las conexiones inalámbricas.
El bluetooth funciona sin problemas, tanto con unos auriculares como con transferencia de archivos, y como digo, tiene una buena estabilidad y cobertura.
ENCENDIDO Y APAGADO
El S92, al no disponer de botón de encendido, se enciende automáticamente cuando recibe corriente.
Pulsando el botón de apagado en el mando nos aparecen las opciones de apagar, suspender o reiniciar..
vRY_fF25xHfn6LJ2zDYwNLwgfmcPYUjkRydvxPSJ3U42DICNiJhf2FyrcNEA-Xgc8a-g1RwPfBcsv6uBoW3S-9b8UOjkHj88yJigRCxd0BtdvWwcMbAWPmIgirCrVDUQP73iG8XIF7Xvgv80izY5yuKhrHpZZhDQQzdFSY5uDEkUpi8O2R9nddax7xwTNkI1vQsqPl4Gbn0NAgk1DVbyPCb3As0BK0sRXgQ6O23GstT5CdghG8aDKsAtHgE3HUl3rJLCkc2AywuLGMooEeK8RXnm49vimRey5PsBKfw3WceVgJeSl0SVPlkyKpxD9XyaACmljXRMHvlK-h_nM78ffQPJj2bOOsNt3D5V6HvfakVa2b0g4G-KfS0ZX0Eh5Eys81wwRUVKg3Jtvn_0933RxSwRG1aa4bk_4_a-IU_-yqPhWIdLnPGYP3P8av8C2JmOtr-3HK_KdexBWKoMwQfT--cWeVfnPlWBmWlUV4sLfNucrN6EkfD-yyd2kfXYCj2yR6f3PmPrFvMyoDXLOHR6-hTK_NwYreM3f4Oh3xp8gdEL41TCZynQfBoKQRC-jX2DmXbIx36BFOjznPaDx38KeYMpINo6NXEUnB4vLf0XK1kIFdh6=w1242-h273-no
Una vez que está apagado o en reposo podemos volverlo a iniciar desde el mando a distancia.
Tenemos también un botón de apagado en Android para acceder a dicho menú.
SISTEMA ANDROID
Con un dongle USB de teclado y ratón inalámbricos, el S92 arranca en algo menos de 30 segundos. Nos aparece un launcher bastante común en TV Box chinos y que nos sirve para manejarnos bien con el mando a distancia. Tenemos la fila inferior destinada a poner el acceso directo a las aplicaciones que queramos.
ffxikUfBVRTe85tm6ybeu8NrlxgpGtHwkEXoJpoKYwtnfwq6GR8XT3D_nB7ESVIBuahixEPHGM9hWgGMZmxdX0CQMetlFULLSns3cqRdJflmBAqunXQPtfz4x2pTxupBiJqCluX4Bc2FhCpSb-mz9egQwlwfvLfM2gwvYUBnLihbYHNUaoQmuLDmQWQsskL5WgjkrAH8KkC-N0Jv4IcoD6vqbTLS_Wlhiapfba-QPGK52mnwptZwZhroZcXS8ri2UPHJs-mB6E-T-Ehwd48_bpUnq0Mw0-4O87DgeWMBjhitSu2ImtP3m_Bti9jbf6l_wJdZm8kCYLSaf6AU8YV3lqne0RFL0EoNr_1zf7VaCGcCNB37yuT0JiRwwX0ddgL_8SO5wJ3bh1UZQ2fS7iwz4Itq3cNGsmN9-RPf7VR3m9uhL0EuA5ijdPkkiOHlahdVuceFvqxRMid6jtVuZMLOAdrBnPQDovvi1prjohTSkLDpwZJUqV-_5d6O-FqQBywbtrfi0PfookrqEKopsAy_b50qFB-j8950wi_gxJMXDJ4D7F8QnP-RK9zhedVspkFSv-na-sNnCmDUNZhOfJoMFy1dQABeBhCoWIcdHkHQlDikCgNN=w1177-h662-no
También tenemos disponibles las barras superior de notificaciones e inferior de control de navegación y volúmen.
_SLCN3F23JYNw6Uyu0QkJsYnIWomgM9d61O4TLXO_CnpcSjcUegiK9NMXuGUtW5WIlcurVXUulw_EDzhHKj9llXc86V8GCmmJBAaa815KyKvSO4OzKpFJjACIcyffz86znkU8CW6wb33sczcQlsEhxJ1Gclm_3nKlcpZ1DiQYOQ256cPVLDOJd7kV9QsymW-3VBK6lVWoZHQIXyl2_HFrgFpoHtQbH0Y6zeDUFZdEC_yKCyEvLOTX9q6-TN_DRO5DUlbzmdBBb0HqFwEzRy1Mt_dRjqvyhjiUTFMC85rianYtJrenw8Ku2Z_tFLt37IvsqDYkfJ94m6RzsTWjjYsVSolJ5loMFgRrgs3lAKbg0pahPQ6hZggfPxhUicxVl9KSQFMrbXz9yGXgLVVOjwjnCMFOfjLgBO5yxqYJmyqekp6W23YTEHtAhf4ixaWLDzz0_tY0B7k6KRYvA75Rs-6UOXm5uK_GTJJzqRjZYL2ykg2DzFdwdMAawQi6Io1XL5QSxt8MaXkbniv8YfzPiXak5HdC3eT3v6HKExb0qfSvVbqyOlBvDIhEiUT1BM4t1zFYiIrODKosRku2WrMeGUOCu_KyrIVORQXNlmFP66ZD7iJCBEA=w1177-h662-no
Firmware y FOTA
Nada más conectar el equipo a Internet me ha saltado una actualización vía OTA.
kL7JMAD2FCIWAb8xPEUHX8DGvQPQnLvdwvVRuYrD323Dj0ozywJjw6g4b2oE5Mt5S5pi6OTQbVHSghXTp9oKYmMt8Ur8CoAWrtjvXz-DbbtZDiM_ymqABV2TTyCnUBoHd5NZNVJPgcOvjRHhwxJh_YyUk0FLFuTAT3g9JpY68X5DeGisVmeahuT4_iHhDPay3bUo_8MC2J5BQvDtb7Rt69MyhMIRHkNh1yxSH8u-5IVwydX5L0KWzVmZNXxgaBr5rkRkbPbEqE6QOn6V0eqdCunZDLJUrb97sxWS2q_oP771ZGvG005ZcYJ2927ZaCmp3wLCbf0hgVywqZJue2bBm3OPxB0-NTBPHl7ZXYPK4zcI_8GOuFhfD3ohvx4CUjspEjqF-avJe4vNWo0q7RduqP57L97rqI4w_0XdKQVV8n3UwZ8owYRWzaX_l3e7i9QfoYuoxeaOJOex5RZ_VxFOfCOuERgFlvamJ4Rqj-ljOB7ahcNOsHE5kHgJpqi8Rnb9EYevdu41coPU49pXToBRtKWiheAKEYu1EPuLhtLcU-_WVUdG_8Yf909hU8c4EH2G_Q-o_u8AlAJJhbUAn-8G4ezPD4YDYt3Oy_0pcIoZUi05rrhm=w657-h369-no
Se ha descargado sin problemas. Una vez actualizado, la fecha de compilación del firmware es del 26 de Octubre y tiene el nombre de S92_106M0.
q6DWVOhAU2DJ2LWdmzkd7fG91TlESbyZ0YO1-nXdUrhCchYTHr49q1G8sqb7K92k9Bj4MBmnx_w97BORHXxwb2LJwioXanKMxTf9VN3IGHPbNuJtU_NEeeBhriCWEwVyvxQUXl59-bLz-15dtAhWFm7HTGzxWf2roXLRTN2JQjkL6jReP9fjBKb-oJPyD-uL-ezOSENCiP5DYUSembg8QRI9ISZKxqzVzrWbQwKbhSIZrH1YT5-_ZNVQ4I8M9bK2Zj5KGhV-reFei7pIQike_0rZXnf1UGtljricpb9khw7cDyobNxyA8tFmL7PXOlzonsZq3fDA_NtuKMvr4Z0z1ehSJCfVDXaFU293ApuANX1GKFKI1LIugPm9NUlV8_Z98pQ7Z9ULXoZuKqJ4B4q2h2f0v6UqoqgWTwFybzKGXu3cMK1W1z0RcZLHhy7MhZ-y2t5UBVAnr-9T_lYRdo2dYztEuedpK4MahVsqp-DVNcp7NunsZXvO9963TCQDZHxTBfHNfBKR-otBttQ8c7VInw5Z9W3v4HgauHXV8tmLsUIUixV9erHz9WqN7u0XWECygjW7lVGEbRiX8BfROpO_elDcW3_2fanIQ8NraNLP7ZmDba1O=w1177-h662-no
Almacenamiento
TbOn-CT3w7Y5A7uILvV7X8yc9_REO9Y8qQC2rJqqBJyborG8jI5QSCNUJE1nd9BULwutaiQN89Wj7hzHevYeKIiTkFIKRqnPPEiBEkmEMTdqgr4Uhq-yy4wJCdQ1aKAnhnOzErLdZbLqTmSrMF88t5fQpPApJ6W4cc8lZMVnqzZ_lgAhbaA59E1Vz7AGgDurx6zW8O26O0VVcK3VS1vJQZrSSwFcxbYfNKCSKb1TcmHVdUFasnyqCTU_utlVVEKaEffls8xjikUD0UmNyIMPkR2ZxS4Eq59FjpPKp4v2fVRswarncrBPDnS5dViEH6xTQjY2sMjNQTS56lTH47_6EG7zhU3MX6cddgeyj3sEcrivtXjw8iGe5tEVYvHkoVe4C2UysiOVzqSNY52EUFmn74sLT5BZJ45ZSzbPJOa1iyx1fFdafN21NXqalfy-15JZqRyzCZLts9ofcZIBGTQP7-aKZhU77n7-waF5Nal2I6-Q_ET-HS02ddFVOhjyuppdwOuPov6eoUVOZULboQ_Y8QRcowR_Dy10LsXEDWnqG5NRDetp5n5AmuIU2ROIH9yU4yelSgWKDeU_hhunYWnzHlZ6fHO6ZlH5t5bCltHgJSROcNT4=w960-h540-no
El S92 dispone de 16GB de memoria eMMC, de los cuales tenemos disponibles alrededor de 10. Podemos ampliar el tamaño incluyendo una tarjeta micro SD y añadiéndola a la memoria del sistema gracias a Android M.
Otras configuraciones
Podemos elegir la resolución a mostrar. Si nuestro televisor lo soporta, podemos poner resoluciones de hasta 3840x2160. En mi caso la resolución máxima es 1920x1080p@60Hz.
s6R71bBk4htXYVUAhkIPCg_MQQ8zwywaZbiU3dVUSNy8X8rHdkK76zY9BjOQqfo2qO8JTtO7DuAGzebMDwSDdSjTc77TkItlYcphqsJjWttLbQzLyMNrCwjnVQ8r3GI7lsKEQDCoq8oLqKcP0mKu4hrF48T3o9vMK6K1v-CErgBYxxJLMBDdIA2amyaeQJENB-8dLO-eoXblKg4a0OKS9V8lLsg26iuUTHejOG_3zO_4VP_Lu_S9X6vKiXhAAL8cDgKoqV5Zxtk34fQ4Qo-8xjt-o8BT37a2siFnWW7iTYGh_whf0hPuOUj5h8q3gv3JVbuajUG4MYgCwJx6lxvcqTDqKJGdGstz9HTee2ELWl_sfTAeiGmiF5OBiZY3xyPXSuM3x_ZlUkrSjbwx4wL-e1HpoOBbdiFZnfPxA4OTVUek3emw5LPLpVFNfwYfe_NoaHITbW5xNvTg6LKj4K0FnmXNRaLvUaPzu4cabXufu_fSU0z_hDpUKyJ0jbkmHlbfDWopqsNW0R1epBfYpjuWX-sIuFKw4HxdWS2E6c645hgYWXF0MljKMrqCrI2wkh2Mi5BAJJMoaXWtS6qxfa4vs9OlgLf5RT18cVso4If56gOA2jwd=w960-h540-no
Hay una opción en la configuración para activar el HDMI CEC. No lo puedo probar por no tener un televisor compatible, pero no parece estar muy pulido este sistema con el SoC s912.
7FvRmc72ZF9UtCnmp2LPoHQj5fVq0F6HItRmXEDCkMABf_xuZ3yIJizlaLYIu-eQeGS30zC3baabVN74kGOKGmtB0xzKuu6k2tOFA9F9yjwLqC8bjGmZL08NtuyghZFPx9zleMU9ZIst1jxmdNRDx-aWdQaXqUEaCUSPmztlmWxyh6-5iSBG8irLke1g_V9d_kMWp8cpMLyvBED_kMEYu-kHjfHD5dTYaj1MKSWiuih3S7tRHxXWjpXsKWQZhRQLIpu9r5p9A49y0SkqS_rGoB6xEC2FqDbjpF4s8LOdrTj8Z070F6uw6xfpHt-A_HUXZwziYLQIeqGAIPJlL3a90BxFr-mkSyq9eyQaIde5aZ3UjaYMTerF47Z0GOooUVoBYlFZSN8qnMA9ozpf6BZod-FimwMaykzyd3X2AZazLTix-MT_a_WN50cYy0kYqo1cdTGkNDf2PlFwRDbUrDOmaXovI8prnw4wTLBYeXy2abgGHxtAJJffxZhEYN2HTmua19MfVpw8VjlmNuzMhImHrll2xdY8r6iWwyGmSU6aUN-wOjzMjSVWSBt7RMnbEhBkDqkDPebqILl1uGDO2TQ6G-BatW-ZNmosLnwFnCLf0raBDRbn=w1177-h662-no
8369e7bh5FnTyFufISK1pCZP94aFxl_949wHtZB4bSV8ahe4_PAWVBVMaHhMYk0Nc5GF2c6yMCkBrE67DBAHrwSGASGKh3HJjMwOTk-h0OzE8ImJEZdAEaiUlGqqGZ-r0BbM5CNleN_BHD7Ruf8Y5XwSr5nRQBsePIUCcVCscstYCF9wQBu3GGVfZ6Lu4e6nT_ttZBuC4D1jQgjaAKGU5jWwOxGmxk2wQaK6wBfeIOL_0kRnJ2KagEr6QKFMN8HD9oCXdG9c8mM73nnA35K63JXRN_bu4oRqgZ3ikOI-o7tY78ZCVJ_sflgHg16iLMh-ZpdbjF3ZB2g4Pylqx1rY1mICyfSlOB0xCTubAEY4qkDoeXoETWcBgO5BU30bu0qOYlLmI4S_9k2TzLPXmHPN1AWgHET_md_Pm6ij837dfrVVTrnGdhOdcNJDHCH1z0nDzuHQ0k2Y6jsDkttGx5xALpjqymvdH6kPdrZ4h38U9QJqNDwNIhQ8TXe78x0sqc3O78XzoxR-4D2befZrbGwXa8BuA1I32Hf3fabMBbufBkhdatQTjcqFWX_Tm4zY5E2sJMuxm1JLk_iW9CpwauiKWvupSibqmd0R_s-G9rj3GkuuViVV=w566-h319-no
Miracast y DLNA/AirPlay
La aplicación DLNA me ha funcionado correctamente. Con el Miracast no he tenido tanta suerte. Después de realizar la conexión, no se veía nada en pantalla.
Root
El S92 tiene el acceso root activado
POtaDTrGP_WLeijrXysDZRD3TVX5BnUwggV09doxFvv8VVCV5vL1BlS4bNLUvOPwDtJwPxc_kBbC8CPxxlbIt-GoIkgVmvQm9yHdpZIEs9c4K0c6DndCyFqRjTMyiXYiZpzFwlO-9kJ4rxlNG6uhW5wsAzhMdiiyYXgHUDpRXApFZvdDwhBxeBY5jJCzsLOSnV7VuWBwDTjT_U7C6fwGAWMwrjF19MWyfpCZsVqMP7ecaE0LWNQaeuvMtCN3PPSMlQBPmuXMJR5NttEkJUpejaZZlJB9rOon7ooykIJWq6IyTYSNEEGHojRm720HxNIWnSxQOM5hAGntv9ENawOCRCJu_CN78KiWOrioD_5eSpjCbjzP1bkNyDU9cxsfEQFCbJJWmNz_TG4kiGIJvWxi-RgjMio6OFbsFePpb4rOa4bGT4yEJWoji-eFEIc25yE1CQXY63Uaan8Vpd61NItQTVrXzxNkE2JdsIFeAh3yxjphMW8tj3q0mFo1e4VzTpNOfStiYobiLmfJSIJ0eY-lN2AXRkZdaV5uVFUklst_avwWNKNweYTKw84TfUuQZFbkpxmwhnAT7RVBBHXC4aSChfLyiIGqgoIQSsKK1R3AQ_XZvN-w=w644-h204-no
SOFTWARE INCLUIDO
Estas son las pocas aplicaciones que vienen con el equipo. Algo que se agradece, la verdad.
pSTwIR34zS9SbbLU-9nHcJDlyBqP45vE5e6X1eTbhZD-GtYDEmHLC4F2MDvRBIp7jf28MulmvZuaRPsH9yhXII1FUVDT6JtuVo3s_rU_s89BF9PtAtpJ2fHelJmS5csmM2EMmV1R3ItCd5ymgIYTkMRVcHHVFoH4UySYlGog396ibfIKTb0WGvjW8h4b3o9O6mPtoX45MFooejAh-R--QaQqNe61hq1Xq9FXEWsNHJAePSd1_5MW_59zH5E0QzwWAj2FntjwdPMjNpGXDInVlxw9ex0MiPcy11E5YzWuJONpBE45dbSepBPa33PzKzJv6zKxkRclZ5glEDVFMLQPnEGA7npZMXk_xkS3pijDQTMWfOsWr_00eYBRYhbb0NcZs29JvNN_syrMRpxB72m0gcRoJfyvTA0i9ibW4B_8qcfbe-lbUxtzMQ8fjHJDWd-olgp7bitxKo7UP9ZBJYPMvQEC0F3gbwP-DhQwa7N4KQyVZlyEzaNBf0ZPqiO0rZETxNPwa5TsjgYxNbdKeE6ND0FbL8dPCj1voysvvzUT70PLXUF4dTG6nnWWZ0U8Fj2KzeRSF6vFZyaEcJtrk0wzVapFt1snxvf5ieCq0cJyxCoEozTw=w1177-h662-no
En cuanto a Kodi, y como es costumbre, vienen instalados un motón de addons de vídeo y audio así como repositorios para descargarnos más. La versión incluida es la 16.1
lcqXwSWMsYLJAqqi_T6UIilRXC0pzKPSF_k0ozakXSvNzerm6rj4ws6O037_7qR4U2W9HFE7_OaY1dTynAkO8dge4of-HIkDwUxtRYKjrDXAPe5NbskyB7lFq3bAOboR3uNqSo53GtSSw4Sg_tFJlyy11qVovNKP8xeXTwqyTXw2aWpfGoxRozeXoYSrVrmJPhxGEHi4u6_5bxvW99SgVyauaKyvg4zi_-lBCEXvJXnu0i7LjMkBpT6XjMPL1H34yhc3TMTOz1tbSlZ4_KTx4sDSsqAFek2hloeI6-wqN1iev0wxNkqIj9wgMkrHgG_yKeibevhfJPCC-aQXropNulbAzhWurbxz69tKGZOX1zxxEY5PRbKRKN5UIROa85tbOrwdhswZbPN6w5jnkgNkwpEP1nK6FrhGODs75mv73gMbnGYqWlmFcDlvQfJFH_O97Co_HHSrQxAjcknXH_GLWjt36_ZClqx2tDG3WH8Btc_o6YjkSUAiJm932S4Qbwj5FnjFATfYHa6oZCPfwFDzj4tjbIvbT7e10XcyOkMWDsrFDr_pqi5RB86uykJFX21exV4PnspP45j4WC8Yhd520ixRusCf4yC6uNYdKCd645rLt3y5=w580-h326-no
He probado pelisalacarta, tvalacarta y Quasar sin problemas.
La aplicación de Netflix funciona sin problemas pero en SD como en la mayoría de los Android porque no cumple con el Widewine Level L1 (solo L3) necesario para la reproducción de contenido en HD en esta plataforma.
r1UnvFPz7BnvuNF833C50S8u2quRfzH9up91jZyK8kXm5Rv7d1kYxgFgqg7VBK1mPYQCzp4T06nBgDyrQ7fj7evLUzVa9gw43WhWe-8_K-1IUft6ZUlFgrYgMFIGExUyepD7BFqX9m66IOQ8dN9KizSPMVnUB4wUO1ucWp4_m5drFwZeqXnsFlA0Zn_J1cPfiUcsFG-v-f6z9eXO7AWR8MOw_ins5JYSMkcugv-hzrjNH31nReJqtt3a-twlyKaav_c5mHIRq9ZWWZZH4FnovdSiHq9yCRl5GrMHjr8pkgUHryY8Sp0fp_okcMKNHiSVhVfEaKUnJJ33iXAny16RbKcPEzEA9sCMENP6gW3RvXfuSfcalUIs98WtsN2uMrWEBjESsozBjpOrOjqDCCH4XqLFJbaQ3Lv0oNMhOsxBXvi_yBMWdZPbPjBMsg86xK7nK-Xip8u3OcB_hyUrF5AxZWlzbpcgHkQ_A63MAnGkPEodLvQuvttFc_RAbSwc5F42COiTClC_lltRzoEpO3YzGFiSCn9kByEeUhHyhh3LfORV_Ml1fc8vj1072QDIqNsLVCE-JCF897MkAVbPG7p-0ScjNsCh7vttsMqBQVbPAaM7V3Yf=w667-h355-no
tK4hvlkm39VsNcJR6MZv3nUMUysTKhWPQCUqGtKbbs9zkSzoqyRLH3ZDmZwv8Nag7EPzWzgx3WcGD5KY3v2mJC-PYBP7QY9xDKU-A4-qJVrcjRpfK2vyFZXwrf_uAiaBr17xi4OUPKDXm0ONXA-O0ieGzIFh-z_mqMU_OATz-61RPugOlyr-YHsNfBEq7u495vpNne-GD77ileTUEUg5kzm8mtwPtJI0DFsQcknG4_HlNgm9YVCNI8cdgMZFZ1O9EWIEFXbl9aQAca09PPGJoTrF-oCTWnXEZuH_U-HQq2AtkwBwoS3nnv4NQXKZcqGB77h8-S2nVFh0Wqy54LOHu5HEx3NL-9C2eDSK0Pyuea4n5nqUuH1mUTnXRJabuCu27lwj2zUbjANwSlcxm_gT19UK1mdZd2XKeCHzcFPazhEFrrFPfQvJpm75zU1g1WbTeDDupRSZfq87hsyufW13uoa6xxSRDg06gWJuHu8bF-4imqkn1eA0zP0XgJ4xxWAjcqy8w7s4YX2hRMiV6ouOBNGt767-g5kfvyTykYGh538EFxX4c0Hd2SqgZWiOzF4c7AXf3ntCVjVv0Wabs0KTuJep16Tclm1XBDnQeG2VV-BStdId=w465-h254-no
Movistar+, antes llamado Yomvi, funciona igual que en el resto de equipos con el SoC S912; si inicias la reproducción desde el principio sin avanzar o retroceder, no tienes problemas. Sin embargo, en cuanto saltas a otro punto de la reproduccion, el programa se cierra.
TJ1QW7UYiERq7NVs58k64o9VDmKawqNzOoekhyBKdy9jslIkSV0P5TCet81goQdSmPamCXEfDWZ_ukwQbl7YFWb0qeF1cieN4Mcga4m-pj9ULyMcs-3j8HsMrL9JZPNc92IRVamYIJEz_ifvm4USdntHs8haDIg0NUukes0Gwwyf9mllgpyqMQllfYGYbGgLF6ct9jqJJDOBXkBclYVw-C7USHgLZoPodMj1novkPyDfGEiNDH5W_MzlYl3DQwHtFsxLyNafEGnD4LohNiyXP-qL8yQ_LPNIB6VQj2z33f1Db9F_0w9WPI5KTdcDW6knRSSgFYO4Hs8_hj9ToE96jb_s9C1h9PKQVNOtxQ7lX0JNpQAxuOeVBvSG9SnrRz_kahug3t-ickcsPRMznywYNh-88o_LtoCErkbINi4HKal5J8Y1-GlCEl3BrPrxcYRd5SPifm0D4wvei2UDnqUcJL0GypMgCeiNJdrX7KSfH4UJxHzSL27IbqaRdkUe3425syJNnRaP16CUnpr3GyTeQDo2BnoNFuqkONDHy-EJf5TkkQu7ju643fHLtoDBOfCy8NrnnejkyELQ5BJwzO7P7ebHmDB-lbo3XV7-i9D1Z-01G2Bn=w1177-h662-no
Afortunadamente, este es el primer modelo con el SoC S912 en el que no detecto los flashazos verdes. Espero que para los otros equipos sea un problema que se pueda solucionar con una actualización por software.
PRUEBAS EN ANDROID
El S92 monta con un SoC Amlogic S912 octacore-core (Cortex A53, Quad Core, 2GHz) y una GPU Mali-820MP3. Se supone que el micro debería funcionar a 2.0Ghz pero se ha detectado que en todos los equipos se ha limitado a 1.5GHz, posiblemente para evitar problemas de sobrecalentamiento. En muchos equipos sigue marcando 2.0Ghz, pero en el S92 ya se muestra la frecuencia máxima a 1,5Ghz. Esta frecuencia es la misma que la de los equipos con el SoC s905 y s905x. Por ello, no existen grandes diferencias de rendimiento en la CPU. Donde sí se nota que hay diferencia es en la GPU, pasando de una Mali-450MP3 a una Mali-820MP, consiguiendo con ello un gran salto en rendimiento 3D.
CPU-z
YwWhgbscY07sKYETCd3jWIVCkUpOjT7yf7rUCHoMM0Ot3YMow0ZSg3CV_DarcJajJjZTbFb4UktZ3jp_xoEqWqsLML5aGUeY3Hix93eoBo-5On4Ml74EhfZ7mol9B-qFjWbf22jzxMYb86N37IOxXSJ-dS4hvB-_8hSeGKZ7HR8U_SvSbKCMGe0jx0ZO6OpRuvRhPAbOivQcK0sKdCaR2P8omTdL2elo3dRKsyag3FUlC82bVZh8DvUeh0kNkZC0OZ7PA4Eu9sT12D4DctYZGpg62ZXRVTkcp3XmQgtzPaHzEO3EqP6UBBppUbqLqkzbaY0x5YdAr9BCZmNZCYi9VIKW0QIqk9nCMqy9BpAl7EaVm_tp7IJD7O3Q2myHh7nCLIFi_NTfOsM_OQl9BY9azSoMFWq86hwmTuyjRI4gXzbaso8QGkP6lFBJ2iR7nE0IkOSuJrbYZEJCT0UF36vQZSRxbHHDSDLoOQ9D60xzZTKqL2tBt3gEZQQdkDcIuZs1O0a9too442Owawm2GIrhkHpoZYKEjF89Pak5n6MkZmZcWI8S4HIfuzilMRh2FUc9tr_zQYAXPq1LIIrMaKIi593doA0mYC_C-foAvbp2N3jvB4ht=w1208-h662-no
Antutu
LeXrJA-eMSWvli02CsKFHiIgaJ9nwSJz4if3Mbb-7QjwOkIoLyOPm1AbYNReD_2h-Q65qU2loSorrzvWC_Q69lJoBFcrmYLk1vAy5Soxhzmje-zPFChr88GoTYlwZzuUAu-6IlHnHHN5_OICxKpTY3rNd1Xr4oTSzjThbM7683AA8DIxl2p40TgRsAGU3tSJuAfbDRAOPeb_ASt4FaGDMhV4hKXRffJbPO2DzF_cBNSqrLHG9nvMF3Zp6sSDCGytPMsYopex1vkqGdJnRL76_rInl-efrAiz3bo5Mf9Xu3iJgvlyljVA0YrzAVMtAbS3zCX361u5-REGszDxOTWTKn6HbO-0Zo0LeoBRF2hHaiCkswJwDESgISoPs6cDtTQAsdlgyJ5Jbbj4_eiSAeQCfnsH5z_IldIS9pa1nO3UloGTtDqplJ2T7S-5eaqvgpunfibaoU6QmXsUnpF_s2QFJKp82aDLZpcZtyJwgCFp9qVr2pwF6XL0N3TKr-ftpnddUuGWfvxQOBXKcEHcTxeoQj-rEovXwBuZ8hq0YSIsH3vKxci8uTyA2f2nrZskKd5ETmFjUCJ5nfwGpB1LqAiiWNHrq3w0p71NEARwV5oPcTbuknb4=w1218-h662-no
3DMark
5RUbC6hA4KBdjxNCQ3F3-ii2y3-UitOUHyJd6cWbjCHyo09SUIx05v9vtUZZLzdeyKn49TJ-o3UoM1KDRblrKgL2tJeF1wAFyPa_IYOLobOsA47p2iRURTuj14T8oGp6G0CT2LSPserPhINz-oWaPePDV_C3156Tp3-AKHAHhNeQvIVbl183loFyhK6pCU6_D9rGgpHUVPH8Z8ocM8zb_qfQQwYVZHfGvU-fzb6YUBbhMTFqTV_sdLSoeSndXEm2SFXWpAAn8q5mFoswQ-YbYytqDjpkdOC3hl4KzQ0CwxBYGc-SciKXgIpffKovzeN3YTsqzGoZ4Ujnjvc4_Kosm3hinj-zSPVPZCcmE1Vv7rfDey8rvpXiPG6Vl7DteaX1P3rjs2WMw38Nj1dKiDj9k2zGYLdliLZrUPtRGa4FqAbYVKhhfkFRu5I-2ZrwP5k1QMwlzVauHjrhhHWOkTI9WvMzi3aCRDaZ8sseXzDiN9cCwZ5cyFaKqhdh3E4w9ftKNqnJOYQqUZIwhdhGb39GIt-Mz83s7Aft-5TBDxavf89PmXM2K4x0F-pj2Kku2skeQXiEEwSyr3YCaymFsoL3XSsPricY-xjq4jebHxDrN4iTw4Ix=w1023-h662-no
Geekbench 4
3tfTRD5aH-wzk12RDf54QNef6qhMK5rXG2SjKUkZZTd63Pf7zYYV4-OHeZPDX6OWrnDTgpBxyJZ7PFmfEkR53fzgchZAXFKjthxtWD_n0nAP-WyNKoYkZuAfOGz80caxFISfX5nUiGPD1Rnxsl2VETzJ3tP21RvHY7IS-1mqOC0j2BU2jiLRWdoOsFa9KR5rvJiNJBX0cKir8zOFawnvqoGIOF-uQYofPrYXDi9E8G1Iwytfp9IokGAG_5NKPzPIx51imJ0rlvDU6H4VLom1xljGwlPOsW4QYpx2CQW8jHLmKSOxvdy1-gCA8ACsR_b2-mpxXckMUN0Y-oDj-8N8xEFT-2EOn6eSOes8d5BeUy0HS2xHYt8lw0RUxrIHzC_tnuE7eX41WO4387Cor4cdApAXCPdY7SXa7bSqVSWWYXw-uH_nae3vAM8Qmp2YbLxPHh5Ly9Uwa5KcSCTJO0xwImnGb-7pfoMzaRzYRzrrurNiP-pioZg5JNCU148Sxp6eq2x_ReccH--ecw4xBnw0CPb887FLLpOYNiDwYcUecaNcYp7MjShstEx0xBap-4oWSDUeXeV2BaLSxHzZ-tiOAbukCvsmmvp2--SGBi-ij8vX_5tE=w1208-h662-no
Vellamo
-836MAFM0L9U6sKy-Iiv3rfo9_uiupjABpGDB-FF0kcHzYVTBaRUt95--AsCyuWm5SPKiO_os2E5m2p1WI36J8hCojp8fuAuHmV3mTk1lNIOVql4ITPbh-ZZy8VvPb9wrPUYahFAKQfazsAUtelTVMMjyvIrIUViZjen8paSg_dwcQ-9rTetqTNPLuQt66V_Mcd--tnIPs-WKxceO3A_zi5ktByczhw3r8OcGIojweJERKhPzt3MGj6mSEFfHfYu3Iq-o7Jf4RsTWq5EvtFH_aA3lHgILl4OwQeW9kmFRFUNjIQ_TQPeoG3xOZZ-ygHNCQeC1cjNkSSge-voihfzghexhwk6-USYzz_v6ZUooNt5X-AEYzxhKTz48WnW9JZDJ0oe0qUqLLp2a_obGmMjuMDreIRWFCzc4t2rgQGlmHkOyiVfcs-jbLIf6gtf5yrGciv_DBRI0mirMmkZpWeH3VW5s0Tbgu3mqtBSrSFMBltDwkz9Tqy9QWCvMvPWfO5LNGznFptrtnfce-HPRPz92L4jD0iB2xClgIeXxZ-xaJElk4Ms5VdfsTHg4WJuuX9ojmD20_aQSeYEUO_YdfA313PGOtAUena-9aQu5Spv13PCEu-4=w1216-h662-no
A1 SD Bench
GfU6kjXXnsXFrbc3Yj86exRvU3mjmEo_MV4xGAMWDP9BTzn7wPTGVPocJAJ8ZCHgyYYu7A6nci556NDKCK57Kl3JuKxlualP1R82DzQN_yYGxuFblCuJA51-OuAdc0BIC6krw_MvE3GwBheAgg0_PR6AJLcJSZ0nrqCZ5sbB_WIPoP0w6WC62UgSUOS9mUq9QAuM0yRCing1qnM4DMtOKIEsOcWF7F1dNLRNDW6Km83i0Yg9rVEyCQBziYdPznj7ohF9v5NNWbycjRowt49eFpKtLf4C8qOPqbv0GLZvluud9t3RyweSBwYwmJ9GXZ554WjRCOZn6I6QBsWK8q3LQa9NNIHXe1drqraYNITK3XEa0yhp9MGmwJpMbkRt_8BoryF499nogHaspGsNKzGVdFIHtFLlLoJMOsRxeMb8q2boE8SwNHUKl-dNzXEF4ttmoyWXWmCXqdupbldWhudcLOMXPjSGlfTx6GvClVDGaxS2pn22NVcBBXXTN0KmfQRm5XTx2NkgK3DZT37VpYxidrXCZEjzTevkwvA6MiPbajdDv5XV87ATKt2er4U94xeU0VUmL0WB7FanO65vLR2-hb0ndx-tn5sFmlnIxFl-bzHrxKez=w567-h252-no
La memoria eMMC tiene unas buenas velocidades tanto en lectura como en escritura, algo que se agradece para mejorar la fluidez en Android.
CONCLUSIONES
Estamos ante otro equipo que monta el último SoC de Amlogic; el s912. Viendo la simple carcasa del aparato, no me parecía que fuera a esconder un gran equipo en su interior. Pues tengo que reconocer que este equipo es el mejor equipo con el SoC s912 que he probado hasta ahora. La primera gran baza es que no pega los flashazos verde de otros equipos con este SoC. La buena conectividad, con el Wifi de doble banda y el ethernet Gigabit, que funcionan muy bien. La memoria eMMC también arroja unos buenos resultados en las pruebas. En cuanto al software, siempre es algo a valorar que nada más conectarlo a Internet se nos descargue una actualización vía OTA. De esta forma, nos aseguramos de que el fabricante nos va a dar cierto soporte. Veo que en Android hay pocos fallos reseñables. A parte del funcionamiento errático de Movistar+, solo cabría reseñar el mal funcionamiento del Miracast. Espero que se pueda solucionar en futuras actualizaciones. En definitiva, me ha sorprendido gratamente este equipo por la buena calidad-precio que tiene. Un equipo a tener en cuenta para quien este buscando equipo con un presupuesto ajustado.
PROS
Precio
2GB de RAM y 16GB de eMMC
Wifi AC y ethernet Gigabit
Actualizaciones OTA
Buena memoria eMMC
Android muy fluido
CONTRAS
No funciona Miracast
Movistar+ no funciona correctamente
