Vale, pues entonces comprueba las temperaturas porque no es normal.
Esto es sin usar ningún juego ni nada por el estilo (el ruido que hace de normal)
CPUID HWMonitor Report
Binaries
HWMonitor version 1.3.1.0
Monitoring
Mainboard Model B85M-D3H (0x000001E8 - 0x009EE5F6)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8728
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8728
LPCIO Revision ID 0x1
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 28 01 00 00 40 F3 10 00 00 00 40 80 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 0A 30 02 30 00 00 00 00 00 00 00 00 00 00 00 00
70 09 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0A30
Hardware Monitors
Hardware monitor ITE IT8728
Voltage 0 0.86 Volts [0x48] (CPU VCORE)
Voltage 1 3.30 Volts [0xA7] (VCC3)
Voltage 2 11.74 Volts [0xA3] (+12V)
Voltage 3 3.32 Volts [0xA6] (+VCC)
Voltage 4 0.78 Volts [0x41] (vAXG)
Voltage 5 1.75 Volts [0x92] (CPU VTT)
Voltage 6 1.54 Volts [0x80] (DRAM)
Voltage 7 3.38 Volts [0x8D] (+3.3V)
Temperature 0 36 degC (96 degF) [0x24] (TMPIN0)
Temperature 2 42 degC (107 degF) [0x2A] (TMPIN2)
Fan 0 1619 RPM [0x1A1] (CPU FAN)
Fan 1 823 RPM [0x334] (FANIN1)
Fan 2 576 RPM [0x494] (System Fan 2)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 19 00 00 00 FF FF 00 00 00 80 60 02 30 A0 33 91
10 FF FF FF 77 C7 82 80 80 01 03 04 FF FF FF FF FF
20 46 A7 A3 A5 41 92 80 8D 86 24 7F 2A B9 C0 0F 0F
30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00
40 7F 7F 7F 7F 7F 7F 5F 40 AD 6A D4 00 FF FF FF FF
50 FF D8 7F 7F 7F 40 00 00 90 5C 3E 12 65 00 00 00
60 00 14 41 46 1C 03 00 FF 00 14 32 46 1C 03 00 FF
70 00 14 32 46 1C 03 00 FF FF FF FF FF FF FF FF FF
80 FF FF FF FF FF FF FF FF 02 30 01 02 01 70 E0 94
90 FF 00 00 00 FF 00 00 00 40 97 00 00 40 61 C1 80
A0 CE 50 50 50 50 50 50 FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor ACPI
Temperature 0 28 degC (82 degF) [0xBC2] (TZ00)
Temperature 1 30 degC (85 degF) [0xBD6] (TZ01)
Hardware monitor Intel I/O
Temperature 0 45 degC (113 degF) [0x2D] (GPU)
Clock Speed 0 598.57 MHz [0x256] (Graphics)
Hardware monitor NVIDIA NVAPI
Voltage 0 0.95 Volts [0x3B6] (GPU)
Power 0 11.15 pc (GPU)
Temperature 0 43 degC (109 degF) [0x2B] (GPU)
Fan 0 1050 RPM [0x41A] (GPU)
Fan PWM 0 24 pc [0x18] (FANPWMIN0)
Clock Speed 0 135.00 MHz [0x87] (Graphics)
Clock Speed 1 324.00 MHz [0x87] (Memory)
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 2
-- Thread 0 2
-- Core 4
-- Thread 0 4
-- Core 6
-- Thread 0 6
Timers
ACPI timer 3.580 MHz
Perf timer 3.118 MHz
Sys timer 1.000 KHz
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name Intel Core i5 4570
Codename Haswell
Specification Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
Package (platform ID) Socket 1150 LGA (0x1)
CPUID 6.C.3
Extended CPUID 6.3C
Core Stepping C0
Technology 22 nm
TDP Limit 84.0 Watts
Tjmax 100.0 °C
Core Speed 3491.7 MHz
Multiplier x Bus Speed 35.0 x 99.8 MHz
Stock frequency 3200 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 6 MBytes, 12-way set associative, 64-byte line size
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 6 MB, 16 thread(s)
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 32x
Max turbo ratio 36x
Max efficiency ratio 8x
O/C bins none
Ratio 1 core 36x
Ratio 2 cores 36x
Ratio 3 cores 35x
Ratio 4 cores 34x
IA Voltage Mode PCU adaptive
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 0 mV
Temperature 0 50 degC (122 degF) (Core #0)
Temperature 1 49 degC (120 degF) (Core #2)
Temperature 2 46 degC (114 degF) (Core #4)
Temperature 3 48 degC (118 degF) (Core #6)
Temperature 4 50 degC (122 degF) (Package)
Voltage 0 1.00 Volts (VID)
Voltage 1 +0.00 Volts (IA Offset)
Voltage 2 +0.00 Volts (GT Offset)
Voltage 3 +0.00 Volts (LLC/Ring Offset)
Voltage 4 +0.00 Volts (System Agent Offset)
Power 0 28.68 W (Package)
Power 1 15.03 W (IA Cores)
Power 2 1.67 W (GT)
Power 3 11.97 W (Uncore)
Power 4 1.70 W (DRAM)
Clock Speed 0 3491.67 MHz (Core #0)
Clock Speed 1 3391.91 MHz (Core #2)
Clock Speed 2 3391.91 MHz (Core #4)
Clock Speed 3 3491.67 MHz (Core #6)
