honeybadger
Que os parece esta configuracion? Muchas gracias, es para gaming
[TABLE="align: center"]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif]66693[/FONT][/TD]
[TD="width: 299"][FONT=Verdana, Arial, Helvetica, sans-serif]Intel Core i5-4460 3.2Ghz Box[/FONT][/TD]
[TD="width: 81, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]134.71[/FONT][/TD]
[TD="width: 76, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]1[/FONT][/TD]
[TD="width: 84, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]134.71[/FONT][/TD]
[/TR]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif]89258[/FONT][/TD]
[TD="width: 299"][FONT=Verdana, Arial, Helvetica, sans-serif]Asrock B85M-HDS R2.0[/FONT][/TD]
[TD="width: 81, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]47.93[/FONT][/TD]
[TD="width: 84, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]47.93[/FONT][/TD]
[/TR]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif]56811[/FONT][/TD]
[TD="width: 299"][FONT=Verdana, Arial, Helvetica, sans-serif]Corsair Value Select DDR3 1600 PC-12800 8GB CL11[/FONT][/TD]
[TD="width: 81, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]34.30[/FONT][/TD]
[TD="width: 84, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]34.30[/FONT][/TD]
[/TR]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif]52021[/FONT][/TD]
[TD="width: 299"][FONT=Verdana, Arial, Helvetica, sans-serif]WD Blue 1TB SATA3[/FONT][/TD]
[TD="width: 81, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]39.67[/FONT][/TD]
[TD="width: 84, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]39.67[/FONT][/TD]
[/TR]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif]57426[/FONT][/TD]
[TD="width: 299"][FONT=Verdana, Arial, Helvetica, sans-serif]NOX NX 200 USB 3.0 Negra[/FONT][/TD]
[TD="width: 81, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]24.75[/FONT][/TD]
[TD="width: 84, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]24.75[/FONT][/TD]
[/TR]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif]71475[/FONT][/TD]
[TD="width: 299"][FONT=Verdana, Arial, Helvetica, sans-serif]Corsair VS550 550W[/FONT][/TD]
[TD="width: 81, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]41.32[/FONT][/TD]
[TD="width: 84, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]41.32[/FONT][/TD]
[/TR]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif]77779[/FONT][/TD]
[TD="width: 299"][FONT=Verdana, Arial, Helvetica, sans-serif]Gigabyte GeForce GTX 960 OC 2GB GDDR5[/FONT][/TD]
[TD="width: 81, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]163.64[/FONT][/TD]
[TD="width: 84, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]163.64[/FONT][/TD]
[/TR]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif]59129[/FONT][/TD]
[TD="width: 299"][FONT=Verdana, Arial, Helvetica, sans-serif]Asus PCE-N10 150Mbps 11n Wireless PCI Express[/FONT][/TD]
[TD="width: 81, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]14.01[/FONT][/TD]
[TD="width: 84, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]14.01[/FONT][/TD]
[/TR]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif]31046[/FONT][/TD]
[TD="width: 299"][FONT=Verdana, Arial, Helvetica, sans-serif]Montaje y testeo de componentes internos del PC[/FONT][/TD]
[TD="width: 81, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]37.19[/FONT][/TD]
[TD="width: 84, align: right"][FONT=Verdana, Arial, Helvetica, sans-serif]37.19[/FONT][/TD]
[/TR]
[TR]
[TD="width: 48"][FONT=Verdana, Arial, Helvetica, sans-serif] [/FONT][/TD]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
