[REVIEW] TV Box Zidoo X7 | RK3328 2/8GB | Wifi AC | Android Nougat
Txemoto
Zidoo X7
MzPIRw5IjX_UcY1iKUQHRa-XJTfXsVkTwtsL3RVUqZY-_6EZe580mStTMFKUknSZMbQmtLzs46qw239NCJ4xXkuZLuBV56u5NaVvTOmMiKVk8PLpFCWgw011J683gXKPIyWdNOkHeUzLaxbCRZRqyAy6O9HHFUnsuTClF3YhWYu48WsvD8wYwcJLlun3jJiXl4DiZ0D_yBudAaYdocVWZ6riW4oMQWtyzaIatZlPeFaVxKXHqTyL29bc7r-YfWy856WtArIAHyINCqKt6OC6UDyexOijPgmxUHn6wnnSFqIl8mx1QMFuoXxqZicISaCd7gL7WIjGJ7-fWY3zfjjsZqSqCYmxa5za5qSi0n8H7HSIcz_hgpKvkjpuyMXVl8raMIt3Yq344qkLShkWr-vkHosdZyp1fKUJwIAOBZw31r4WEJgeTD7fbbqQR-2c-umv7XM8WppkrcIO5LP6n5oByPYIjQLlm6Et94d6YqfiOV8Ui-yABtcD6QDt6-mFeJqlRr-BOTHTiyAVbkab5DixuPgIVsptaHfVYYD578SAW52c8-LTfkVj7S7R130uWSrPSy7bsdyi4873NKYQsXBt45tSF7vcN4Iy8fpl4xvciUGfgipph7i5IhVjxHnCrdYMyI8Wd1ibIhiv7DjRKRvL7J_sekHC_b8ts80BiF-yp8m1JNM=w377-h459-no
ESPECIFICACIONES
  • SoC – Rockchip RK3328 quad core ARM Cortex-A53 processor @ 1.5 GHz
  • GPU: ARM Mali-450MP2
  • RAM: 2GB DDR3
  • Memoria interna : 8 GB eMMC
  • WiFi: 802.11 b/g/n/AC AP6255
  • Bluetooth: 4.1
  • Ethernet: 10/100 Mbps
  • 2 x USB 2.0, 1 x USB 3.0
  • Lector micro SD
  • Otros: Salida AV, salida SPDIF audio.
  • Android Nougat 7.1.2
  • Tamaño: 10,9 x 10,9 x 2 cm
  • Peso: 200gr
CONTENIDO DEL PAQUETE
W3P-RP3qVjM1HIbeJOaeBI_ForXqVZGE7_fZpzVbnZ4GwTIQkHnOwXuN1Ag3TWwEDv5YMY_VWsFHUPpadwv1r1iJu37JnVl_rrZUWKGkHawhNj1SGSUpdEwUmZOI7KUfwyt8D7povPMyXWtYuTPGK4-aoSerYEC2-6MUtgBUI-qPRNbXTG0PvWTE9Ia1AqCmcaXoEjtPMFbBVArQwatIN3LwaauEo2Kqz_tARaGfcWb0VpWF350vLgPcfpV-Gy6xKOi2-I8MXb99u5QTS8fC6ETnp_t6OaVEjcXATR5ukWzsgyfvkj3JOTT6r8rxEpfJR77QNLOAFowOUPyFjzM2tib3ZLG1UGz6rXSdnkIZKEgxNhu-vkCCarsMiWMXZjulZxkxdK-jwYwjjrOozx9dCfyXNgoQTvrfA66EjtrUyTLEU4pK3NJiWHucphUONxtpx4rjPXk-DaSsxciwMjlU-y7CpVZu1FovG6cUf83YdlfB9zvDQentC4z7BVL6DsLV7lLQppaJ8RzALLlh7KGbkUPvJpj6OTiiJmIabZWuvPPN7mlgXHFxL6sN3cJhWABX_5sldN4pcCT30WYhHNA7ooELXwAsQB9v7tU0i2r_zvnaZEwDVn0qhE-PDioaqizi6t5QVI-1dDJoFomTjauAbvfDm3ioOGJPdXm6_CYa4GXqMU4=w1109-h735-no
mlRGnkHvINu8NlhesD2887rpTwcqqhnGL_AA3Y101hWrVj5cRANs3hyd_NKFufJrFruzmCnR1sDa_iAMV3SqKwtk2DLWKxTp0yGal0YO20mdKWTqfg0VZaVTG16nwLIgFDcJAw5zLzTDSkWJHR-6AY8lYl8Ulqcogbq1aIwskMy3aguJwjMQ6mLO4Bo1aCbqpx2Zj91gcrZiXw9jmMWnu4BHV-CkP24xqf5yCAPoPxMl2BdW3ubBCABqRwcwPV39ZQFFh_04CSa9zEV-Amxxd4lATaPUtbfzTe2TjuXTg4IcJy_EkS6Ib4iiEEBfvfKfqcF4hVkTWp7awxbeCwynMrh4zjCdkQIy3LCv_hzYhWkHzeDLqOksFQUlcRTbaKC1MELGiVYVCk1b0x0lV9jS_kZ_swUgrW9Kdeo3IgDkFlf3kCyXEumuqNvFKC3T5QdOCu80urlXWvae5TI3RjR7-P5AQYD-H3GgnnrKJai-FB1aM3oOPWy1VWNv5wrs-Iyb4Yon1f5jVzASzbK35yW9WdPZjzsans5s53CBI3J8ZxoXGgkUva27oB970aO_i1Bgclu8KADxJuKqYAlpPXnnARGRv0vHjV8AC8C3yqQEj4DAkDpIol_F_21xs1cLlfsxewYxd9NnGF2m_rdfg0wVktHDocNFbTYMmkn_FvQlG6KYU2g=w842-h735-no
  • X7
  • Mando a distancia IR
  • Cable HDMI
  • Adaptador de red
  • Manual de usuario
  • Tarjeta de garantía
DISEÑO Y CONEXIONES
ue5NSzW7eyP2P4HrsujAFmjHw-HO9Ey70E8HIurGvBHCCbVSNcgeHfMZNU7DzK3ok2d_lnmJ5ReOUjdqtumqvU7OuwVlOwqAZX3BTU4V_8clzfR_uNSAvZ-GgWrgiEzIilR-6jl5TpiYxBnEX1zdo7Zvgk-K28ebrYxLrweZz15EKJf0i6li0Z8wGj-uZefnPILTHE39qQFWFov6mMnAgW5NJRHEwJoKCi-ed-oPJSw061V14UxDc2zK_pkwfuD1NoieC30e7VGAxPq77rnTYrtiSZxA5m7dSHs7ExK5Y7ocYCUhfMkkfIDDy17LDKDV7RDzE95AfrKQH4V6JB8hA88HPJicNKkXXpTgA-95sWLHJgTEGK2Xc2KCE5TF85CAadCBbPXvoToblsDBrHd3-CN9lAwx6Z04v6HS1ax5fDcoGxHrxMBfp_ZkLxiD8bLUwc3nK2jKrsHHfImM5YR5RneFCq2m2arn8wCKVzI-OkGmxNtoi-t1sjb-NYvpnb_03DBODUmSTyhKHcbYpoKDLx_821UerK5T5F1TpsUmS1v41m11BU2MnLEd7bRgfWns97g0NHQYahfJH_2Rat_z1ikU1NH-xtsfWLGBmER9Zw77d70mrcIILYJkxHpW6HrD1YZE7yanqaQEKab0YNK-6Jcr1_jlJU1XoCdYiQVMGeBZUCs=w1002-h735-no
No podemos decir que Zidoo ha planteado una caja con un diseño innovador. Se mantiene el plástico negro. La parte superior es brillante y los laterales y la parte inferior es mate.
En la parte delantera tenemos el sensor de infrarrojos y el led de estado.
R9rQerhTwhbopf_lZ0vne9qVzIrJofugUqo5sHsRUvKLRtggZ87P8NrIvqRMdZs3xmXmUswDnFoLMYpgTLlGvRrTlIM7mrGdNF5IOidf_89F5FFjoqK5-sAhJ4hBTU0OuVAYCk497-lulSXLF4N6FtXQnXCMMPq5b88rcMPdxhmwF40qAH38UpiI_GllKJ1raHfwArojCZ002WoGG7JPFbkHXcctvnUF50-5AujdkO-YSMx-15QeayKY4-ZBlyQo6aWLwtvuoWT4ZmBGjUcBNMp3XFRKDYCW2bDANdW0dIdBOtVchWet0eRZN3P_071GStf8kXn5qUmqqkQdeHtyLyM17ryXYk98BK1r7Cu7IqqKva8EOWMf688TBJ84xc5izTqDO7B3Djl_mtEL0jYlp5dO8jgkG_EgBGsVbvu-DY_zCOybNpiGko2SuwKn7AsfSpJus530onFTC6N0G6jH29KIe8GbW0KWbm-ACQAzekkcMpcZyz26mYeYz9--OWd9xgHvttcVUK9Q8nPEcd7F8yTBtfG8zJkDitbWzwlDevWlPZodnKFYcGxY976i2HA-cwbAaBk9NL8gR2-2AeaZEL7x6pyEEuiVJf5gZzrVY--XXmoup4NWS5ie7UQBF-ahcMGFKSSEQZaiFFAMLxbyq2OPLeXT3dm9V0330WHxo8C7avU=w1579-h417-no
El led se enciende en azul cuando el equipo está encendido y cambia al color rojo cuando está apagado o en reposo.
9-mqdhWd4lzH9kE68rUkIWsJlrGxN9NqK4tHZyJiNJ5Nf3tW7MMg5FCj6yxGzvb22IIhRAvuCOAgOkpI1F1NrolwjAxeoYs4WSx7qAJttRhZq1tuvTLUqn1_wH21PBUJ1ogYg0lT1rLurZKk7qB2oWQW483HzevE-L0wm2sBWF5jqPV3zm5b79_EjgIWPSfdOLqxxSELw3ekbZNKPJSDHQOvjK6IXLPUZ2Ht9e-BRH0FLb5v6GSWjC-ndmhPtcDOFnpIyR7Sbu5Z2ZS2N0cSgNSxbmCXriuvxMY9I1HDFbAIfudpnQBeptpjlB9fdvwWS4SrALM4Hj7KcUYezQ5An57dogtx8iqKEa3a3iQKgtcXCVKs2ScxmUXGV9nJpW4UFojtOKabXWAvwPm9xYKr7nsUWh1Ba_l2or_qsOrOjUrUa_oeEH3N-MqDGAfQxb3T1Ovo-G41c3hWeHHgZY3q7qqN6IsUQJdBmkgcCSRO9TevwFMO2tR0LCa9TPC1DdB1vZXz4U7K_fbjcNJKV6yYwuXQh1DxBhytAZn-r6LF5EHXGMuivFU97xTWwFfO4x963qb0eDAJFYlA5-nby9ixgWVzhiI_4FMWIs7zSrejD0TGKbw5AZhp_OT29vvVoLqnqTO8C_-l9DDdSZktyz6W66sFTPRILgtZxbohf-GywlftWvs=w1366-h354-no
En la parte trasera tenemos el conector de alimentación, la salida AV, el conector ethernet, el conector HDMI 2.0, el conector de audio SPDIF y el botón de acceso al recovery.
EmiMh5RPvHnJQ7YvkWaCYV5zxRFqFznZF_I_CmNChUK9ai184pQCdx_SeerJtQb5tcI8Wyxj7mYHqOp69nZ-ha3fnhwpohaKlxJxR4Cx6OikzLpZONujTa1WraUt0VgBQYd9C7kTQhne7IuWt7s85Vzue4_TGK4ydX8d-OOXkL9cYmIBLfOlYUUFvKP9xV0Gxw-7Kq4CkQHWoTyqAb0WYJy7lqj579zsFX85zi3GmAwc08AT2B1g1hwn6VbFPczheg2CuqIw2SZ7iT7m2rga2fOx-8jIwT8P7CsrbMHhfCEQKcRsiYAnQ8AQZetPTmg3pYavFlHEGopAzqY1-Ht07H0b8j6sHB9DetYyhooeSLr0ArEuX_cFPriBXIcPcQJ5iOprGUC4lp0fwYi35paACQToWl3uEYpPxbmY49auPQ_fZ2L2b8gIxBV2tWAqhBpShQwi5x1GS-NcG_YpCJso5QRxs3A9HJzaRb8CEE9GQANYu0OtlX7aOhUhKyTSvpvmUC4PLcO6wlETMfd65kSGKHU9xkmRPMJ7lF7b-KPG5Fxpq8J4XNj36Dv34SMRR6qBH6dIZLagb2bV3XPVcnml2QdXoFNI3HDtrOj4rQRDbZ0q5h3k3lsCexG1sTeDQKRoIy5QaG5L311ckXSTEVWP-HWFyUvUi_IQowxIxeCDcwrLQVs=w1366-h368-no
En la parte izquierda tenemos dos puertos USB 2.0 y el lector de tarjetas micro SD.
FzACAMPgSmIEBXdnsCXPO11Dd06ER5tOJFJc5BR2xHZ9gU1u6k0OfuZqJX3BF5WkcTEflkdnYvZg3nqg8VpQSCkjuAJ2WpE4F2t1VVj0d_b9BefAWYtzJOBrrvMznil3pQ3ZbMJzdVeUBnkN_E9WOTo9v40I1Byq95EGJJnhhLRQuFokco_BOEwRTkyms5Z82qANw1GpxfRFQc49bkevWyscElTkmE0X1LgQokvWFonC6ZkKQZkl4QzPZh8n4sIzgTqgyGB0mGc0XVvs8gbmVOMT6saLj0CtmNSwelZuJA3TdREqinZAUwggcnYlj1jfRKkWQ3BNT23qlMeq1GyYbKkOWXwFDCDjl4KWgMjzSBi9mV1P3QoEi-rmSiZDKy4I1shGTywr8hzhhFlnWwi5H29spWO6bAaQmhCeYfKxyjkumzDJpIEIFGUSTNTzdMPz529XMRyhblzrh97nCAgVSDoQrUG3sEzT7xdGUfRUg0Ddt_S6KbT8iNdlNvV2y5kNq0t-Yd0nIMozp9GOREvP96qjmBPPGWjfQekvVcZH7MurP0iFI2YdhrPif5_bNcpBAJtTzXZYoeXc1wp7oldFlFP4t17WdKrN57Q_jZbwYK1EC_oygkL6ex88zxe3f1g7qrUNt_nHllmR9NV60gVWMpjkfjOc4aFTS-fQBhfh7eizwFc=w1581-h425-no
En la parte derecha tenemos un puerto USB 3.0
JzI51hI35klXgV7Xjesy7oo61pTMKTLdZMMQtNVcF9g3L6reAQFQYnJGajZS_oQg0XGDZf3DJHha72Cp3mInyv7CV96HfkAw2ekN1lYJDqbkyul7eCk7HkhB440st1FY1tHw_g9AL0Up4aVRQNvd26d_iocfIE8Fvxvd6yG-OCqRchPzDJAslG5KShStIbaRfTs489EmJlOFy5NZtAK4YSPcTcmw5gYf22HSdmTICQprDbWb8tDw3FWI7KmLpFKB0iDrNHUPm_uiKyXb0TFA8oZmi-wM6D2N7fkc1VzhxAWZsZb7p_lBYLxFT_2UZBHF8Pmw8NK1k9aUuBY9LaKGcRPPEU9ZEhZxb7TC9bn7v6jt5hEFzwBz2guT2l2H81l7Z9H3WQAHtXjNjW-d15l3EOKK8BWWIvSqLPaRyGUdcY-HWI0TwGohVf4oUvWyYrZIW8lWJCPo9TPRPGwsbMVGNIWtNQU-7LYtGN8sL0XDkFOy8u2ghrJYql8gpwiIc01HXQD-Ez4wAk4153Wq21c3ErMGkI0CvpCyj54n-fhymc0QsddL26Mt8zMn-e7KNmM5klYLZAUwgv_T-2Egdgar2ibmUWkzpUIfsCqrco7XjWjIxKq9PQhmqS9sfXNNpmZfRZyFLy72GdxNKPscVRSOW3pAGcfAkZN1LQ21cPcYV_ptsKQ=w1590-h424-no
En la parte inferior tenemos unas rendijas de ventilación y cuatro soportes de goma en las esquinas.
tDhB7WebCYo2-o9oQJMoK5bWCCpXbFyu1-G0JoYBW0JUCi2VfwJlxihvJMI3xmCPDW2c-18ytqZ5KLjj-altRx42C05_xCxhgBh60IrY0F_C62RcMza3uZ2VFrPyU9nwJIGf7suHmnxqzh3UoNKRKCpOm459ztS-6_-4rPpSXYpehp_w8M3fhTVxXd9hfmvwg-x1AmOBPr91t0TInmsUa2aQrB2le93S0UX9raglNTcrxUvoFDw17FU7tn3ek5dv4LuBvF88NEPpmtn3QDYtmGffSzO2J4iS6x4MURfraUrLEHHt9j8-WyKIV5cJ4khuAegRxIfLuI_jhGQLPDGKF_pPDV7mHYcFkAQkMnE6MxbH8WyYMYiQOyXdPCeW6d5tKhdo5rDq_IQ30_yJ30qo5BkjIF0jxyf5aWzrprb7ztEzFbbuyT8wZBY-5wCXU9r4ewq_EJCoVzVlenan8_8v0cElG1SqKcgvV7N_6a5qfgYJQyJBdqfHo4LIj7e3cPYoAg3h14nGctJyiluT1t1vakmNcW0h_KZtGS-zsmOHG9uREoSPY1bBsq4t-4iXDRE-H8i_zwhr5L8zBVRQ1RRv847lB8QejpQTaSjA8SwYNk5m_YVt5qJmR35dwu3gad1-0gYwOBTJ2n0bpTe09gMN5XgNPoihwpTeY0z-MMvIlytMs4A=w952-h735-no
MANDO A DISTANCIA
nKRqTTe-MtSNMZ-X4oH7QLGANbKhyP5xtQoJcVJGhkjI5LpBAYNfyup9dHv-Bmjp9k6r-UE0nWWPu347022i1eyw2hk77t0GtnPJsgL2dfp5GC665Kt3tvrcLLisw3VTMudxn1UTE9O6DhmGmPfgeGDXv3Tz-85jhOJw9wURnpJLLuqX_fMx2Y4gHjjbNwS949Y1Jk7PfSQnEhPSdlHg7HiVYywTunup3pm6Vgis8E0cUcRG0teEA5xqMOY17B4miEjcfb12ND_KOKVNNnLJfcYzfEgkf-7oGNSMnJRO1wpHPYXBBvc4zXzmcvBUFes3go9OWYpwKIV5993tniANn72Qwtz0bKgTVGNgj6aXK-TCFKI_CnX60hSNx6AxGVBOO4nyUsI42zharFJ6uahWyQfv-gQcP-V8IwckFQYhzWxLgpyGS_S-SEy_i2pm2D3LtBNB5ThBvaxLouciRfPv1uM7SZ3ptD6a2TvUgY8M5ctPj-zK9ons9Y5YzcwpgL80YRr7kzW8G4bXaGYhxOjuf0Rch7s5q_VCO2_Sgum4j25DdjzzquSzanzp440du5YoWHP8834SY5UVi583FUD4MIgCg3sHm2hB-LhFO2ZXk-ROvL8gikgV6AfcBigxxdAVQgj79E2Vn9EGfogroFRnjXhfNNX-6I0F5QhB_MSBio5_zNg=w220-h735-no
El mando a distancia incluido es un modelo específico de Zidoo. Sigue siendo básico, pero da una mejor impresión de robustez al cogerlo que otros modelos que he probado. Tiene la opción de aprender algunos botones del televisor. También tiene tres botones de colores que se pueden configurar por software para lanzar las aplicaciones que queramos.
YqO_iTPnEDIbwxFqHZ8gZH2U2RoigCDHG5crSMx07HLcXAU_ZVHfhLG2FQpQDppZVz-QWTu8lEytMGC5196rLkxxOSIoKkE9QEKe9KjcSok3y7HGRAlcBsw4QSwtgbQzd1A8N5hFWKvb2jR8Auy3zg_tB_GjOONkerbX5o1J2oe9GWFNcvwGFqMLPstzWuobyDid-yNYwseJM7KGQt5J7Uw6VEdv0f0UiZGvaATZm-17fhiMVp7Or6MJvA9-lvir_QxkfqHvEILQRF2SEVSOyyANdD3DZSqMZBzh-o7HYFwgFl-sZLmYyZu1lnrjMU7n2FfTjDDi-nitw0z1VjYmjt3jvAC8IdQupGILXq6Q53lkl_YLAUPlHNLZCPLzLXNRQvc2_Jqu6rTWnM1mjbkKeKYDifJO7ZxoI19Uzq85gZjGPtzHWiGs5ujwnh6xaRIac6SRxv-Ml-g2eZEoXp6VGmXTLw7WR9MJtyDSeQJUuCksow0HdWhMcLqj-bBmJc_gYHF7brWl6pxHph1Nh4DqJhsaxSO-Vjl1jLGTg64tOSSSb6SlUNIhUSk8aybwhXpEEskQ_YNadDosEtZqXKPdzdoIOZ9KeZB582gGMEvEtkTFF9p__1FMAI1wNxDu6rITzYGBPAOdIgNVN-tlIlGHTS81of-RyJrqjulOBl9PiQF5B2s=w1152-h648-no
Tiene un muy buen rango de acción y no debemos apuntar al aparato para que nos haga caso.
REDES
El dispositivo tiene fast ethernet (10/100Mps) y Wifi de doble banda. Ambas conexiones funcionan sin problemas. El Wifi tiene un buen rango de acción para no llevar antena externa. Estas son las velocidades de la conexión ethernet y Wifi.
0iQOE3Li7blNWbFj1i_Hy3qsx0kE0eHBatMk0sQKCqPD-yCJMhfXsITbD839l4KCLlIePBOQvcWiYFarp-4YPWvlyohBw6qLuErTFtdMAYsAGLc8SvKbBV_3fc6wEw31s2ssRdBgFjtg55Rga4p5EppnIUq_CDwzSqwFsMgXDO-9S3Ua4zjBEHSyv0GC9IioA5sNuoLc4t00DNKAqE9-uEiLMnM5vNkiiysNQa10enPJOv-_u_0juhkII87f3meyaRzgBmeTyiNWZbIl1rCkYqO3KBxKViJnNIhDhLg-5nnT1vCz8eQxgyvTTfnS9-8a8O8z20L3mQW0y7LRRsXxDwxQniCUnUEhQ2Ce9E3u8WMwqBpvp1iAe3qlv5K4rVa-8wXMahGPy4BlhXwHMPYgImtzhcvvN0Lm3M4s4rgncSCMymTkriF3mLDJjvZtHO0uYGaBFWoP_ml43jcsumHckjJk_71vvIvy30mhETDRWRzFmcR5MsNw3yy3K5qnYWLalFYs-8tdrHCxWxXldzm7xRbhan-bDXtrr_jXGqyGZRs8ddo2zhFv9_pkcUHxE39Gx4yyTu-s_9YS9iZqdTy_gUkISaf_SQx5rIWjjj9A8I0Y3A8Mp7sU2j4kEDSSp8s26Ae1--cB0aeHQWIbisEVtdkIJtSFQvZ7q1JjJheU3iElrSE=w1151-h331-no
Es el primer TV Box que veo en donde la velocidad del Wifi, la banda de 5GHz en este caso, es mucho más rápida que la conexión cableada.
Tanto la transferencia de ficheros por bluetooth con la conexión mediante auriculares me ha funcionado sin problemas.
ENCENDIDO Y APAGADO
El X7 no tiene botón de encendido, por lo que se enciende automáticamente cuando recibe corriente.
Pulsando brevemente el botón de encendido del mando, nos aparece un menú para elegir cuál es la opción por defecto al pulsarlo.
UVbjEVmPEUaJqWIf4WJc6tniF6mwjb3orWT2SOdIGRgSnSc-19i1F42gNuqksqAdCsVA3bnyvxhOBrl5OSaU2qerdlv7zRud-Q0zShQiRzFgQlf7crr7gqiEbF-qrz5J5yBH7CkFyxfT5F4EkB-LH7tTcoBLvqiUS5o8IqzkcsklOcR4NsJOf1RHcSfQe_q_nBUjzMfxri7aJNrOo1mCxlaFy78PKoAbhoXyTt3dZZEzDY1mVNmMRczRkTo11SkT2yPRQt6R-Xpg-YRS_KGqpYiVB_i2oxfph_YI7Ly5KaUEy07UoGp51PAtvm2QQynnxWAyl3HUw0dkDHv98RR8Q2GVr4jyTJtVXb_2GV0KUkbv2u6Jx16nWkhdTGWfIGCpPnQ9CsufOB71OUjznlRBuIXn3SkD4d3ahTTlAnGj33aU1oEnsjuheRp-mGxfgmWvvJazJK9ETJhg8bZbeI0YN-RmC3IhfhrYK6BlT4B2zLC7_9gvlfOlIB4bmgDMD5sFf44WqbEvnhJ6shPZl8jJPaLa47WTJz_Nfh9Hc_G347hWSxOZy37lz9iZGRrREPhMtx2bJf_HBQb8h1KDXLg4FHhg2WsGfvt3-REU8NZ9hTIXhM01IEhNZpPPmeU6hZjJxr-rvwU8CFiyPXcQDU66dkNyFomiwcrj-54ar7Q7lJmq7N0=w1152-h648-no
Si seleccionamos la opción de preguntar, a partir de ese momento nos saldrá otro menú para elegir entre las opciones de apagar, reiniciar o dejar en modo reposo.
xYLubaEBlG08fB87FX4siE8hx-qi03OMO08YcbR9nnTu-8GkKJUwfoQMykB-xtFkENwJq954qJLwPAENSC71xUw0BqEDWF19wX2KJklMIwSaagHsgToAVzdUcl7HsL-QTssxm7Tp9gsqkMVYRwRw8JRhk3Dxr4GOcVcAm4pgUiQOaI-Yy2ARjuFpxAsz0F_oQfGdPwryE2mEGq4NEC3H2KCyyTT-mlyTdraRiZ4fwKWteDGNNllTw5mt8O9RzTU4bUhXZU6m8HIuhD5P8titqaDyaOWqup8QG-vYz56-u5dNwgF0PdAw2wqo4WzIaVLeFRFeJdVj2SJh7w6uc0d_SG7eCRfJQdA3VpFqwCoCH3s_0nx7OZwMyNJHuRARH3k-ES8ZygY45B1T1m8cVfoL8k45gIo2wWie8LMdomC9SmGFKTw3Xxe_xl9skmZj8ul_ECXIO76ZLQf2eOLUt-smP_LBAkresJ7l1deKFabMYLUUUbFu9jc3xkmAML-sj-7ljtuQ0OABAkNKUQscuTJ7h_gKQ-LJAn7F4RHpO0MwGwzyDHB-t3VQyFsTmb3vm8pQOn48KLKuj-IPOB3Nv4PM0Kh1_tYdhZBxUvCQ8MWqu_xRL8FHv90HFalgmj3X_-U_ExbnIunT1XIIIwjJEontjB1tLjwi5lLKR8d_MjG5DmWltjY=w1152-h648-no
Lo que no he visto es una manera de pasar de este modo a la pregunta inicial.
Desde el mando a distancia podemos encenderlo o despertarlo sin problemas.
SISTEMA ANDROID
El sistema, con un dongle USB de teclado y ratón inalámbricos, arranca en unos 15 segundos. Uno de los tiempos de inicio más rápidos que he visto.
Lo primero que nos aparece son cuatro pantallas con la configuración inicial de idioma, pantalla y red.
4gpiPMqDIgrc60R0-D5GO3OxZvMBC_xewR-8cs7cBqJE3ct4BBSlkdKobA3vTUY24dXieevnDXRNKaj5YBQ_YpJ9Zqmxz5_LDL3UiXNcLtNckiSLq3PSCKy959V59inwum91wl-2NMvLxoqNzfSfSzWK8biFPl0qVAi0OcwvcIL5zNDcI_RJIdanxOw277-dmutQ0JAn9lfYttMpAtZCG0WljExGEoEjMZFYCF5Es3bGHUiWQ9YpQxQzTuSv7cEIdtVS7nMYPVhFGpP0XwiP6fhqfRR9-O3S2wmlGu9-xOO5-79MV77YJgjt6n7F68MEGyNd132ek7HWC3UasiqpGPeCjx2JbIy0xBEU7F97QFW-tq0j5-Daw5GgjS9fbBC6dw8vneiteiTfYhw5TOO1pppaM9tPcHSG_dwXvFcssxW7cSlFxx0EVdMAsa8eFfZYQ977WRFmFTuz1eUkI_6KQ4FVfTtYQxwUN8ybxVW7JKSiY60KE2BowX5pfs6cJemsYoPqqgryuarTzjqqjtm6CmkI0Hgv-TPUe9Kw79JTiqfNY3FDMne6to0o274ZkgNTepj8guGS28TgjWVFScU_Dgp1BKyJiDjTuyCMfhQArJjYaHLypDKl2my1w7q0qfQmBb9YSIHf5HDetgv0l2sRFsL5wZe4hrTRcV6DQG-IccZ2FWo=w1187-h662-no
Nos aparece un launcher realizado por Zidoo y que tiene un diseño muy similar al launcher de Android TV.
tvBC6JQnFPhHVzfHdMa_OX5WQ52d2Ef3B32zHiPJxS1Xae8NP0DaRJO3ateVIGAw-_DUyyQBG4U1vCTH32BWkYPbc-Xhb7g7W_PXfws-mi4RvRYtCBatYesWhmkZGxTVjZjExAqk2T6D98M1NcKYX9xC1CXscieYBZRrC7RgcDMcH4phswLUhXaqeW9GK3BX-pzPXLiBzMsfIuSSR5vCIKWlksjOVUiE-UwQDLFXR3f2ygi0tipkW51OthqUNxCOKIuJ8BBh7E48_K06HDDKuF-mDfWDaBs5AEiU_VzY-NJEDFF7no7JxvaU2REPor6QhfQRw00PYz1hu1ZvPOM_qxR1bCmpI10HBALOUjWwesP-ir5p9tLxiFEnwhGw5955JG4FLtX6KcbDItdRS8bZvgdWeMDfYtARfD9zTYOfdl6wAd5oK39RL9rW9vKtEClmz0i_29vP08uottuj1XWo6OKTkQIeveq0R1h9qMghVbuxezQbM4Pmp7dx1rLqcvJdsvvet1wJsXQXtwJT1oO1aKLxMQtCrwn2YX5XJFMA0zCAQgevKe1ThwzVRqKXNF0X4XtsElHA92iQWzegzBEvtGUpyCwTm8zJrbC9enrgTRn4AKDjE9RaWuwerzjB0_47w79LlO6Pthlnw0vZfs1M1gHPQ-p0OKJ1FdkTpRaTq22jAKw=w1152-h648-no
En la parte superior tenemos unos accesos directos fijos. En la segunda fila tenemos unos accesos directos a la instalación de una serie de programas de streaming elegidos por Zidoo y justo debajo una fila para los accesos directos que queramos.
5OiGMPIsrgmJQtGNGGb899E_e7JwShD4KzrGE6e-G9I3OhMO2FSOY6BsPewLNL1X0feIQ_PUpbVRd6mPIGj2Rx5YvRcP8eQwkUiQ9vjXJzY3yNdxGPpNmJGTx4xtYkBDl6tlsyWe8SRioMFIcizNuw8KjC92_pXxJ1ke1ElrSKbD6mWA0OFtERknaSl6ambaELVo7IVqFt1iVITucHd_hs_Qk4MpliQXqodo4_6VT2nwY31W-Qkg9_0d_mKTU1g-TJAdGaolwAR-7l6RigzDBX5s-MNHwuIVr6C2KG79qc7up1MD1AGy6ognWcXhf4jKWr5WCNkoGLrXStb_7HDsHpA7gcPuho0n5O1yOOUC4yb_su5MMuV0-3k_TTSHmpJIW-lMDZ4_9JFS3hnJmrkIidj0efEwJMJbYO-l-w4WxFbuPrn9UlVnR_2fZeuyuhn5ZOecn9ql1wefQY-YUGwCv84WBp_PPRRDf9lAvpEXsozwCV4nRrbqlPB9awPCGZmknG8yiPoaiaBz1YhctV46JZCsXEQmUF1jH5jHlmWdem4G_H3EyG44pTZHdfwgNnisPtB6akAUTJMSWpjfc4GZZBEKuvMou926Lg_EEEMhumqu5fvwDjybccWx81xztCUu76QdcLcbjdjdtF44rb6fC8_i8DM8ou_qzkEi2f4JHkVn5rA=w1152-h648-no
Más abajo otros accesos a la configuración general, la del bluetooth, la de la red y la de apagar el equipo.
bh3pitgrIxvMog0q6YiQAPrU8LhcCJ10KgZ2GpO9plXTrJnSQTunhGqkYWMEfsHVxo9MSRTkO0gwaSgDV8jE_NggAnIbdVcawEfd-igQk4bXu1AMP2M8rLJrHmVsHWkI9PhRocP-UqAkmwBJVL7UlihbxPBjiTG1ol71vSgPbjggxbG-K5F0OI6drAL2IR99eKEWT4O8Hlvc18Y3cGxxUZMtCZ6vmcV_DdFanU6541N9bMIlj9CYs61dqgsWeOIr3zVm-5va_liV0zh4L0CbZfXB1px2BKFyHTXwUQ4VH4ngY6_7akB4I5LsALj91cXtwLNviFQBQDO23x4BMg1LYD_3RC-W71AURQGbOzYUd43ddUuk6NCeJsLCXCVYBfoqopJYlfp10HGQXsKH3tJsYONlrUMkTjlto9RdA7j-tpDhOp4fKGHTSUKO34xrMnKLtboIkooQMEmeltVmMhHR0SkNVHBgZt8nnw2-6026IqJ-Ri0TNOb4t7gpCdTvovQmD3JYVJgifO1V4XOfAujHpj1uzB-OpZ-Fb40-Egre57tG4q-qb2dhFrWsv2htJkC9lKLsAIbfNurahRFsVjkPo05xN3J8KB0tQMEXSZlkFWeCB8i_H6Iaqs5S1lIZNZjoFQvZZCtHDiISz4z1f-Jl---uQVgJAHChOU1iLhA9ls8P0W4=w1152-h648-no
Tenemos acceso tanto la barra superior de accesos directos y notificaciones como a la inferior de navegación.
6raWs8ecmoAhOHyvihgM2E-mSSuncp7BhDI4UH-e-uEYdSKiELj9A_gHpDKD7V7kGMOURUowWDBD1OrkZAujeYq4KdTz6LUD_qQG4Y_R-zZfbROhIgkZBr7fRHs3bV8KdpDMvcnQbgFMr7NvxC2lrthFAFGMx9TwAlpCK3h-eTEYfH9mozBlRVUSfOlBzfypj4JtRu5gbjy05z-XfNOjQ_ED9HwgyaY1deOtzimht_ozmh0W2oEYRr6U6YLq4Z6IxEe2tOOpyuvqNOnLPNHdlqRpdiLxFZTxaZYQ4krjQYY6HWnHCG4niFNtyuMQLnZJwjrQ42tVFQj0QaCZ00jyCgZSn4UTEzDAi63b2VXdWgjfkcouM9GJBMnSJJabOwM3l8GXvpSoCGXKnRwSLox0hoMNn6OwY8YiDN8-Ba_K8Y_josQlsO1Bfj5IRFe2IQlwSj92yjfsivD8kRyvwG2dnERpz21pz8apHWWSFOkTMtlDpnSpp05ZtpN4u8wKkB1Xt0P3P0tVvQ3Y3wb6twdLehYLivM54PuxpC7VMh_sI6ALzKvKUdPD3u5Gm_GxKuq_3FxqyND2Zi-nS1G5aworinE-bvtNGO_7MQbXxTwwuo0epAFVfM96k1NqKJEd53C2xv_1H0yrtMTdtZnhrpqb9taNdBJZBUYxZ0nRVjGnOggoSgE=w1152-h648-no
Tiene un menú personalizado por Zidoo con el acceso a las opciones más comunes.
h3HU3ybrL6_vEDWYJzpg75pbBCQsumZZID70QPuxvGIR52LndimGgKoCW4HkaxlXuBoaqHT0xvEtmX3wGaGhd3OQ52Q6KBq3DAAuvePYeKLC85o4prsvsOc7CQhtGp1IPtgJF81t02htli3QtymUlm7-iuXsg-8naPA5ObUUeFgRzG-Qc3Pa57_vrihr0Fd9CRhopEka0oledB5gZMyDX17JFnG7rIL7fayGNyALIoaU-qyCDZa5VHfyKybCdhZTOE_18aAViInjLy6C_rqtbopDz9Zl_9qgY-Ibqo1iG6HQidlidcGS7115_I0CoR84yC5fUNr-k1Ol1fsTXTEdsDpmsXPe2wxk7Fk4SzNfLJ7MlpZstJh7YhXO5kOn43oRT9MnnhFOynMCHTh23itSgQ26hZakYwZ1No54q7lnXeaHorEJC591cPHOO0bAzTNxBmXXi3IK054oVZP0VOoCikmercbYg97A2Bu03ZlS6XMLMdc7CTFbBYljWVNdZ3yvvohcMAYpbJzepDHEDG2ic4USd4wRA6m2weAVhN1zwjA-txYawpnNUnFz797LC3X5_HLm2Jm7OIjUNJhJBlP2-WQl_LNOAQm-3nQ0YuCqiZzv6hpWcX2cbpe0iYn-L8A4nRF8Q7ShAT2b1XDPLn_kitxCu_jC47oc23YCCyCA8r8zYkw=w1152-h648-no
Y también tenemos acceso al resto de opciones de Nougat con el típico menú en el lateral derecho.
ogMMuKLjy5OOY39fqlR-FMKq1FGQJMGBGiuC6IdHimg9-youzKW7m8XkeQgxELLOQ-8YBN_jmDcAtjyLwmFn1szOFSSFU64q1YZ8_tt9_j-oJRf25viMsmuNbdwmff6KvwjEbpchviU4kXuPrqlFguBTl94rLr1jZXduaRCVWW6utwdcejt1saoHFhy5J6FIQMbJSVEZD3pLLLORXHus3g5A5Q62JFrxcRFIPQFZM8Ikjk5sE5LtLeqiCCqm2T0pQOjzBXLz9DlAzxpksajktWZ5ou6K_EB7OtxRoBoAXsHXxuoc-nb5Vew8i_sPXU_5uNl-LwsmIxo-z7o-4hzVUW3rjNBlDh43SGHhV2cMXssCFybsQl9Olz_xe3sYyH5MbfV4WyJR9-ccaQf2dlq_szSXRJnFtxj9aBfHVywep_FQNFRxd6zsgfxqyD8mO3DMjFz3nPeibJ-F5dbzHFpy63NNPpDQvuEBT_mXSq9s7DBVX4vFrwWYNvGb4-3Mr8E8szxqc17SnnQJ1bVA0rHZ7a0hIOiVoqmWRJvbgELcec39azDxS2JMwdrKaOZ0-FDeMxEJ_VUJNm1yl_OjsVctgm2BzrlVzBAt4_KTLxz8doQa7OMNiThVflHG9m2AKWMfS02jWVOMg0UWNELvqnVZJUz071ZJbw7VLvoYUwVkW1BgS-k=w1152-h648-no
Firmware y OTA
El equipo viene con la versión 7.1.2 Nougat de Android. La versión del firmware tiene fecha del 15 de junio de 2017, una versión de kernel 3.10.104 y la fecha del parche de seguridad es del 5 de abril de 2017.
M0RdNdy9WYuu4OyUaHn0L5NuJx73tWkUWILvmUPBESHnVWcu010k2HcC8SkZlBd98yjWpRQ5F7uXLXAUd--UyRCEruVyGhCVKxm1g1Xkm_ERN_hwi2J5O4pHZ9nchd3YFO0iq66oALEoUWKJJXXUroxj4UOdP0P1PEAynQcp0_E1m9TY-t6-jA5ujUBPcdJ2Y8opCkNasHkzlzC736DCANcuwCWU0CvXVOvy5Hosaqef9XXoZr-JGQg6xEeboZ4MLnM2dfAGtaQaehCHEDmwWdpuzXwLuj3hb-30U4IvwWq4sweFUs0K1GZ0lGv-f_cyrfWK_Ojwkx2nXbjNU1UvO-v2eEU9JRG8qO9lp8rMbO5a5nASEmZjVcLfZ3fQxQN0Uv1dw8k9VRs0zay5V-q1wCHaxEB83ZM-Wx2v1hisBmc-NeZdzfZqevCwtMe_rWmRocaikLb4BqAlZRv7J7YBFrNY59Z873BjjJJ3C6fRrAIGEd9GjqGUNJd3nEWe7k74dBy9vnKHFeJU8PhKJJ6-rnM-su2RPqTqANI6yHJ4UfHOVWiHLbk_VOD9qQgtYwLOr53dFpi87lk3LjyyAoA3Xz7wxMC_1XkhwaQu6jIULfoNrShgd4g618y20Xu_1xevC2D2huJEJIStwVW52TwGM3J4nsa24BMWMkkGuIfP4j0g9dU=w1152-h648-no
Tiene un apartado de actualización online. Nos dice que el sistema está actualizado.
uJXhYsuv9vvF1AMzvgjxqnrifKKtlGsC8BtZoPaZIXcL1_c2VNAJGvxBCNnjn9VyDE82AZUBX9YzVmsoJK0In6fEGXTyufRMV1Y_hBfrcnupsnHu2YAL4yFSImW3EVTEkCl7WlvKcn7cIWRukLm04xsiaKgZBikjSoHiEL3iyfG0lEriNbTSFkNGUIxVet_DMnGU6L4cUUgjcml5JenaRIxWkG2k8XEOkbOHKEAQbLS6-LEqIBI5Iw0zGHvRmVdQQqX4s0_-emy-UouUf2koQK3F0oC0WzFnwxE15Hv1sZsaS9KTnuZXD7u7QZ4xeMaIuZhyyEC_1gl-bJPIeVKnNnMcI2NP0jRFTntIHbpbGfB-B_uyTBmlMWNAH8lx7XAWnlexuxh-HzZsQ3g0OjEf0UIU-zLrY6lsPhK-AWtq51yIoU5Jk59a8U1AJ8M_I9BEuwl3cpRnqNg0ynms6xUkvgTkjqoLretj0wbpg2p6xokFle6vjFYXci8yZo-m2w-AljEvfTfLlIg5AdVKycgebFRCN3YhLdRl6IsIQ9CB9J5nrB-bfZEC-BYupXtdXK9qjVCGvj-c201QSh8VB02kEbjxs0VjUAbUkVwYFuDbXoBKtfZXSH5ReeFh4qnNJg-ftcRdQLmwOrZJL9byzVt4DqajaHfOAH_M7WjvEcu6mFWXALY=w1152-h648-no
Almacenamiento
Reu8fjHh48BjlY1RDo6Dff2Fnam48vVMxdgqy7101Q0GK4_p7XOjN1YSxm4Dijn6R1koFcuYnEphsni1BM9s-tDZENj82aKJsi5IfFaeJnNcSmtRN0JtkVPw4fzasTYqBwAuADdXBOd2bKB5Nm9X-05lPs5Ufm0YdIw_eOSK9erUtvq0Nuyj2KNOpEMHc7Tl5gUo1W02XArhCMCSe_DmjcsI9_V7Zqa-jLxCyGl4_cENDfLMn1MgGOTxzy7VM7bP4PgOeeAJTk6hDqCaR8tbmH0s5IojQofRbXst73k4fbYe5ko1q5Yb0SsCYynkgQj0cMKq2_HvR90zGtEgQUPwUZj0I7W5VqnRKC9N2Chttm7mInZ6NxukMrlzkE1fDQgUtjeErSrW44nOlcQipuoH7_keqw8Ot2Nu4CKCcwbQXv5YNdyQUzeT1JtI7cNhuhXbgbK4uuBfPa7QKlClxzC-9RJdbuvLxb16zIK-y0MC85w1xv8WFwCBqcx8jy53TFSshVvRjlV9AuDhjwee4Opd4qiacWidG0DKDV-Bzg8BJDYIXqFzQzjUScsLI45e9L_B_AgjTWXg7VKn_a7Caw1h6VegvX-HwbWtsRZKI79zfnITh0TzcnaXY8tUkzbC3459de9ViYKgC0iPXNOJrX4T4g7GHBECfzlMMEnmPZSIsOAw2Hw=w457-h662-no
Aquí tenemos quizá el punto más flojo del X7, puesto que solo dispone de 8GB. En los firmware de los equipos Rockchip suele ser habitual que el espacio esté dividido en dos particiones. En el X7 no existe ese problema porque tenemos todo el espacio en una única partición. Tenemos algo menos de 5GB de espacio disponible. No es demasiado y no podremos instalar programas pesados. Sin embargo, para usar Kodi con los addons más habituales o para ver contenido por streaming es suficiente. Nos tocará añadir una tarjeta micro SD para aumentar la capacidad de almacenamiento.
Salida de vídeo
Este soc de Rockchip, como el s905 de Amlogic, es compatible con HDMI 2.0 y soporta salida de vídeo 4K. Sin embargo, en este caso no ha detectado bien la resolución máxima de mi monitor, que es de 3840x2160@60Hz, y de modo automático me ha puesto la de 4096x2160@60Hz. Esto provoca que aparezcan unas franjas negras en la parte superior e inferior de la pantalla. Debo seleccionar la resolución correcta para de desaparezcan dichas franjas.
sSVA21h-7Nnk48CB8xa8MZvcqON_5DBVgMN3Al8m3aGJnwJo-443YRjl_Tb1Y-lzDytY2Vik8dmJSXdoW5t01Gt66gnPyhZI4ivxDLJ3fKT-HDhlf6nLi5yY5dQw5maVCoIVNI6z_fE2L2QeEE371b1l9JuvMGj304lPSPw724ReFBHeyhnJtBWy6w38f7wff1svyKyDq62vuK95nDjyLQIxwG1QI0pNcxOCy8lw5xGLwCZZ4eufHs7NcRktXK4_2xGKjadQCQnBU6xP_gUvasTz-jllmTDkXeKR8pUtcWXTslpVKjWUMIIs28ycaltW-5GHrq2eU2z4kQKrl0juCmqk_7Jl8559cnueV2yV-8LxMUJy65CLov6jPHNcHIEgPge2VxJFAkn6UmokKBHctl_74UnXlyIPlNNjnS8lGs_Xwvb00vUbkH4MBlhoHjFMGbJhtAKCs_pu7Murnwd3nOHzLdjKYE8r8iSkn-4aZDb2JDUkSdGU6PIdCwYIrsc0Ly2bRp9cfCY5L_gwXfMp4Lr-03puV1T3xhHOpEm1hsRzxyVkH5TLoY8yzbFe2ZQ6KATmW_UacVCTBixU1T8QIMefzDq8dfpQfBr9Lozsg6kBzsEzA7GUjutbuIbYTRvTsXzKQC15rXnSqFzLZCf2sN4d9skXhdF24NGiICHyRpcAo8w=w1152-h648-no
No hay opción para habilitar o deshabilitar el HDMI CEC, pero ha funcionado directamente sin hacer nada. Una grata sorpresa que no he visto hasta ahora en ningún aparato con un SoC de Rockchip.
Software de control remoto
No hay una aplicación de control remoto. Supongo que Rockchip acabará sacando alguna, como había en modelos anteriores.
Miracast y DLNA
No hay aplicación para transmisión de ficheros por DLNA. Esta carencia es fácilmente salvable desde Kodi, mismamente. Sin embargo, sí que tenemos una aplicación para hacer Screen Mirroring o Miracast. Lamentablemente, la he probado y no funciona bien.
WPayzsgkOCnQ75-oiFAOVF44N5odtsF5JdYPHC4lLELy807WrAB36xaw67AtpR2SZU5gC_9esmHWMrFYBm1DtW7n5uuBf7gEKlovRSIntVcvaSdiT1-K1RoEL47q6zBSJgH8A3WB3YoOkOSJs3oMUFi5OaJnzPhM0zWz-GgqFV3BVE3UGbjQhx4bfw1o1G_1vPXeO1QBfADN6b3rCYO9A1gP1T7s7Sc79R9kD1YS7i5ckASX9T3JDKUh3QSadrWo1PL2QOMAZt9cK15xQthRUkKdsYsjYTq-vzCnzgTybrEjmij4zsMMh0HPEC3Kx0fv0CtbakhRtlvBgPFbq3YJiM_kmN6oD4kxnzzq3S9PY2FQQa9TMRoozZb7AY1QWNMHap_kCylHD8Pp0bDxzTjSs-jt8EB_tLTsRFcLgsnrvttCx1gWdB52OWJvlMfUFgH0LUz_otHnKDMwLpRrMkgRYMX2_xRidAnWoHzNJenfrmo-LaVE3ZmkDhgAiptvBEu9lrBvsH8B1IAlWcwJn6GTROCOSlKvlAOCj7FVjQHbVINcvWo1326deuWrSzoaANx2Led0xMgPVCpZfa8PsJmO7oDt_oC4hdKzkt7elsnuW1ifY4QPRe6P8BBPLCuIGtPn7orXdWwQddiyPjWERXIp_7QbnxXUfTDvem4vcr3ObMDeGOc=w1152-h648-no
SOFTWARE INCLUIDO
Estas son las aplicaciones que vienen con el aparato.
gqZBpbvnFvr_-3NuNLOvlIyf0XQpytlddEzPMm6d3TQbisJQWDHk3oXg5gj7jR1ZblLBUUTaMHDoxYR1AGVZHgWeiyMzCtUr-vm7mlOOelxFnlFuXW6MKogyq7CHOP3AIpxTYvprOU4-vjwtBh-ciZPaCBFDHCSwyiEpU24S0pVnJZ0AU32iHsaUAY-dKPETcp6viw10OV0vFscmIWULe5YJx80qsXRqZYKBkNJKRmrRCLfbG4BpBpVFqymXjh7LzYAFuRypLROIhMlWtjo_kR-77O3L3Imj0I9mWa1GfW-LykAib8gn01nh8WCslhJ-EZ_H5JeIK5SxS8guTTFe2VlTJnm_mwaFj_oUxIwyvpc92w8nvAzmF7l-PIriKaMh1X8BQq59oOd7VYP6-Tkm0e6lsMxMvp1Sy64Y-hZnS9h-_1Bn7oUmWyg9SeJp91W1OnO6-3dnmuhPVubneVzyl9xiENvERw_mqnMrNbmTs2_MNwmpO902DkD92bQVJK1FLZsn7WyHo_bNhKo1mmtM2a6mzsYzWn6i4-7D2o2812IqJd9KAol6NlvU-XvmmpY5Al2BQY5W2OT_-Zd6WpfhQDmWNZQzoLu-RFDwQ7iP8_4jRC4gd6k_z2aZJ2uSwg2bgbmxjYtb5zOatAZaO5ZG7jBLAOTwBzqAwgqNZqnIGO2CkhY=w1152-h648-no
Hay una aplicación en la que podemos configurar una ubicación para que nos muestre la predicción del tiempo para los próximos días.
GhwdVGJllMSao9McWbhN-10XbC5K8p7QGxEtGsI7XLwDMhQWHEWUnwemvAXx7HYkZAa4frWfXHDbB7Emu8QMZcWdkYjBPs3y88zROpLl5z4e1p6co6TqUukYHmOJlI4cMLRvXAhq4eDSu-WTUlAomCR0oRJlmr7Ne3ab3m1e2aV933cPTLh7YKMJ6LR8z6N2krM2CcDEUyaOEXMDbd3UC-7ZAMxPVneW1aALcxJLRu7Oh9gztuBzbEzXyUOCJ9koKHSS1SJMGqbWZ0WZ76aJUL21f208p1-_iG0F6wzwGDEreoIEBRC75CUXTIw-vA3KSr7knMhc_tBolU8dQvB4yNbiUzv3Pl75ZsBSAcvaZlWSJAHI4Tt9OsSWebplLZDSfnwNunuliAX2FTG-WqMUpPgOdXNFXVmHvud4iBLN0ms4FXeKR6Dd1k2Xzt23yYzmj2Ch_MiP1sRR3hTGrWiHWFH_4iOCs1v8NcJt7hb0-lSja-LqwcpihK3PR1iK5ObBmZ_t7KbPWwBIhTlZctgwtxqx-jttU1n2Gw_YC2VmPpRUeAGix0vXf1CrCul_kJGVrJFyzfRziH62sZr2oqoPn1879hTrluAN0Yjlr6jASXXKhD3dBmheCVEvrkRV25glWCn3K1_4aUNe3W9H_HjA10jN0H-TgTRqbMw3YJFjAsn2uTs=w1152-h648-no
También hay un instalador de Apks que nos permite conectarnos mediante una web para enviarle las apks directamente desde el móvil.
rHuYpv9OpoSGf9eoBbhAreinZBBnZKCDe_QDIBKeL2Vc1MUZrG_ZpNTxwx4m1wQgsOi-caiXlR95Rh02_Wio0CdTlRtkW_807_QucxHMkfisfmSD6HcON-Um8GMc-G9CAZLWLeHP_v1dNUzy3WOi1vJPfkr26BPbBHHXKu3bZvYb3rtRgS82NUQX3CCoKPx0AxQP8gvMtKA5khXojS-EvXpruHRNACuYhy9Rm4VZpSFtMHDyU55kcFrNHI65rQLPD9wofAJFCICfKIo-qWWlovsIrX3XiaM6g5j62z6lWGo8Ev9QRQrpQi6Ujg3-YN2uCm1fisGZSdCogvDgGv-qNDVm9OLIj1ZYz9b-FX64K2nCgAOR-k-Me1s9Safs8qTJCy5Ix7rPVzkQn8tSgvrv2erutObKTOufGTom5JFq_2acvNbt_9lFKkJ9nvdqV7oRPpL74RxBE_utCwvWX4AinvnMJk6ABAw2u1sTL5r4hHFFXpI2L9UATRQz3kxR2X9gD58MAD-fcuVSrThtBJB-wFKJxPapQUQMf6_f5RHzkfWyZQnlVvezfTExP-LF6rofxlPz_YXVNPT6aFekDVS155oXrewpFwOKK-drT7A4sRHCddjaFq6StsojJPmOqk0EapW95TMTK81jY2bwKKMihHDFgGVeDrjdi9VbEjeSUENlYoc=w1152-h648-no
1U5B9SWBxOnJYYA8GnqStU5ueE0tQaseqlBQhlmKwN0arjmzLYMAks34FvwHChBaIxbLqJ7I8b8VmzRuhoJhrdIF8CkkWpbLbB1JN4QzXvHqBeRt7WuaCJDxg3_peKMGMR95hVS3G9uEo1to3si-NI5Ywry2N_3xvrsSz6pnl3wATn6bkmNfmNUjq7ZQmD-_Eszh80-NHAQCLFS6c_wcbiNOMoixReH551KXn9Zhd1YwDwxSqDJA3WiKRvlWLiLhLQ0jG6vPGRzbn7XPI__nzxSSvtmUXVUOxJRPU0SA6-s-H0IQW709VXgVUE77WDennasbRBrnz0ytuUd8OOtzFzdUAbEs9rtVxWloAb2HnoGIwRXyhtKxL7j5Dv_uAwI6u9FH1C-lEE8pIgwxv8DE_n6JSXEYnwPqf4g5jdr9xU0Qhs4DGPK1HPiv0kfL31v9fl4V4GBg655MYEEh4pmGMOBvWZX_fb1h87zvaWSbbwpJfd5G3GwmnHifgRWIq-ZLVVriwpf4Rh1EP3HXCd5TI3iuWkQGOiWqhuP3HqtJ93Cq762DV3b4QmCrdu4LZD2j4Ips7AD1NQUJ2A2dQspFgqYcbEaqLqbsaFnmDqqoNJyOUpuP5ODlb_fSLmnIKwstCjh50GzJ1LEMRWbJjCbCCz69-EuJSvkU22PGcYolLyFjcwc=w529-h662-no
También trae instalada un fork de Kodi desarrollado por Zidoo llamado ZDMC. Internamente es una versión 16.1 Jarvis con optimizaciones para los SoCs de Rockchip.
S0nssAyN9w94eZTNtcfHrJKOnVSjBVJa5DyvZJiMwaOHwz6JQlbfZz6_Nx0tpnLgXelxkEUuNliJDfikCv3iENvPMUTW0XaZ5vx37GtpDQEetgrjmpBcZHS6yP32w2eXQd0e-Pi9jbljUDUxvtU-zD7oKsMG6NbK-H0PMRMy4txb8QT_d69TnEADvA0aGawkUOI1FnT9WwWEQaEyr0zV23qFW26CRkzwQD1msIbM31gf9sSwTuPdheUcCwRkAUtTUrfx3RHWv5Y_wAvlp_gz9Bs_Dn9dJGAuan0nPKmJ95jZFswQpBaYT8bn57pRJRWuMUcDyDCvpTer7B_73Vi-O9WTyBz4w-VEHdGsDAZcq15Sz7teqmQZJSFdIgrzvwFgvMfyzU_TmZxPSZYBFpLnt0th67s-XZgCj9U0iVlUh23I9S4yYpa-ZynqZkK3mhTe36AIA9mjJo16B-eZyAsMXTyWO5FZDu0ddg1vCK9EkC3Ev-sMSc3VkT_RELNYgsJaUmC62N1U4ZnUJezw4iytptYuOq9kmMJuoRMlCBOn-TXcViholksTjxTpD-cepW_1QEFIVXZQieqCo3w1JoVGgc9enJb_ryoJc5GoIzyIf9AN-RinoTpa8RL3faLdbPESIjqNja-t3nYAlE1_uDpFvrS74Gto1DOyKtXXNIGyFqGbllo=w1152-h648-no
He probado los addons más habituales sin problemas.
En cuanto a Netflix, funciona en SD,como en la mayoría de los Android porque, además de no contar con la aprobación de Netflix, no cumple con el Widewine Level L1 necesario para la reproducción de contenido en HD en esta plataforma.
_tCY7aS-tdiLq6_jjhwxv0QFxmKrdDAIrVOCuxtF23PSVl7fCYeJiLeQUZJYPWyIW_kFL-vR4_EdALUayjLH-sJquuEyAO0by8H30DxWhIwmUbzpHkVKAYFuxbiyNlM7f29JRvqXq07peSh9QbQEq8tlKmEzDf66Bl5NcDEm2Y1rgBK9aVfU69WM03YhS-BQcBoo9Bbz7zZDikgdN9Ch3oXxBRQ8CX5PO9j5BGkXJbn3mVZauRevuGPc-YK_v0EXyXrv7mMISvZFcDQ1BozmxffCv6-UsMQUuo8qrT_96NlgFXISd6HuinChDVEA_EQoVHTMAuzLkMLCSYT-8AVo8wuqVuWBvdr8tKlsZxi9cXGJhqmwzgXEQrpddEJNsgilmHlrujrMxyEi3i_cihYBeiOAMHnAC_aGCaPn79PeRLByiVDmyciCPrYqlxds6GlTyAvsrLzg-MyC97zmJrqHxnkEdPKnJvmFNbBCAE8c2fipv0qfvebe_LPU_1EApSXTIqduQsN1gzzRYwW0lbmAaVbEiZr6EYK9WTCPFC1t9pNZ7UUdi4RrIeAWcUZtZOmNXIM90unJgU-88OKNhbRZLlzeNx7u94DUFLXFmN5R3K36hGVvqw7JFsqz5hnhatyQPB1SIIF2HRXRwGD9hzkGHgLt9ECvjxcqvNKgxpveb5oS3vI=w1152-h648-no
nFtHEZ5ripsfRCohWCJ0EDm6vP9PEZSFR6HLRYKxAo6dK0IhvXGGwnmOk-6LEy2zPlMkHJbk6WpQJhFKRSE-X-dHRWhH73Uu4SevvWA6oc29Kpr4uRglgGB98GqcHV4D9geqy9vUMC821xZjCrZjo6h0b3Krl0efOfTxhoVrTpw6e19XRisYvyBsDLSXVJRCSQqtXTrQUDnNdQ4_HtgxptNmALTQMkC9qN_YpV4SJA0tvysQOfHyOKYCkAXLhTftNWetIP-p1_E8C8O0X4FIPkm_HHqTHWMrtsUKpBYqGIqPgWHIDYbdSR7IZ3VYuPe7RyqwLyLZJtwIli6LgZENLkBnX4bYgKAo5Yy0W2CCG-qvRozx3ebKwzUTFL_bk7pAkMoa6W9cPEGrhToT_dt89h57eS-pfClHfwwhvdG5ax3mnL5sCif7zNpW4ApafiVBAxBJyPe0kz3f57iBoObz5IrE2ujXNecxN4LBLOeFthKS2BEOR3DFYZ9AYCA4BZFkmr5D-BAmoBUhGxnV9zT2H_1pC7JdGioK0FAE8N2EMfE14icqcP_tbLzDqDzFBKjdVAvhFrc3uLSz99m3QRtbn-S7Q0o34efRsJ2_WbDR150nMiA8xwHGo-azc97AkNcPrBQce8W-U8XDxNsNEHQpk5LTk0W60ueX53mdxOyvLEzX32Y=w1152-h648-no
He probado la aplicación de Movistar+ y funciona de manera correcta, en SD, eso si.
dewyl7ukwtQ9mnPv6SakNVpOTq2XlOWg9-4ntWwR-7W9PK7GfEh2AHkRkW7J9NffHUJL_uzjpe7_uSQknxkvNW0g1BLUI7P8oEHqBEnPX43WjazlzgJIRt7qBHvHMLBZAiiUEyaqcscunB_Lxh3jSpqGLWMF378m9HVs4IiH7vJEuJgGcXTQCcHj7rorzzv2D_eTsBuD6f9kSbJzOIqkIlwvmb2w-wywBHwXdHmrUC41gJuCuHX5Apw1l2ogcj1IgPqLrPzT-WUephjmAPCHgA33Zm-W-FpWTZYoTe06B11i13hA0-MYwyIXjTPkr4Wn9WDaGhozP2dZxWg8FCclmXNYnj7crlEMNfYV2xc3urb4GJaym_pFJWE10ZHzS1Tcjl7p3mnB0M2yviBMFVZrvVvFp2Yf1Cbd8P2uPuwUg9RVgewnI6EcTxhGbz4LsewPBy0aMO-atXCEGpF58biStxHKwKP9J9v61ODCXiIckTYhfXGRSwjHZZG0Xn1kM6aoLQExyn3vCB-olrp7T_dDdjbndbcP8nuiJFi4_o8GA_0zmNKBDcbIRdpZcAHLEoP3Ns7lyiQIOqmP7ft_Eo_Fy4-umDUpBRehPla1ydaBDAKVm6CtjP2vrd0pn1dLtl1JnUUD2m3NIqkyGCYdGqUtwSxC_TSZGzqg6ehsd1z4XmyV7qE=w1152-h648-no
Sin embargo, con la aplicación de Amazon Prime Video no he tenido tanta suerte. A la hora de reproducir el contenido, la aplicación se cierra.
_fHbjjB2H-069I8gWUQPVUFwAB9ARi5xauhfzea2Lj7ZyRTvIpTmesQN5pPywIf_lUbQbGTrwWSkDVoGQX-25tHGGxUnZ7T_RTM4muRTS9BAr2ocIR6oY2XA_IudnopXzLHskfKaOBQqfhLcg1CGZp3B2Sr970iYz6J_xu7lBef8tQnft01wqsXj1-GnZX43H9qAOi0Ov9TF_EEMG4Ulg_iEtrq36tgDr9mWhRWHYRS4Rye5DYTermM50OLaKTAwLROH8KhbsaOCVRk17JRJbpH3fcDP9cCnhZmJaB3Ufhb6_xxFZTNoTM7rRufl4fGGZL8wRTtl4NRze4U2_4ITu9_L7TPU3yHBtT_6hgF8_iUb6PdOCxfgBi-6xUH0-fS6d4KFPgOoyE-wbQ6UlxAKChcK9jAOx4_EWo6__86YCEdQIGMyr0d3RNOVGuETltp9HWjl0rptB2laOXsE7ZEx0XKksfIiZ88t11FY4g84Ppv2lR8vqw3TTSBYcGioK0tdlEvZJavl3MpPKBw38Hz_0mlHVUd3dUz2o7UgsShek3mQ-KkBOJAyQshCaCoenRj9N-OxiPQHVeWidsq8NPECuyJzTUctk57Ykudiw7zHBKL8IpQrj-9JhCLSzGpZgcw_9_GIy7JmFkZBDxFPQxwdXgV1j2mwilMmQ1Ftj3bn9Nr2PxU=w1152-h648-no
PRUEBAS EN ANDROID
No he tenido problemas en descargar las aplicaciones de Google Play y la fluidez del sistema es muy buena. Sin embargo, he tenido varios cierres forzados de aplicaciones. Algo que no me esperaba para nada en esta marca.
El X7 viene con un SoC Rockchip RK3328 (Cortex A53, Quad Core, 1.5GHz) y una GPU Mali-450MP2. Tiene un rendimiento similar al del SoC s905(x) de Amlogic. Estos son los resultados de las pruebas sintéticas que he podido realizar al dispositivo.
CPU-z
KL8OgSbtAk3C0yeLxbCbSqFCVnDjSahG1OKPP2vESQzqLEMCoV6BmuzV8UP_Iypf6S8ArLR4EaxdCaYXvitaT32snZtOnH4eUNMh6Bcj6rYunRRu4K4hZ9aWwgUidA-7FKW-YYRSlAKsSqIEzoZAeggAXBEJXTKIWMqxXrqoVRP6lqcn4kIlN34aQHQGBTYX0ODI9_CtYK-TGgnHzFs0k6p4XbUbuUIFGA56t8ue01Om6tGtCmZL5mbszzuz9Qkb5KSIgT5u4BepJDZyIf8tk_r0S37ll6FyUb2y1WJtwtfQNuzqU1AgivfG3fkmAERcUePH-R2k0CVjVaiY7GB3olH-MWYSeqtTuiHw2qrypxihsT8LQXb4dF5Sm4vFSeDKmS9QGX6LqDNEjSKcFAbpUzZr-DT8by7kgPjyZxPsbeiZfsG_x1bUOuVl4OanQxd5TCdrsKit8YRD2TJVpfnHirSeme5oiLr8hchL96VRDS_mAhnGtgYIzNS7aW21oHvVPRw_xWwGIDawPcIaAYFdi5WykJoCRTCcUriWvgIRxOphXbQ43g-miDzg2hU16Yf7DKSeOPjqlpK02pXjWsUxxKsKTaAcwg6LIFXEJemNZeyn7AwddZRFIUMhl501SNtCGeKDyDGTyaRXzj39on1NedBGMz5JXHtuFstKTnVlYv4DIds=w1152-h648-no
No se detecta correctamente el SoC por parte de este programa.
Antutu
xkTnX3iG9YvWnkojcGBL97bM5Zkoblh06u9ZYyKCCrkNtorYchzKp9M3Ga9zk_U9PX5YCEHpeaHfMY_rWYuuOzYvqAXG5bHu40EiRTuh79L-wzMgpqE1rIUiMkbprDQwk557xH7kxxajV7sYhFo58XroLCyxNOmkx4mve2mYmfaOYHi06-sx0WsfeK7zvbDxD_HQJHPRs34Zr6RnCVVtxfT-aWfiIC4DVHg6KoG-9xOP60Op2XawPwk-fVNtT2pT1VcX1UW1MyxypkvjvVhg-FKSQFdk9r7BJn4GKV8zaCHRfrqxXLVaNsfBRpDoL-dF_cKVL2IZeyclGav1OtpjprOYnBorUE59at6QfPrFYnuGShh2xEKI_mCZtc3pPJ4rDGKji7pJwTXdSjfj2iBZGbtSsa7QoB0vQCXNquFvv50EdJE-y-W1DSPXB7JrSxGZcyXYLsxf4kVesuYGbPLz4e9FXS5NU71WSnpG8lJSubOfLbsUHJJT_NWSTYMbwNjbu9tBme0Jz19kNGhuWJ47cwhEoQQ_497HkMG6IXR1U92qzZn9zjJfIUUQ41AoPX4K_pJn-aotqfz62cSE6_IhJGjuPGhxuFawcLS3swlhYI9jQx86DBFYwBqwncSamrS2Hz4mlei7X6P8_2_CKM5Ok4px-M9wM_2-f_03KTGFKmLRlgM=w1152-h648-no
Geekbench
9gLhnyeWwcz1uz6ax9LGyMxK-CujDTB_hWaOcYQv1t45ysdWbRrm9oUk6vZsJBXq_WkGYeSiGPDfKKImKuKX4fRJbDZqqZl0wxRs-4nJQsTrHlhUP-PW6tHHconHCCbsp97hXj2VbldEh9d159lXXzIkJZ3HtNDO5WdU7DyO1UkAmAzuxgwjNwKhiMgQlSWLLketDvQ64VOyrGQerOOlVwTbSvsQPFF9CCsHGp2n4OJZr7xBS0NEDn21EFZbgTzPgATKJtYkucsic6RfR8LRGVgRUeWUmxRwICZZvwKgEcjEUSEfYRDh5UQHBdbX8dHFbrsbdBtPyc_a4ZYTCsIL_Q23kGH1i1XJsMFCDALiIT45p8fKxhXtwqLccBTtsTdjCW891itH5i_JSznIfV0kKOAy1xyWSJ17n7AKXwYCZnRN9XSi9iPk1wCCCNi4xIbe8R_hsZHkxbNAMrdOxjUN2mwPJj2AevnY_aRge0MKVDnUEZ2-Mr5K_8vwqzZYXDjVhwLfmuh_SBfQ6OMfIoHphIMZ9WNNhOvIFHMmKxgrLhpc5Zk4ptBQsw69SHWlurBBZP8-dPq4a4tMdnI9BtXeBpzDG5tEGzAXq4DQFbOk6uUajcCTaHXMi_CeSZ1uwp7LNsAhoF_Fm8IKTx82U5rOzx5aUBhCfkAotIe4CiFeGGBNgu4=w1152-h648-no
A1 SD Bench
qWoGvbxphl-LB8ICDSxo6U9v4W5ObwrE8L1Q5rN3YM-r4cXlMGTFFQmYrc-F222-PDZ-GmKqSbzsnRhXw6kCLCo9E4CW-D6RBYmBk9D8hSqQjUMKZ9W0Novuf3Y8tBLIHU06Ip1Z1Wb4Y_rV7Bnk6VMXt1SZJ6N-mDgBTX1Vkw74A7HToGlgpAW_09E9jQtZHmwTyTiuSV9NYx_hlK9kvubwGvTAxuMjd3eyNXCf_esk4gYaaq6AeA0MbC6KYIA0nuXBG3nWqPp83nQwIvpwm7h3dHMZ5MgelVWaLDbE1Hwth6bMSBSjNnwypGR7B5pBodFFnV-BkGN8PDO5Uy1wKL0Cnq_QlZ_-CCGPjAdAIquVc9Ay8NHinOcCFDwA8rwL1T0dnlCIaBLeq7tjf2i2ncdLXnDLzVXP3xeGONSZrmFUI-8wzBFDyyA6gcPyycKHX9FL1YX5M0yh7SYCAuhxNgHQO1PWI-GWrPl3QFWCx5YFHvf5rXEwlA4Dp61ppP4Gx-IvYyp1-X9cfop4UQ1YuTk24Dnt8LAGDXmgI_aFL66ADEtjS9ksYFIYgu9aN7KFdI-KondJ1Mf-uuVR-pc6gBekQhU0nlPUE0MW7eyAwkp2f3__xwAxNfGpkuFe1BO7aJSNH983nIMUf2f3Cl8L5J2EQgXiZhWeNZqdvzoakvw4m_s=w447-h236-no
Las velocidades de la memoria eMMC son muy buenas y ayudan, sin duda, a mejorar la fluidez del aparato..
CONCLUSIONES
Tengo que reconocer que tenía muchas ganas de coger un equipo de Zidoo, dada la fama de este fabricante con otros modelos anteriores. No puedo decir que el X7 sea un completo fracaso, pero tampoco puedo decir que me haya sorprendido muy gratamente. En el apartado de hardware, aunque funciona bien y para muchos puede ser suficiente, no entiendo la conexión fast ethernet a estas alturas de la película. Afortunadamente, el WiFi compensa en cierta medida esa carencia. Sin embargo, algo más difícil de solventar es la escasa memoria interna que trae el equipo de Zidoo. Esos 8GB se ve que están pensados para reproducción online. Lamentablemente, esta será una carencia muy importante para quien necesite instalar muchas aplicaciones, juegos o hacer streaming de torrents de gran tamaño. Sin embargo, el apartado que más me ha decepcionado es el software. Sobre todo por los cierres forzados bastante comunes en diferentes aplicaciones. Que no funcione Miracast o la aplicación Prime Video tampoco dicen nada bueno del software del aparato. Sin embargo, a diferencia de otros fabricantes, en este caso tengo la esperanza de que Zidoo solucione estos problemas en una espero que pronta actualización. Es algo esperable en un equipo que tiene un precio sensiblemente superior a la competencia.
PROS
Soporte Zidoo¿?
Movistar+ funciona
CONTRAS
Precio
Cierres forzados
Prime Video no funciona
Ethernet 100Mbps
Miracast no funciona y sin app para DLNA
