HDMI 1.4/2.0 --- VGA monitor
Tema en 'Monitores y Tv' iniciado por Mr T, 30 Dic 2018.
  1. Mr T
    Mr T Usuario
    3 Dic 2018
    18
    Spain
    Me gustaría usar mi monitor Philips vga a través de un adaptador hdmi vga activo.
    No estoy seguro de que sea el hecho de que algunas placas base que he visto a veces tienen soporte para HDMI 1.4 y otras para HDMI 2.0.
    El procesador es un apu ryzen.
    https://www.amd.com/en/products/apu/amd-ryzen-5-2400g
    Gracias
    HDMI-VGA ADAPTER
    https://www.ugreen.com/product/UGREEN_Gold_Plated_HDMI_...
    Specification
    1. Input interface: HDMI Male/ Micro USB
    2. Output interface: VGA Female,3.5mm audio
    3. Support Video output in VGA:1920*1080@60Hz(Max)
    4. Additonal power from Micro USB connector
    5. Cable Length:16CM
    6. HDMI input resolution support: 480p,576p,720p,1080i,1080p
    VGA output resolution support: 1024X768, 1280X720, 1280X768, 1280X800, 1280X1024, 1360X768, 1600X1200, 1920X1080
    PHILIPS MONITOR
    https://www.philips.com.sg/c-p/193V5LSB2_69/lcd-monitor...
    LCD panel type
    TFT-LCD
    Backlight type
    W-LED system
    Panel Size
    18.5 inch / 47 cm
    Effective viewing area
    409.8 (H) x 230.4 (V)
    Aspect ratio
    16:9
    Optimum resolution
    1366 x 768 @ 60 Hz
    Response time (typical)
    5 ms
    Brightness
    200 cd/m²
    Contrast ratio (typical)
    700:1
    Pixel pitch
    0.30x 0.30 mm
    Viewing angle
    90º (H) / 65º (V)
    @ C/R > 10
    Display colors
    16.7 M
    Scanning Frequency
    30 -83 kHz (H) / 56 -75 Hz (V)
    sRGB
    Yes
    MOTHERBOARDS
    https://www.asus.com/Motherboards/PRIME-A320M-K/specifi...
    https://www.asus.com/us/Motherboards/PRIME-B450M-A-CSM/...
    https://www.msi.com/Motherboard/B450M-PRO-M2/Specificat...
