Charla oficial: Sapphire Radeon HD 7870 GHz Edition 2GB GDDR5
Tema en 'Tarjetas Graficas' iniciado por smarty, 21 Abr 2013.
  1. smarty
    12.124
    4.108
    Una buena Gráfica con una buena relación calidad/Precio, escelente alternativa economica a las la 7950 pre-boost y a las Nvidia gtx660 ti. Con esta gráfica podréis jugar a todos los juegos actuales a un nivel gráfico alto/ muy alto.
    Nota: Hubo unas SERIES DEFECTUOSAS de Sapphire Radeon HD 7870 GHz Edition 2GB. En la caja se ve una pegatina, FIJAOS EN EL SN. Los posteriores al A130300061911 TIENEN RESUELTO EL PROBLEMA.
    Características de Sapphire Radeon HD 7870 GHz Edition 2GB GDDR5
    • GPU
      • 1000 MHz Core Clock
      • 28 nm Chip
      • 1280 x Stream Processors
    • Memory
      • 2048 MB Size
      • 256 -bit GDDR5
      • 4800 MHz Effective
    • Output
      • 1 x Dual-Link DVI
      • 1 x Single Link DVI
      • 1 x HDMI (with 3D)
      • 1 x DisplayPort
    • Dimension 260(L)x113(W)x35(H) mm Size.
    • Software Driver CD
    • Accessory
      • CrossFire™ Bridge Interconnect Cable
      • DVI to VGA Adapter
      • 6 PIN to 4 PIN Power Cable x 2
    Requirements
    • PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard.
    • 2X75 Watt 6-pin PCI Express power connector is required. (4X75 Watt for 2x Crossfire)
    • Certified power supplies are recommended. Please refer to: http://support.amd.com/us/certified/power-supplies/Pages/listing.aspx
    • 1024MBMinimum of system memory.
    • Installation software requires CD-ROM drive.
    • DVD playback requires DVD drive.
    • Blu-ray™ / HD DVD playback requires Blu-ray / HD DVD drive.
    • For an AMD CrossFireX™ system, a second same AMD Radeon™ graphics card, an AMD CrossFireX™ Ready motherboard and one AMD CrossFireX Bridge Interconnect cable per graphics card (optional) are required.
    • To support 3 displays, one of the monitors has to support DisplayPort.
    • 500 Watt Power Supply is required.
    Garantía: 2 años.
    http://youtu.be/heCCwvim8Y8
    Información de la configuración del PC que mueve el Battlefield 3 con esta gráfica:
    - Specs : Ultra + 1920x1080 + MSAAx4 + AAx16 = Min: 40 Fps | Max:70 Fps
    - Config :
    ● Seven Ultimate 64-bit
    ● Corsair 600T Graphite
    ● Corsair HX 750 Watts
    ● WD Caviar Black 1 TB - SATA III
    ● ASUS P5G41C-M LX
    ● Intel core 2 Quad Q9400 OC @ 3.06 GHz
    ● Corsair H50 Push-Pull
    ● Sapphire AMD radeon HD 7870 GHz edition | 2 GB | 1000/1200 Mhz | PCi-e 3.0
    ● G.Skill 2x4 GB DDR3 1600 MHz
    ● Samsung SA350 24" LED - 1920x1080
    ● Razer Imperator 4G
    ● Logitech Y-SV39
