[REVIEW] TV Box Alfawise Z28 Pro - RK3328 1/8GB
Txemoto
Z28 Pro
ESPECIFICACIONES
  • SoC – Rockchip RK3328 quad core ARM Cortex-A53 processor @ 1.5 GHz with
  • GPU: ARM Mali-400MP2
  • RAM: 1GB DDR3
  • Memoria interna : 8 GB eMMC
  • WiFi: 802.11abgn
  • Ethernet: 10/100 Mbps
  • 2 x USB 2.0, 1 x USB 3.0
  • Lector micro SD
  • Otros: Salida AV, salida SPDIF audio.
  • Android Lollipop 5.1
  • Tamaño: 10 x 10 x 1,6 cm
  • Peso: 120gr
CONTENIDO DEL PAQUETE
ObM_IlL2hL4Js9Qh2E0LVioV7qSJ5R2VqOc4wHnBmlGUnfZFxCDJ-O7YqV-iNxip6SYqvh7r0A_YfPLaEuU3p1cYPtWJTWiW3iOyMb0qZ8I7BsQR4dScl_UXIx_ooyodoUIZji42H6dgOC_TZ1n0ucjkWSp8N1-4x0GP9rwBTWmRM8yMaVW_RzRqeGM0xe03-ym35AxBqXw2Z26ilC-fi1Pa9KxLKxiCz7CKuuz0Z_qSz22TDbfpOB5nV0ZhejKzv85tfpgFtYK6D82QVeKDYQ2F9pMjzJ_hGSXOtZAgcx6nfvfIGNbKi2xAL2bD5mQ_4mMQ65QV8S5kk3040i6xc8B3EqIsn0A1YhsiOEYFcbkRn29uA8AqaXbqHtSW_tr_o2FsxQb6j8hEXNh--Ugy_3X0sBjVl7dzNmnj1ZWrLDttMiPktrYxYobLUbDo0srBasygl_Nd2eKsrQ8IxWKxO_9K3sw4i-G-YjtV0SL1vEwDF3qfC1N3QAtltm4SAxgEB0O_yI4Ub1heOdOVVNBUo0DHMOGdsS6UBLuBxI67TftYQ0iXrBwV370Pm3-JkYUwAvgM5oMhxWpFWKJcjYUNgQrYVNwasqQ0miqU64v7dr_ZPH8KzUj7YN8a1aB-xIfWvWWKoh2iBvMZhQ4fjNiYh-jgecCLJpN3jCpyPPl0aBg=w1266-h785-no
4pQk_FWq8CpDZ55Bk8ZlDH5ITZ3AULXNKhy8wQfk2Tud0tflT_tNR8cPlXQuJ-XcI1kxiTiAwtFmRebfuaotqOJXhh7JzqUBfD_HVyiSI_O0_vQTrNV6_r3Ke5Jbgvds-LkXpNWsxOyUyKqbfAGJKHsyCqben2xdG-46rCQajwVAvuDw4mNsCtNnK1mJFIPCltJiKgujfnYg3fu2gCcWs3DgtzNiNOrq6RZCPtPxIGuphM04Msymf4KWsmCxzcgjRNNIos4xw5SLUuLCVBOPTbWEV1E6jWfgDP33u_pdPcWmDUmNiRpNcqxnojNVZMLevd0Gdcjot3hfXUYSbG0EFEf0n3tHdprQ5qC63grffNrTshVMDg9V5TsXX3DQTBc2H7xhioqkqo6LV0HFOYWkswYFG6VDCwBe4kIplWCe4pkbCyIpkyhxNt2hJ77bM5FYZX8s9ZpEr1K3IuqiJhdnCmhiFcrY5OUk_Z6GDQqbSxQpxDZK-kuN50fGYq2a5CN7NtaHuyfvqLx3zgLs7uwrwcYe6yAOmzB98vTW08a1M4blXVhkEkWruoS5k8mvVn0GttGOYesyjpZEb44j-77ydCYXsqotFBqn3B6XK7Cwpo_cmhM09DWlbzt7q4KpqFuoLH6U_ZWGF_x7_5Ji69Mk29Z1wrHXOdkRSq-HqXPB_8k=w847-h785-no
  • Z28 Pro
  • Mando a distancia IR
  • Cable HDMI
  • Adaptador de red
En este caso se han ahorrado hasta la simple guía de conexiones que se incluyen en todos los paquetes.
DISEÑO Y CONEXIONES
qggIat60vVZ3g9TIQ17M2frft0DnfDl_7P2DqPBPKJ5JLQeDBBdw75nUH-Vb9odgw7aUdnVg956JvG0N08HfGxLcO5XrF8BTz9E6Vy14-g4OkeK1_P0Y41FL9B8tem6oPpfMI7X_OOWKjJhEA9zX9vrocqTwJ0DQ57c-RdLjh5Qt3tFunsBsEipdVlyK_UtXtNoCWdFEDV-aBIq3OISsVAKL5wvEDaHcKp0oJD54uSwWVqMETehNcxbpBxDdlBYLV9SfR7dCXki2NJnh0eRtjoyw5HAQmzI5Wbw5IrtwNvspcVNjNDhTDIebjJLOXibGxCFJBHnkcRJ0PdxS6S3XUAdqYSNgc4yM3bzYAaL_5gwY21HxYQeXL_OJ8dEbLsqmODh8S9Wzyvcuchb_pMI5JCV197AFWvjq6zIibmmtzh_BgpQz9w2r99ZC3xkKxS52nQKUYGHfz9ygPlytNM0lFr-odiOfW0XiPJQHZmGpyXVdUA4go6XbZJgW2lELzUsElofsHO2bjPQQTcceNcmQYnYExrFzNgV102r2rQMzIgbeMFI5rIcyovHW6bdMMEuciSA3AnjzHRxByLZi3bRUqk-CQkk2MWkNcgnepu4gFW_j7L7KGIn7g4LdhJ6HX_6WeukWzB2zoO5FihaUAfOWP-5uj6j6fmGbSigGAFuEOl4=w1071-h785-no
Sin tener un diseño rompedor, al menos han eliminado las esquinas puntiagudas de los equipos más baratos. Por lo demás, nada nuevo, plástico por todos los costados.
En la parte delantera tenemos el sensor de infrarrojos y el led de estado. El led se enciende en azul cuando el equipo está encendido y se apaga cuando está en reposo o apagado.
OCBklUBP4h4mZrHpksY12oAL1paqUSrtpzIXSDgPvn-eyIomR56VDMjM5grtWgeVOtw33GzxBHQoWA1H0sKGtU4FR9iI0hXS7G1o9buN8iJxGFxZ1mJajmGpOBg7WoWV-TAVCPeEtJGDoDsb0eKd-4XAbIcWgwSxYG_H7fxEKedoO610I5sDFZFOXnlckNQdU6KZWxY7k8M6jMqBrUZyeXZXPy8qjejeupbhWt-QSDcNTIXbwgesvMjNnFUhTmMCBgnfXG2Id95aWJgHxEtZI80koLJ_Pnj2D2aPsxB3zQukuaFPvAOsebYFVLZBl3FrKPVRH0hCixD4fcvxUmrwAQE7VQFoMONH7U85l2NrZiSMRLRi5W31H2qhjJi2hFI31u2PPjBgEfiS4gjXNkPyz14RX8iDpd9ctrnqtm10VEkg187uHUmbFF87ldh9R0OlY9gsM80nNreQ58osecj6HKBODQp96ICO0VrPyvSMa63aKjV-_UhaDoGVQc4HwEAaPbQBz8wjnPN8Ty893PULXebdxVVUCpPgu-X_j8MQ3bolrgWjfs2n-50bapv_gUumqEtB7dOEkv6oi1YdL1MtnUxNbYO9iBcfhu8p7dGHQsWpLCNWIQ7L31lugzr90Q3hazLpPcalw0b06_3nBiftCcSzgse94oniRtA8w9sWZSs=w1517-h397-no
En la parte trasera tenemos el conector HDMI 2.0, la salida AV, el conector de audio SPDIF, el conector ethernet y el conector de alimentación.
6CxBH-9N8Zd8FrODhUR-tjL3tfxrK66JP9DY4zGlWHvcXcnbJbBx9YMgXJKJ9wR2QcY4obhaBoa6mSf67UsO3UxLpoFBHTS3Eo8QyI3YEk_lKLYq02C84Uqp3ZWfVtMKu876AzKY3bCOXvRxEYQRSa3Hul3a08tu_pG8lLZTxIDInxmix8xjofgcbpd23APiMUHGEOxmEH0wk0XtsFfzYR2Ndn76MnbaGClB9IX0N2MJuBLgilhA0TlFzYX81AyP1YD6XYmZpEl-cCY08EAvYIZ79BQSFw5Hk1nY2d6DJ3pF3dTo70aDZcGnWMB5xPm-HE1xUXq0Euey2DoXnH1yYVuCqkQJLWTuSdS_umTUgIJkC-gFKba1wQ4jnAV26FtZ6IztMX3gTc2LgxxJWB4BUidZpGxgb-7c2DX9Likr6ZrvlX8030fLaQEjyooOeWb-k16Q8DacQWAXs2e7yFfA55ovJEdLU9K5z9NDFPPcg_lXsGwYj_1RFkNZUtxM1gTXU0DXvoLqz_7ItJBdT0lAnn26HkMrIvwPOFi5HLYshYIXAwetJPIhgH5R7jwqfwRsWYZrQEkTt_h87SAprz86YrfZ8-OPiM36fTyV3OL-uP68gcvf93UgVbfB98Cw-lrSXxnDCfIaHDMU1vYekzPeOvfppcHQaIu5Dqj4jPEpM4A=w1547-h375-no
En la parte izquierda tenemos el lector de tarjetas micro SD y lo que parece ser un botón de reset para acceder al modo de actualización del aparato.
T07gHWIl2QH7L4OEkjCA3zwrg3pwQvQvo5WKvNTcU7-dluXrAIU3mvb8B1PYdwjYj2FQU_xMbNBjS-i7T8gCXfTpQ5iOb7zXRl6GFFN7CcnjpNM8G7O30N4f768f_Zf5_RVa2psqLAGddljnJnrt8EPjqwW76hOg1b8_xa-0VnJ4VU1UwVFnjn0_T1Z2YhD0--T14dNF6gxdLVSWyr5X4WIatumNjXMTnAKkXRD-w8b4iDU76PF31iIyRJBnKnEybG1ULDPHlbmXaQ-EFybX4zCewqpU5F4T8TF78Z8gltezIO7P5Mu5gcrNFFWRizKRIkmEbn0citUlNMSapsY9g-9vUliTMuurDROXctDbj_wscfIR0xaXaQo3t9ShCCDMPF8hN1jL5Mwi_mn_k2y6Ll8RTmZdOgidJLGv9VUzsr3ska-yTwGcg0tTkfHoJTFPvtmR9YKk_DNyQrpip59mgRfU4sfUOo04-5_3GkCexbwZ8GTKmXIosVE_gtES4Kv3bnY4Nh7MdmBbjKDiNQtndjDSm0mL-SZmE2bbCDWedPovKrNCnxgNiueGMkyqcOsvRVxZAHuJrbIefLWYsM3K6wk3JHyTwjC8uQKsiH6XK9EaYY4G7-Kx1suvyCpPz_gsWkF_OChWZmXaxlDefhJpoS-lwElP-UKbOpkg7GdfKWk=w1533-h421-no
En la parte derecha tenemos dos puertos USB 2.0 y un puerto USB 3.0
MANDO A DISTANCIA
El mando a distancia incluido es el más típico entre los TV Box de bajo coste. Es muy básico y nos obligará a disponer de otro sistema de control de aparato, como puede ser un ratón inalámbrico o un airmouse. Además, en este caso tenemos un radio de acción muy limitado, lo que nos obliga a apuntar al aparato directamente para que reciba las órdenes que le enviamos. Tampoco funciona el HDMI CEC.
ENCENDIDO Y APAGADO
El Z28 Pro no tiene botón de encendido, por lo que se enciende automáticamente cuando recibe corriente.
Pulsando brevemente el botón de encendido del mando, el equipo se apaga. Si mantenemos pulsado el botón de encendido nos aparece un menú para elegir entre apagarlo o reiniciarlo.
gdaW8T-hhgoum-AdrJ5E_GGWvlZDafpPUCHs4RsU3Lr84d07oiYnU7nLTWkHaKu4KKO4aEoXcplUQgez6VngxMS-8uLQBpbzrcbwkG2td-WlLJLmuzgkVwoyk3G05IHXSEv59_LRFz3xKe1koqq1VcGoHuNKVEDUK2GYAzqAx8VcEoCuLbEL_-IdmNRv-xRcceozgx6B2ASMXobKS6R9Pe4uhT_PBpIWABZpuwkwiFzKn-QpVfFRCGEvSxIqjJm9jIZgsbHbN6sLKZFiWY9Avzn-pOvuZIZCjvBhLEyOShLs6R-6Oaj5KkzZtfm-9fLoBb-Eqcs8Cjdovr0wotPYEO87jzlj72x5CaVezZuebQJs_pIVlGwYB1hIwSn6V2zE5uVq6XRjKWWsYVyzKJBEtt9vuI3gfmQmpfZ3rXpETCLNPsx0meiAqhhiFWqNqpw7-Y6_dt3AUG9zNrIT2kapKNSC55rX8u-IQJDPlDgUZsi_f0cJnNv6mxrnkq2ESDvD8AWip4qMR9mBgjZT1cBSB0ZW5CKbpWEEwAT4R0g8TeVWINUDjgHSQmHRTfUhZJnd8aJikE9zIUhuLgn-PQvg-wuBxVY5icZeEMEKVFUX2dMlyJEUcURqmNT0rITPcMl3zmi_Hh5A5ilsZSP4Z1A3EjKCIzpR0nfU7H847fXbUnxczL8=w814-h169-no
Una vez que está en modo reposo podemos volverlo a iniciar desde el mando a distancia.
SISTEMA ANDROID
El sistema, con un dongle USB de teclado y ratón inalámbricos, arranca en alrededor de 30 segundos. Nos aparece un launcher parecido a la mayoría que suele venir en estos aparatos, con una fila de accesos directos en la parte inferior.
xEEeWT2Kt5xXFP7ApzVKkhPD-xe0wHiC-MtJNvLV7O6o29ktfObBB9yO0QbH5X7fSed7NCYwaJOdWjLlUpD5wsIH89Lw58PH1_RnMtZmDDf4ZvBEYg5Ye2VrhrvBuVDF12hFcvbQuAeIo4hvQheuIww0SDVyWB0J716iBAXkGTF6E5PzMwFmdNo0CwGFJOyjOeuCljHEEomj9EuUazhRSW6YY9vuyajVKerH5N26WocS6XyxC28lXJ7UMqnL4xk1MxQiwRFaaCNnZ1wJd5Ny3IvUIXZ7ZV_9HTAStYw6yX0LxeEEWXsPzcLcU6ZRUvlFZ7egXRtOIIDW-dvR4qAmoIX6ekozozIOxoI76QMSg0T3EZlaEKdS7Upmn9i_CQZj44JQ9TKAtYnCA7umQUszkm5KkssnQuO5fWAm96u8qxFV355vAs0APk3smhEf8f6gojz-tiSBkz-ycVrw0_PIOS5nStMyo0kzE-LgnkiMFpTfjbU5B6qE-Yiq4UiA5BIIz5LnrepOOqDmuAJN8GdykYk-e0hNh3zR8IfndrMLbZLQjJThxGbjjtGZFYPylDIvZjf25v4H2FzeJd4-00O4E2du0FH2ME7W3lU8edI7d7V0fx7Oj0OCCTWbjJMQnOpjjmUs6PLEzt-D_wG4qJco7-UuZkritwosHTLBDdMvLxXoAuw=w1240-h698-no
No tenemos acceso ni a la barra superior de notificaciones como a la inferior de navegación.
Al ser Android Nougat, el menú de configuración se encuentra en la parte derecha de la pantalla.
TIN7QSdt69Ga32kgiCowT47Gcx7wr7Tp-yALcNgkNnBINTDufj20RiKk4yrZQlWe1N0gTRoCUfDGtTvg54s_Z9yfWDcNy-pMkModMYJxBYFoRZKgv6Rser4oY2kxB4ZrWtP_PMFs5-IzRmas2oX0xn10RwyW2SI-1jmw5xwpoo7Oqn-gd9U3VfBfvDw7_1dScKRAHOF7cZpNXTrcvAVzB-Bh618mVlp6LEfWc14rf0uPOv7WDF5YbQP2h6ezd_56w7581LoX2To_UJLubBfwZGIozrLUvtWetppo-fzQiChbSyrl_y4P9TqmdlOMr1eV04i5Nq79prJ7HUwOZR2ICn-JO5CvpnnZZgCj6RcXmJWsXgyZw82IXyFkjwAFB5Z-vVrx_H4DBBpgnhd0YKFj7Qyd__OcvrhMPmATxCmVvEbOiLulYFjEd2ODt_wtp7ZsKCGclmsiFEnLR21oKjqRIeLGp_fOXjUnZL9JgDqva6Rtxies0WJl-WPZ2FMQGLn0bZMnkfUu145fCgKMnj-eDEB7ZSJdAIEkOAw7B_0eVSL_ugAQ0NPMLqyIHO7cepi8HQSJZFEgiE54LbB4pZSz05FRiAnIQsx08njV_FYfYEb6W6BMqp91k_6fBgAhFxmeAuKgquMyim7Jk5Mh-o9AjVkRPLcltsgQiEcgiQIASz436_c=w1240-h698-no
Firmware y OTA
El equipo viene con la versión 7.1.1 Nougat de Android. La versión del firmware tiene fecha del 24 de mayo de 2017.
Crr45iFmly4hjPVrxMAf0lyCI5IyiX9JbSxUK5HHj5Kxj2yh-SI71mtYEszu5BR_jwUsh7anBvFNRjJ-4weVM0jm_c0V9OyMkbshHZXZSDy-9MTQRVub055AKGzHX6YxgYPPd_esLoNqJMRZp7Mu9t09nDNJaZZcE3Wmt-UzIwnOnVr3CwY80leUkjx2c5KyvCjoY0V6mdJ1T8vnGXT3Q_9UoLt7oF3bo1LY92kf4omF-s1WLp1uxatTAP0XxMCap7-fdUky6u3JfzXaL3caCuNSVcaeaixu9Y3wk5mTPT9Usa3Ph5wlnexLNJlsAHeOYB4GbaMnVK70JCewVueW1otAFDcsKL8wiIQYocKjC2KljzHt1mY0MWxStFZ1p43BFQTtMw_alrG1AU6RVWhsxjZ7HnO8TfQrUD16spxliZY4dwGcwMjFJB3SNjngW6ZZYccn514-4Oujzi7DPJPVYFJseyZKNmRBikEZByJr-AbmpXsjWSm7vKGJf_L9fFtpyisKGwQ6IfWjl0-Bx3AQStJ6xDEwV-dSY6QwdTFmaSd5jjP5Jny6g6giXdf5iZvIFca-6INJU7-bkZv2ghegE2dDEhkZF-Sn_uO6twhIcQdCvkzV6vVvmyvpCGKCAKBGYrPsg-PpxamA-xG9CcFzzeCRCI6-DN8uoy6HgNv35KHI660=w1240-h698-no
Cuando le damos a buscar actualizaciones, nos dice que el sistema está actualizado.
MBIDk0zc8d6D9Th2Rh27JQSQKJNRbgE_SsJshUnANVGAvWLNX4M8yaewQzo3HdAFMTjxhqKrX_BCzrM7NW9GfhC1kfNjchc4LNkHaq4e-4AdZjHvfXSK7S_zTL3jmJKgZ1c5ahdBC6iHnrQDtSkxxll3ZImL0cz9QbQ6a2HnYNyBHbDI7Oq9hprPRzhx3tK7Ofu29vpcpPd_rtdfMK4tMC9wMrdmwEE-Qe8EEJMR3tKflGATaidLsxBDTICIf3thmbtx_l4_j3FZSOVY9b26ZtFG8IoZV0_sBrZILtGrSG-AcpAckqcAYzuhvpn6cMobtpdjuCCUAc6c9IJJm8dXHZwlQaPhDHYVLH6_ZeAOsuvwNAihx7EdPgQ_5Afop6SsluJiaoO0YslZSbbgAhqGGKIsOREIpLQzahq8JeLoiHqhk3WMhTV1DTJIaAgCLspoRAm9-RkaLkq5uvjv0eP4LAyT0rsifZN7XmQq0Kfj0Vgn3b7H4Zed4RtKWHNIZ1X2n1f-FUkVjd3CplGB9447qUWZWgjAxQ_BgoHcpX9o7brw-369c7SoAjKy5Tk0PjmTzELrapY7vePaFktkGYs5cpIjah7ozjQd-G9t3j4tCA7Vz2b98RUKmaRDzEimdywV_zTKHmrU7ukVYTJleyqX6UO0Dn3iJmiGodYByCj9FY_AGbw=w1240-h698-no
Almacenamiento
WHxOMEXT31cksIOGWSp4bqFmDJA_qx39j10H7qaRz3P3Ibtn1rm0qKuy3PqpuIUnunEEhaWHhYdxxSwtyTj-sQnKdbMhkPK_q3lgrhi4SZOa7yqgi32hFaebm66iFkFfcOUMAjAUywPseAZgXjD9x1hkonhb85Lp1e-qtYJuxRtH5c-trSwHRbM2DRjxNaRrcyO789rdHJ_Az5ugTsQ_E4qI4-i1_DW5woLsBjnNQSs01Pr4W1lmSCUjPTTPEcWC_FbX4GJgimGPP9GkNqhBMZT6ZVxIh7Nyaa2cO7g6CrAGtEyD57HLBPi7vtVAh-TR2xF58dkDbwCtrZQ9GQoR5JLNIMAWv2fhBsqcibW_PGOtFNiFU7LaEuJGDtUZRSEtNW4dFiE9s41_jwcCxHv-GaqMKkzf_GhOE_z8D9Ob1sHlJXwPB9RqB-eVeh1tmyL2Xjvxl-ixyHLBayBqRW_8k4Zi-5SJxW7WKdYpxtiZfb_ksawixdUqSkcJkT7ShL6DbWkFng9lh54reI6y38i_a28cmkv1fhtDS0o4iOBFO61Pl54hSu4uZiVuG5pm2YxAoYMFN7gewnRAM1PkMRcLcHl7nVCbWn_2aDODlMEglJBy-mrP6I5D65pASiRN8W9ehH5Gq5vxOhuOrdidUGuyMIDHn1L0NGqq7XrBMxO3z3mClDM=w1240-h698-no
Aquí tenemos, junto a la memoria, uno de los puntos flojos del TV Box, puesto que solo dispone de 8GB. En los firmware de los equipos Rockchip suele ser habitual que el espacio esté dividido en dos particiones. En el Z28 Pro no existe ese problema porque tenemos todo el espacio en una única partición. Tenemos algo menos de 5GB de espacio disponible. No es demasiado y no podremos instalar programas pesados. Sin embargo, para usar Kodi con los addons más habituales o para ver contenido por streaming es suficiente.
Salida de vídeo
Este soc de Rockchip, como el s905 de Amlogic, es compatible con HDMI 2.0 y soporta salida de vídeo 4K con un máximo de 3840x2160@60Hz. Detecta correctamente dicha resolución, aunque intername debe trabajar a otra resolución porque las capturas son de 1280 x 720.
C3jv0PM7U-lfn2fs_rNTU3UXOMFjlqa7CXq5vo2DHdXHY5pSUs5iBhDEPHDzTMBgpsN20x2fqB0aNIOcVMqZtyLhW2SVHQ22pDhqeel8JSkWV4I1oyOeFt62yNSxLK3eUoQ2r1dP_nnXkdWF23G_1DB7otymtTMcEvGK3daLphrcliYIq25qSsBGHBlHodgSaYv6xxgNaQew2ODxnyAwHTspkGY9IWhDDoDGh0U3_J-AhnOSWJA_UN5G_nViEp_zZmwg7ol9W472MiRcDZV5SVo0OxqFNCbY2O77Vl1d0ECLUVGw86d033YHde7k_CCEmbxBWBP43VwORDkSOy1eSaO26VtEE7xbu34g9XI6von247WC04ubH35ULSZoh4Lt57FnyPx9mnNDWg3hg3ek7MrmDLsQpFtCNh91BY774n2Y-H3o_otuc577GOQRQ2VbqMmUOxHegwdmzWtRpHUULgwYkI2QcFk_JmEPO3kheFBjy4Vts-onu3lG_q4f8mcFLm2KcvwjfuDg12nChjY-oB0DpWSW6mvGNUcdpwXKJaW8CSMcUMIogcqdSztED9rAevXP7SeFZNG8CDvy4U5KyplbjsFIq0-f6KvkdeQynyomw2pwyPRIy8PSo3kV7SwZK2txVeKqWHLMhkMbh0_Xg0ZRB7JWzBPsEU1En8f4oMlCWMM=w1240-h698-no
No hay posibilidad de habilitar el HDMI CEC, lo que agrava aún más el que no funcione el mando correctamente.
Software de control remoto
No hay una aplicación de control remoto. Supongo que Rockchip acabará sacando alguna, como había en modelos anteriores.
Miracast y DLNA
No hay aplicación para transmisión de ficheros por DLNA. Sin embargo, sí que tenemos una aplicación para hacer Screen Mirroring o Miracast. La he probado y funciona bien.
JHGRWfUrMsvtBqv2EFI7BXSXnjSYI2SNjc8d3REz8luPN38WhOWAzqU8bsCa8eaG0yUZhL4rNgKcWDvoXdS2GdT9ZUbMqX4MsgbG4CE3WUyZr2q3R5Ibdlq9BnLs4CVhGhYRflum3j-agS3xvuNue8-8MPWyMFTrbZWDJ_ZBIpw1takZC9eggDop4zVqsFvuIf2lixvJatEMizMwCIIDcb6vaxSq7HNrXwfoD88ImpNrttUTwec6etqzycYrSCgvTYUdh7UOmlAVjFf8xHVsrlCwNXY-mMiG8fESE3RksAoQ9RLd-3Pour_Z8r9EPc9AK3mu211NoeIlo8K9IF-3nYB_0K4wcGuq77mln0-rr9dlPKE1XF7eUblLAbnVQNa0sgeSZviZlsEqH7z-9eFUYJIabtMY2-p595RINJLdrocxL_UP5LPY48EkIKVH5se7b-kYMHX7cZ7C_vTBiZn-C54IFMiBuS0LP2miawQhCF-50XXLt6JbF7rpaaPFcoVLzbzprPuOJIk0cUCjdTIXzItztEh9ld7vMlGwFTHNuxxg2SxBkYH35bEU1FTrrqRqBg4lTNomHZEUKhJVNG1HjqQ7sNe40h_MQQt6n_mAY_8uGPgoE5uIM7IgDdzEke5LpXOOI63kflJikEEmhHpFJCKvq8HmwHxHdv_utnvA-ioeGUk=w1240-h698-no
SOFTWARE INCLUIDO
Estas son las aplicaciones que vienen con el aparato.
Z0IgPFTNUC4rG0a3L26nrSCIkhwNU_3PieK3qmp2FJGydge65w1IPz1J8jBesfC5xos_hSFMAphCHzBAngv2ZyEakoApzqH-qWgxU5uNVybWcRm9EAXf6OPxBXk2OBSEG1nMANI5EEHtDreWnbhhNzVWf4UBLKmYXhEALrNjvdzl8zxaBX1f1maE-LueCQU3vIA3qLxTGq2h1GSwXyvY2eDEdVXJEDUybQUgwhEN8G-kML3oFEj1OTeBXsYQC5IRmPXfYdXYTgrX8-ke7Iwlnoao0gUGzA4K1TBGJRs2iS--733lbXE4ivw6uLGHCf9ssnqrt-PswjMN3_RSgi3zmKmHDi_J-cND3I2xV43zE39YLW3ITdzc6_yM7lHWg9CHi4EMBPoHbRQEIsKVZCA5HAYY-vwkDsqjFXf5iQIL2nzA3kEUUvMutLVLwBLZmCJCk0_99P-jr0ax3IGwJKijzHUiS0mi6JNyvMBh-2Gi-w1UCExtjBoswpA10TM8ssGfGOtbjfCBUzXGmwKijJcto_VXLwStPCRZHHOm8CgV6KABZ5XupCAVPCY59qho22r-95myITqrPs3ejW3c2mxXeqlF1G8Lb5v99ReUeTdsMbG9_nDpiXuJ7Tlo2wGG1GxkGJ_xH8zS0NrcaSA5qwGemWRgDEYHETShZM3dNbF9IzFdPHY=w1240-h698-no
Ni rastro de Kodi. Algo que se está convirtiendo en habitual en los dispositivos chinos para evitar problemas con páginas como Amazon. He ido a instalarlo del Google Play y me he dado cuenta de el gran problema de este equipo; no emite ningún sonido.
He pensado que era un problema del cable HDMI, de la tele, pero no, es un problema del aparato. No emite ningún sonido, por lo que no hago más pruebas y, aunque es posible que sea un problema de esta muestra, desaconsejo totalmente su compra.
PROS
CONTRAS
No se oye el audio
